Bulk Oil Tank on 2000 lxi
08-30-2007, 04:28
Time to change the oil and filters again. I'm wondering if the bulk
tank oil will do. I've always kept it full and in the past 4 yrs. have only drawn 4 or 5 qts. from it. I'm wondering if I should use it up for the change and then refill it with some fresh oil. luckyron1 in sunny MN |
08-30-2007, 05:03
For each oil change I first use up the oil in the bulk tank, then refill.
On 8/30/07, luckyron1 > > Time to change the oil and filters again. I'm wondering if the bulk > tank oil will do. I've always kept it full and in the past 4 yrs. have > only drawn 4 or 5 qts. from it. I'm wondering if I should use it up > for the change and then refill it with some fresh oil. > > luckyron1 in sunny MN > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
08-30-2007, 12:37
You can use it, but you will need more. It is not adequate to fill
your sump. R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "luckyron1" wrote: > > Time to change the oil and filters again. I'm wondering if the bulk > tank oil will do. I've always kept it full and in the past 4 yrs. have > only drawn 4 or 5 qts. from it. I'm wondering if I should use it up > for the change and then refill it with some fresh oil. > > luckyron1 in sunny MN > |
08-31-2007, 09:58
Thanks guys, and I'm sure that this will also exercise the bulk tank
mechanicals at the same time. It seems like everything in these high end coaches goes by the old saw: Use it or lose it. --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > You can use it, but you will need more. It is not adequate to fill > your sump. > > R.E. (Ron) Marabito, Dallas, tX 92WB40 > > > > --- In WanderlodgeForum@yahoogroups.com, "luckyron1" > wrote: > > > > Time to change the oil and filters again. I'm wondering if the bulk > > tank oil will do. I've always kept it full and in the past 4 yrs. have > > only drawn 4 or 5 qts. from it. I'm wondering if I should use it up > > for the change and then refill it with some fresh oil. > > > > luckyron1 in sunny MN > > > |
