Air Suspension Will Not Inflate
11-02-2007, 00:04
Could be that the thirty degree mark is a clue. Frozen moisture in the air
valve? Steve Anderson 79FC35 In a message dated 11/2/2007 7:58:05 AM Pacific Daylight Time, rlf47@... writes: Good morning Bob: That switch controls a valve in the front load center for suspension dump. May need to check the connection to that solenoid valve. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 02:42 PM 11/2/2007 +0000, you wrote: >This morning I had an appointment to have my coach worked on. >Temperature here this AM was 30 degrees. Coach started fine--up came >the air pressure so I hit the "UP" button on the dash and nothing >happened. This is a first! Traced the air lines on the diagram and >the air throttle shares the air source directly with the air supply for >the front and rear air rear bags. Air throttle works fine. Checked >the dash switch and it is operating and has 12V. Since the front and >rar air bags have separate lines what is the chance they are both >frozen? Water in the coach is not frozen. I am scratching my head >here so can anyone help? Coach does not have automatic leveling. By >the way it is 45 degrees at 10:41AM. > >Bob Criss >Pittsburgh >1990SP36 ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
11-02-2007, 03:42
Temperature here this AM was 30 degrees. Coach started fine--up came the air pressure so I hit the "UP" button on the dash and nothing happened. This is a first! Traced the air lines on the diagram and the air throttle shares the air source directly with the air supply for the front and rear air rear bags. Air throttle works fine. Checked the dash switch and it is operating and has 12V. Since the front and rar air bags have separate lines what is the chance they are both frozen? Water in the coach is not frozen. I am scratching my head here so can anyone help? Coach does not have automatic leveling. By the way it is 45 degrees at 10:41AM. Bob Criss Pittsburgh 1990SP36 |
11-02-2007, 04:57
Good morning Bob:
That switch controls a valve in the front load center for suspension dump. May need to check the connection to that solenoid valve. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 02:42 PM 11/2/2007 +0000, you wrote: >This morning I had an appointment to have my coach worked on. >Temperature here this AM was 30 degrees. Coach started fine--up came >the air pressure so I hit the "UP" button on the dash and nothing >happened. This is a first! Traced the air lines on the diagram and >the air throttle shares the air source directly with the air supply for >the front and rear air rear bags. Air throttle works fine. Checked >the dash switch and it is operating and has 12V. Since the front and >rar air bags have separate lines what is the chance they are both >frozen? Water in the coach is not frozen. I am scratching my head >here so can anyone help? Coach does not have automatic leveling. By >the way it is 45 degrees at 10:41AM. > >Bob Criss >Pittsburgh >1990SP36 |
11-02-2007, 12:50
Juergen I guess we have a triangle of SP's in this area. 89 90 & 91
Butler Beaver & Pittsburgh & I haven't done anything about my air bags yet. Don 89 SP 36' Butler, PA I had that happen to me once. Took several tries with suspension dump switch. I got it finally up enough to get to the BB place on Route 8 in Mars, and they fond the front leveling valve was about shot with dirt and corrosion. Where about in the Burgh do you live? I live in Beaver PA Juergen in PA 1991 WLSP 36 crissrace <_crissrace@..._ (mailto:crissrace@...) > wrote: This morning I had an appointment to have my coach worked on. Temperature here this AM was 30 degrees. Coach started fine--up came the air pressure so I hit the "UP" button on the dash and nothing happened. This is a first! Traced the air lines on the diagram and the air throttle shares the air source directly with the air supply for the front and rear air rear bags. Air throttle works fine. Checked the dash switch and it is operating and has 12V. Since the front and rar air bags have separate lines what is the chance they are both frozen? Water in the coach is not frozen. I am scratching my head here so can anyone help? Coach does not have automatic leveling. By the way it is 45 degrees at 10:41AM. Bob Criss Pittsburgh 1990SP36 ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
