Help!-Detroit shop in New Orleans?
10-27-2007, 00:30
I believe that Stewart & Stevenson is a Detroit Dealer......#504-347-4326.
I'm here in New Orleans.....let me know if you need any other help. Susan Guidry 2007 M380 ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
10-27-2007, 04:09
Anyone know a reliable Detroit Diesel shop in New Orleans?
Scott Forman 86 PT38 In New Orleans with issues |
10-27-2007, 13:01
if the repair need involve electric / electronic, the uncommon element
between rv and class 8 is the charging ;house batterys ;inverters ;and relay/solenoids that suck juice while at rest . GregoryO'Connor 94pt In Romoland with issues, but the bus runs good --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Anyone know a reliable Detroit Diesel shop in New Orleans? > > Scott Forman > 86 PT38 > In New Orleans with issues > |
10-27-2007, 13:35
Scott,
I sent you some contact information direct to your email address this morning shortly after your post. I see that it bounced back with an "out of office" message, so I don't know if you got it. If not, look in the WanderlodgeForum database for Wanderoad Assistance. There are two members in Louisiana in there with phone numbers listed. The Memeber-To-Member database has four members in the New Orleans neighborhood listed there also. Good luck and keep us posted with what's wrong and the resolution. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Anyone know a reliable Detroit Diesel shop in New Orleans? > > Scott Forman > 86 PT38 > In New Orleans with issues > |
10-28-2007, 11:22
I made it home. I appear to have a leaky injector or something
similar. Indication of a problem was that when I checked my oil after driving from Memphis to New Orleans (400 mi), my oil level had actually risen. When I called my mechanic, he told me that leaks in the fuel system under the valve covers are fairly common on the 8v92. He told me to get an oil change, fill to 'L' on the dipstick, and check the level every 100 mi. If it rose slowly, I am ok, it it rose very quickly, I would need to have it addressed on the road lest I get my oil too far diluted and cause internal damage. Found 24HR service at a Travel Center America in Slidell, LA, and got an oil change at 8:00 this morning. Oil level did not rise much on the drive home. Problem can now be looked at by my mechanic that I trust. Scott Forman 86 PT38 Safely home in Memphis --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Scott, > > I sent you some contact information direct to your email address this > morning shortly after your post. I see that it bounced back with an > "out of office" message, so I don't know if you got it. If not, look > in the WanderlodgeForum database for Wanderoad Assistance. There are > two members in Louisiana in there with phone numbers listed. The > Memeber-To-Member database has four members in the New Orleans > neighborhood listed there also. > > Good luck and keep us posted with what's wrong and the resolution. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > Anyone know a reliable Detroit Diesel shop in New Orleans? > > > > Scott Forman > > 86 PT38 > > In New Orleans with issues > > > |
10-28-2007, 13:01
Glad you made it home safely Scott! I would prefer a local guy over
road service also and it is good that you had a choice. Let us know what you find please for the learning benefit of us other 8V owners. ;^) Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX |
10-29-2007, 04:24
Pissing injectors show up with eye watering exhaust and performance
issues. A leaky injector at rest that pisses on the piston can bend the piston rod or lock the engine from turning over. With a tank full, sometimes a leak in the return lines under the valve covers will leak even with the engine shut down. You may be able to remove the return line to the tank and pressurize it with 5 psi and see if it maintaines pressure. Finding the leak is better than a once over wrenching of all the old steel lines. I dress the metal mating surfaces in 90 wt oil before reinstalling. some times the lines are installed too twisted and the line is always trying to untwist the nut. if it cracked, the line metal became too brittle for the 22year old installed twist. I am not sure how the 8v is setup under the valve cover????? Water in the oil would have showed up milkey white and one gallon of water will froth up to 4 gallons. In a Duramax with the same issue, I dumped two gallons of oil out of the crank case every day and added fresh oil without changing the filter. I put the old oil in the fuel tank and ran it until Chevy had time to find the failure. (the truck had a seeder mounted and shop sitting was not an option) GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > I made it home. I appear to have a leaky injector or something > similar. Indication of a problem was that when I checked my oil > after driving from Memphis to New