Gen battery charge
10-02-2007, 03:03
Gen battery charge
So much battery talk prompted my question. I have had my 74-FC-31
plugged in for a week under the assumption that plugging in charges the batteries. Engine and house battery seem fine, just the generator battery continues to lose charge to almost dead. I did remove and charge the battery, but what could i do to keep to it that way? thanks for the help. Jim 74-FC-31 MAI TAI FINE |
10-02-2007, 08:35
Gen battery charge
Jim On my 79 FC 33' I put a trickle charger in the gen compartment &
plugged it in. That always kept it charged. Don 89 SP 36' Butler, PA So much battery talk prompted my question. I have had my 74-FC-31 plugged in for a week under the assumption that plugging in charges the batteries. Engine and house battery seem fine, just the generator battery continues to lose charge to almost dead. I did remove and charge the battery, but what could i do to keep to it that way? thanks for the help. Jim 74-FC-31 MAI TAI FINE ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
10-02-2007, 08:42
Gen battery charge
Jim -
If the '74 was wired anything like the early 80's FC, then your genset battery should charge whenever there is charging current available (that is, the chargers or the engine are running). BB used a battery isolator between the main batteries and the genset battery. The isolator is there to keep the genset battery from discharging along with the main batteries. If the isolator has failed, or if the wiring has been modified, then the genset battery won't get a charge. With old birds, it is almost essential to get a wiring diagram and then follow the wiring in the bus to see if it agrees with the diagram. Many of these rigs have been modified - and not always for the better. In the meantime, you could get a small "smart charger" - Napa has them for about $40 - and install it in the genset tray so the genset battery will charge while you are plugged in. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "Jim Benson" wrote: > > So much battery talk prompted my question. I have had my 74-FC-31 > plugged in for a week under the assumption that plugging in charges the > batteries. Engine and house battery seem fine, just the generator > battery continues to lose charge to almost dead. I did remove and > charge the battery, but what could i do to keep to it that way? > thanks for the help. > > Jim > 74-FC-31 > MAI TAI FINE > |
10-04-2007, 19:10
Gen battery charge
Hello Jim, You have helped me in the past, and hope that I can repay the
favor. I have a 1977 FC31 with a Ford 534 Ci. On my dash is a button that allows you to send juice to the house/ starting/ batteries, from the gen. battery, in case those batteries are to discharged to start your rig. I have been told that this switch does not work in reverse. Your gen. battery stands alone. As some else mentioned,(if it exists on your BB), you may have a bad isolator. Have you had the gen. battery checked, (as you may have a bad cell). Even fairly new batterys have been known to have this problem. I have heard of some people using trickle chargers in the gen compartment, but I asked a previous owner of my bus,( he owned it for 10 yrs.), about this practice and he said he never found it to be necessary, the gen batt. always stayed charged. I have a gas Onan 6.5 KW, that has stayed mostly parked since last Dec., and the gen has always started without any problems. Hope this helps. G.Burke Charlotte On 10/2/07, Jim Benson > > So much battery talk prompted my question. I have had my 74-FC-31 > plugged in for a week under the assumption that plugging in charges the > batteries. Engine and house battery seem fine, just the generator > battery continues to lose charge to almost dead. I did remove and > charge the battery, but what could i do to keep to it that way? > thanks for the help. > > Jim > 74-FC-31 > MAI TAI FINE > > > [Non-text portions of this message have been removed] |
