Air filter
09-26-2007, 11:08
Air filter
Some interest to SP owners. I've had mine since 2003 & I didn't know it had
a gage on it to tell when the Donaldson air filter was getting dirty. I was checking the engine compartment on the street when I saw it. Had never seen it before. Mine was in the green. It said to replace the filter when it is in the red. Mine is mounted above the cruise control on the left side looking in the compartment the street side. I was going to put one on a K&N gage after the filter intake on the curb side. Hope this helps someone. Don 89 SP 36' Butler, PA ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
09-27-2007, 04:57
Air filter
When I discovered my Donaldson air filter on the generator had
seriously clogged up after a relatively short amount of use, I was advised to check where the engine breather tube was located. I discovered that it 'emptied' within a few inches of the air filter intake. (Talk about a way to sell lots of air filters!) I purchased some heat-resistant plastic tubing (5/8 O.D. worked for me) and replaced/rerouted the breather tube. Since the generator sound box is all steel, this presented some challenges. After examining several possibilities (that would have required drilling through the box), I finally routed the tube to the outside by running it down the street-side, front edge where it can pass to the outside in an area where only the foam sound-deadening material presses against it. I left about 4 or 5 inches sticking down below the generator box. The outside portion of the tube isn't too noticeable, but it's just behind the front bumper. I used nylon 'wire bundle ties' to hold it in place. I only needed to drill one small hole in the triangular steel brace on the generator sub-assembly frame rail to secure the tube. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Sep 26, 2007, at 8:08 PM, dspithaler@... wrote: > Some interest to SP owners. I've had mine since 2003 & I didn't > know it had > a gage on it to tell when the Donaldson air filter was getting > dirty. I was > checking the engine compartment on the street when I saw it. Had > never seen it > before. Mine was in the green. It said to replace the filter when > it is in > the red. Mine is mounted above the cruise control on the left side > looking in > the compartment the street side. I was going to put one on a K&N > gage after > the filter intake on the curb side. Hope this helps someone. > Don > 89 SP 36' > Butler, PA [Non-text portions of this message have been removed] |
10-24-2007, 09:25
Air filter
I too the air filter out of my 88 pt 40 a couple weeks ago and I cant
remember which way it goes back in. Is the tapered end against the turbo or is it the larger end that has the opening in it. I think the larger end with the opening on it was inserted first. Robert Rahn Kalispell, Mt. 1988 pt 40 |
10-24-2007, 09:37
Air filter
The larger open end goes to the turbo.
On 10/24/07, Robert & Teri Rahn > > I too the air filter out of my 88 pt 40 a couple weeks ago and I cant > remember which way it goes back in. Is the tapered end against the > turbo or is it the larger end that has the opening in it. I think the > larger end with the opening on it was inserted first. > > Robert Rahn > Kalispell, Mt. > 1988 pt 40 > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
