I have never seen a microphor toilet
09-02-2007, 03:29
Kind of wondering why any motor home would need this type of commode?
How does it operate? And why does it have electronics on it? I guess next time were having a Wanderlodge get-together I will haft to check into the newer Wanderlodges and see what this unit is all about. But untill then I will just haft to flush the old fashion way. Jon Rebel Bird |
09-02-2007, 04:19
You can read about Microphor products at <http://www.microphor.com>
Both the air and electric Microphor toilets allow the toilet to be positioned with more flexibility. Traditional RV toilets must be placed directly over the black tank. The air or electric models do not need the direct routing. I'm not familiar with the specifics of the electric models, but the air-operated toilet in my coach "flushes" into a chamber below the bowl. Then air pressure is used to move the effluent on to the black tank. The toilet only requires 1/2 gallon per flush (and usually that's sufficient -- better than some "low flow 1.6 gallon per flush home toilets). A side benefit is that the connection to the black tank is indirect, so odors are less likely to be drawn into the bathroom from the black tank during a flush (especially if the roof-top fan is running in exhaust mode). Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Sep 2, 2007, at 8:29 AM, Jon wrote: > Kind of wondering why any motor home would need this type of commode? > How does it operate? And why does it have electronics on it? I guess > next time were having a Wanderlodge get-together I will haft to check > into the newer Wanderlodges and see what this unit is all about. But > untill then I will just haft to flush the old fashion way. [Non-text portions of this message have been removed] |
