6V92 won't start
08-29-2007, 05:57
6V92 won't start
Greetings All:
I was again exercising the systems after being stationary in this park
for two months, in preparation for getting back on the road next week.
I could not start the coach engine, an '85 6V92. This is the first
failure to start I have experienced in the eighteen months I've owned
the coach. Usually it goes almost as soon as the key engages the
starter.
Symptoms: the starter motor does not turn. All the dash responses are
normal when switching on the ignition--relays audibly toggle, low air
buzzer and light are active and the suspension dump light is on. The
safeline lights flash in the overhead. Turning the key to "start"
causes a couple meters to peg low, but the 12 volt ammeter shows no
change, nor does the volt meter.
I have checked:
1) Battery condition--On this coach, all six 6 volt batteries are tied
together; there is no dedicated house or starting set. All have
sufficient water, and each reads about 6.3 volts with the charger off.
Voltage from the positive tie point to the chassis reads about 12.5
volts--roughly the same as the dash meter. Resistance from the
battery posts to the tie point, and from the negative posts to the
chassis is about 2 ohms (without cleaning the grease off.) No
corrosion is visible at any connector.
2) Engaging the "aux. battery" switch made no difference.
3) The no-start response is similar to the times I didn't get the
transmission selector fully into the "N" neutral position before
trying to crank the motor over, so I cycled the selector several times
to be sure.
4) Toggled the A/T switch.
5) I have no key for the rear start switch, but I cycled the
front-off-rear switch several times. For the present I decided not to
remove and open the box until further consultation.
6) Fuel (5/8 tank, Racor no water) and coolant seem correct.
Riding a Harley since the seventies prepared me for a certain amount
of backroad repair using what little I had in my saddlebags, but now I
have discovered how difficult it is to troubleshoot a 40 foot long
coach without a helper or sufficient tools. Even tried reading my
Fluke in the backup camera, but no luck. It embarrasses me to say I
don't fit under the bus to get to the starter, either!
The lack or prior symptoms makes me suspect a safety interlock
somewhere may be the cause, rather than the starter itself. So the
question for the group is what else to try before I call for a mobile
repair tech (at $110 /hour)?
Thanks--
M.R.Kane
1985 PT 40
near Sanger, TX
08-29-2007, 06:12
6V92 won't start
Will your generator crank?
Howard T., Sowega, 86 PT40
Sent: Wednesday, August 29, 2007 1:57 PM
Subject: [WanderlodgeForum] 6V92 won't start
Greetings All:
starter.
I have checked:
to be sure.
Thanks--
M.R.Kane
1985 PT 40
near Sanger, TX
Checked by AVG Free Edition.
Version: 7.5.476 / Virus Database: 269.12.10/977 - Release Date: 8/28/2007
4:29 PM
08-29-2007, 06:13
6V92 won't start
You might also take apart the rear start box and see if anything is loose.
Mine did the same thing and Nick Stanko figured it out and messed with those
wires.
83PT40
Livingston, Mt
08-29-2007, 06:51
6V92 won't start
Generator cranks and runs OK.
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
08-29-2007, 07:22
6V92 won't start
Sent: Wednesday, August 29, 2007 12:57 PM
Have you tried starting from the rear switch.Also I have had the same trouble
what I do is turn the key I let it stay that way for a short time with out
trying to start the engine.
After about a min. I give it a try.
Bob Loomas 1985 PT 36
Greetings All:
starter.
I have checked:
to be sure.
Thanks--
M.R.Kane
1985 PT 40
near Sanger, TX
08-29-2007, 08:54
6V92 won't start
Micheal,
You hit all the obvious points. Normally I would say, I don't care
how good all the battery and ground connections look, clean them again
anyway.
One last thought came to mind after all the other things you checked.
My 83 PT40 with the 6V92 did that to me one time and after chasing
all the other things you mentioned, it came down to the main power
solenoid in the overhead dash above the driver. If you look up there,
there should be a good size round solenoid with a heavy red 12V cable
coming into it and tons of other smaller wire connections coming off
of it via multiple studs. On mine, years of bouncing up and down the
road loosened one of the wires going into a crimped connector lug just
enough that it would not always do anything. It had the same 'dead
key' approach that you are describing -- nothing when you turn the
key. I found it by accident by just gently wiggling all the wires
connected to it. The lug had to be replaced on the end of the wire.