Orleans (400 mi), my oil level had > actually risen. When I called my mechanic, he told me that leaks in > the fuel system under the valve covers are fairly common on the > 8v92. He told me to get an oil change, fill to 'L' on the dipstick, > and check the level every 100 mi. If it rose slowly, I am ok, it it > rose very quickly, I would need to have it addressed on the road lest > I get my oil too far diluted and cause internal damage. > > Found 24HR service at a Travel Center America in Slidell, LA, and > got an oil change at 8:00 this morning. Oil level did not rise much > on the drive home. Problem can now be looked at by my mechanic that > I trust. > > Scott Forman > 86 PT38 > Safely home in Memphis > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > wrote: > > > > Scott, > > > > I sent you some contact information direct to your email address > this > > morning shortly after your post. I see that it bounced back with an > > "out of office" message, so I don't know if you got it. If not, > look > > in the WanderlodgeForum database for Wanderoad Assistance. There > are > > two members in Louisiana in there with phone numbers listed. The > > Memeber-To-Member database has four members in the New Orleans > > neighborhood listed there also. > > > > Good luck and keep us posted with what's wrong and the resolution. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > > wrote: > > > > > > Anyone know a reliable Detroit Diesel shop in New Orleans? > > > > > > Scott Forman > > > 86 PT38 > > > In New Orleans with issues > > > > > > |
10-29-2007, 09:56
My system will be pressurized to find the problem.
--- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Pissing injectors show up with eye watering exhaust and performance > issues. A leaky injector at rest that pisses on the piston can bend > the piston rod or lock the engine from turning over. > > With a tank full, sometimes a leak in the return lines under the > valve covers will leak even with the engine shut down. You may be > able to remove the return line to the tank and pressurize it with 5 > psi and see if it maintaines pressure. Finding the leak is better > than a once over wrenching of all the old steel lines. I dress the > metal mating surfaces in 90 wt oil before reinstalling. some times > the lines are installed too twisted and the line is always trying to > untwist the nut. if it cracked, the line metal became too brittle for > the 22year old installed twist. I am not sure how the 8v is setup > under the valve cover????? > > Water in the oil would have showed up milkey white and one gallon of > water will froth up to 4 gallons. > > In a Duramax with the same issue, I dumped two gallons of oil out of > the crank case every day and added fresh oil without changing the > filter. I put the old oil in the fuel tank and ran it until Chevy had > time to find the failure. (the truck had a seeder mounted and shop > sitting was not an option) > > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > <sforman@> wrote: > > > > I made it home. I appear to have a leaky injector or something > > similar. Indication of a problem was that when I checked my oil > > after driving from Memphis to New Orleans (400 mi), my oil level > had > > actually risen. When I called my mechanic, he told me that leaks > in > > the fuel system under the valve covers are fairly common on the > > 8v92. He told me to get an oil change, fill to 'L' on the > dipstick, > > and check the level every 100 mi. If it rose slowly, I am ok, it > it > > rose very quickly, I would need to have it addressed on the road > lest > > I get my oil too far diluted and cause internal damage. > > > > Found 24HR service at a Travel Center America in Slidell, LA, and > > got an oil change at 8:00 this morning. Oil level did not rise > much > > on the drive home. Problem can now be looked at by my mechanic > that > > I trust. > > > > Scott Forman > > 86 PT38 > > Safely home in Memphis > > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > > wrote: > > > > > > Scott, > > > > > > I sent you some contact information direct to your email address > > this > > > morning shortly after your post. I see that it bounced back with > an > > > "out of office" message, so I don't know if you got it. If not, > > look > > > in the WanderlodgeForum database for Wanderoad Assistance. There > > are > > > two members in Louisiana in there with phone numbers listed. The > > > Memeber-To-Member database has four members in the New Orleans > > > neighborhood listed there also. > > > > > > Good luck and keep us posted with what's wrong and the resolution. > > > > > > Mike Bulriss > > > 1991 WB40 "Texas Minivan" > > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > > > wrote: > > > > > > > > Anyone know a reliable Detroit Diesel shop in New Orleans? > > > > > > > > Scott Forman > > > > 86 PT38 > > > > In New Orleans with issues > > > > > > > > > > |