Re-crimping 'might' have done it, but maybe not.
Good luck. Let us know the outcome.
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@...> wrote:
> Greetings All:
> starter.
> I have checked:
> to be sure.
> Thanks--
> M.R.Kane
> 1985 PT 40
> near Sanger, TX
08-29-2007, 10:17
6V92 won't start
Our BB is not a PT, but there must also be a "solenoid" or "relay"
between the batteries and the starter motor on your PT. This relay
receives a 12V signal when the key is in the "start" position. If
the relay is bad, or the wiring has gone south between the key and
the relay, the symptoms would be as you describe. The relay will
have two BIG cables and one or two small wires.
THE ENGINE MAY DECIDE TO START AT ANY TIME DURING THESE TESTS. BE
CAREFUL!!!
To trouble shoot these components, test the voltage at the relay
while someone holds the key in "start":
- If 12V shows up at the small wire and the relay doesn't "thunk", it
is the relay.
- If 12V does not show up at the small wire, look at the wiring
between the relay and key switch, the switch itself, or the 12V
supply to the key switch.
- If the relay "thunks in" and there is voltage at the big cable on
the starter side of the relay, check out the starter and starter
cable.
- If, while the relay is "thunked in", there is NOT voltage at the
big cable on the starter side then it is the relay.
This all assumes the cables have been cleaned, visually inspected,
and secured, and that there is 12V at the battery side of the starter
relay.
Note: There may be two small wires on the relay. If so, one is a
ground wire. Test it for a good ground using an ohmeter; if the
ground tests good just ignore it an use the other small wire for the
above tests.
Bob Griesel 84 FC
> Micheal,
again
> anyway.
checked.
there,
cable
just
wire.
> Mike Bulriss
> San Antonio, TX
> --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@>
> > Greetings All:
park
week.
first
owned
> > starter.
responses are
air
The
no
> > I have checked:
tied
off.
12.5
times
> > to be sure.
not to
amount
now I
say I
mobile
> > Thanks--
> > M.R.Kane
> > 1985 PT 40
> > near Sanger, TX
08-29-2007, 12:27
6V92 won't start
I had this problem almost a month ago. Turned out the starter was
bad. Fortunally for me, it happened while it was in the Peterbuilt
shop. Foreman said these starters don't last that long. Replaced and
kicked right over...think I will be carrying a spare in the pod.
Bob Lawrence
84 PT 36
Tacoma,Wa
> Greetings All:
park
week.
owned
> starter.
are
air
The
> I have checked:
tied
off.
times
> to be sure.
to
now I
mobile
> Thanks--
> M.R.Kane
> 1985 PT 40
> near Sanger, TX
08-29-2007, 12:45
6V92 won't start
Always check the simple stuff first. If memory serves me correctly
the 85 has a manual shifter. Shift the shifter into another gear and
then back to neutral. You might even try wiggling the shifter while
holding the key in the start position. This is a very common fix.
If this and the other items people have suggested don't work I'll try
and walk you thru the starting circuit. Mike McMahan 89 PT40
loose.
with those
> wires.
> Ernie Ekberg
> 83PT40
> Livingston, Mt
new AOL at
08-29-2007, 14:39
6V92 won't start
Kane,
On my '85, you can work the rear key start box with the large key
that opens the Bargman lock on the front door (has the big "B" on the
key. Maybe yours is the same??
When I first bought mine, I drove it from AZ to PA. On the way
across MO I-44, bumps got pretty bad and the cable to the starter came
loose on the stud. Had the same symptoms as you're describing. Since
you are going to be under there checking the stud anyway, take a long
handled screwdriver with you and dry jumping the solenoid stud to the
large stud on the starter body. The solenoid is usually what fails on
starters (some call it a "Bendix") Good luck! Let us know what you
find out.
Shane Fedeli
85PT40
Hershey, PA
> Greetings All:
> starter.
> I have checked:
> to be sure.
> Thanks--
> M.R.Kane
> 1985 PT 40
> near Sanger, TX