11-02-2007, 16:06
Hi Bob
I had that happen to me once. Took several tries with suspension dump switch. I got it finally up enough to get to the BB place on Route 8 in Mars, and they fond the front leveling valve was about shot with dirt and corrosion. Where about in the Burgh do you live? I live in Beaver PA Juergen in PA 1991 WLSP 36 crissrace morning I had an appointment to have my coach worked on. Temperature here this AM was 30 degrees. Coach started fine--up came the air pressure so I hit the "UP" button on the dash and nothing happened. This is a first! Traced the air lines on the diagram and the air throttle shares the air source directly with the air supply for the front and rear air rear bags. Air throttle works fine. Checked the dash switch and it is operating and has 12V. Since the front and rar air bags have separate lines what is the chance they are both frozen? Water in the coach is not frozen. I am scratching my head here so can anyone help? Coach does not have automatic leveling. By the way it is 45 degrees at 10:41AM. Bob Criss Pittsburgh 1990SP36 __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
11-03-2007, 01:54
Thanks Bob That's good to know on the air valve in the front I'll check
that out on mine to see if that is the way it works. Mine are Clippard valves. There is a place I can get them in Pittsburgh. Don 89 SP 36' Butler, PA We do indeed have a triangle as I actually live in Bethel Park which is 10 miles south of Pittsburgh. My coach can often be found at Beaverun race course in Beaver (of course) as we race both cars and karts (grandchildren)k The suspension finally came up. I called Glen Rogers and he advised, after it was warm enough to discount the frozen air line, to check the "Allen Air Valve" in the front under the windshield. #4 is the valve that controls the suspension dump and, contrary to what you might expect, the application of air is what keeps the coach down?? In order to let it come up the little yellow Allen air valve must expel air and -- up it comes. Glen said they had been replacing them frequently lately. I just wiggled the lines and mine expelled air and presto, up it came. Thanks to Glen I am on the road again. I sure do miss Benny though. What a waste of knowledge. Bob Criss 1990 SP36 Bethel Park, PA --- In _WanderlodgeForum@WanderlodgeFWan_ (mailto:WanderlodgeForum@yahoogroups.com) , dspithaler@., dsp > > > Juergen I guess we have a triangle of SP's in this area. 89 90 & 91 > Butler Beaver & Pittsburgh & I haven't done anything about my air bags > yet. > Don > 89 SP 36' > Butler, PA > > I had that happen to me once. Took several tries with suspension dump > switch. I got it finally up enough to get to the BB place on Route 8 in Mars, and > they fond the front leveling valve was about shot with dirt and corrosion. > Where ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
11-03-2007, 03:17
is 10 miles south of Pittsburgh. My coach can often be found at Beaverun race course in Beaver (of course) as we race both cars and karts (grandchildren). The suspension finally came up. I called Glen Rogers and he advised, after it was warm enough to discount the frozen air line, to check the "Allen Air Valve" in the front under the windshield. #4 is the valve that controls the suspension dump and, contrary to what you might expect, the application of air is what keeps the coach down?? In order to let it come up the little yellow Allen air valve must expel air and -- up it comes. Glen said they had been replacing them frequently lately. I just wiggled the lines and mine expelled air and presto, up it came. Thanks to Glen I am on the road again. I sure do miss Benny though. What a waste of knowledge. Bob Criss 1990 SP36 Bethel Park, PA --- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > > Juergen I guess we have a triangle of SP's in this area. 89 90 & 91 > Butler Beaver & Pittsburgh & I haven't done anything about my air bags > yet. > Don > 89 SP 36' > Butler, PA > > I had that happen to me once. Took several tries with suspension dump > switch. I got it finally up enough to get to the BB place on Route 8 in Mars, and > they fond the front leveling valve was about shot with dirt and corrosion. > Where about in the Burgh do you live? I live in Beaver PA > Juergen in PA > 1991 WLSP 36 > > crissrace <_crissrace@..._ (mailto:crissrace@...) > wrote: This > morning I had an appointment to have my coach worked on. > Temperature here this AM was 30 degrees. Coach started fine--up came > the air pressure so I hit the "UP" button on the dash and nothing > happened. This is a first! Traced the air lines on the diagram and > the air throttle shares the air source directly with the air supply for > the front and rear air rear bags. Air throttle works fine. Checked > the dash switch and it is operating and has 12V. Since the front and > rar air bags have separate lines what is the chance they are both > frozen? Water in the coach is not frozen. I am scratching my head > here so can anyone help? Coach does not have automatic leveling. By > the way it is 45 degrees at 10:41AM. > > Bob Criss > Pittsburgh > 1990SP36 > > > > > > > > > ************************************** See what's new at http://www.aol.com > > > [Non-text portions of this message have been removed] > |
11-03-2007, 09:48
That's what I was wandering too without getting into extras how much the
basic's changed from one year to the next. I know on the ext. mine still has the black rubber around the wheel wells & it doesn't have the same front end as yours. I'm going to air mine up tomorrow & see which Clippard valve in the front activates my suspension dump. You can get those valves in Pittsburgh if you ever need any. Have you gone underground with yours yet? Don 89 SP 36' Butler, PA Hi Don Your are right about the triangle of SP's here. Now comes the big q uestion. How much difference is there between each coach ?It would be fun to be able and compare notes on that one. Juergen in PA 1991 WLSP 36 ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
11-03-2007, 11:48
Hi Don
Your are right about the triangle of SP's here. Now comes the big q uestion. How much difference is there between each coach ?It would be fun to be able and compare notes on that one. Juergen in PA 1991 WLSP 36 dspithaler@... wrote: Juergen I guess we have a triangle of SP's in this area. 89 90 & 91 Butler Beaver & Pittsburgh & I haven't done anything about my air bags yet. Don 89 SP 36' Butler, PA I had that happen to me once. Took several tries with suspension dump switch. I got it finally up enough to get to the BB place on Route 8 in Mars, and they fond the front leveling valve was about shot with dirt and corrosion. Where about in the Burgh do you live? I live in Beaver PA Juergen in PA 1991 WLSP 36 crissrace <_crissrace@..._ (mailto:crissrace@...) > wrote: This morning I had an appointment to have my coach worked on. Temperature here this AM was 30 degrees. Coach started fine--up came the air pressure so I hit the "UP" button on the dash and nothing happened. This is a first! Traced the air lines on the diagram and the air throttle shares the air source directly with the air supply for the front and rear air rear bags. Air throttle works fine. Checked the dash switch and it is operating and has 12V. Since the front and rar air bags have separate lines what is the chance they are both frozen? Water in the coach is not frozen. I am scratching my head here so can anyone help? Coach does not have automatic leveling. By the way it is 45 degrees at 10:41AM. Bob Criss Pittsburgh 1990SP36 ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
11-04-2007, 05:10
Hi Don
No I have not. My coach is in Vollmers repairshop undergoing an analysis of why the coach settles slowly to the left front. It takes about a day to go from normal level to left front low. We cannot locate any leaks yet, but there must be one somewhere, since the auxilarry air compressor comes on every 4-5 hours for about 5 minutes. I kind of suspect the airbags itself having a slow leak. GENERAL QUESTION... has anyone ever removed an airbag and if so, is it a large complicated procedure or a PITA type. I figured that if the airbag has a leak somewhere, air bubbles should show the hole. Any suggestions/ advice would be greatly appreciated. Juergen in PA 1991 WLSP 36 dspithaler@... wrote: That's what I was wandering too without getting into extras how much the basic's changed from one year to the next. I know on the ext. mine still has the black rubber around the wheel wells & it doesn't have the same front end as yours. I'm going to air mine up tomorrow & see which Clippard valve in the front activates my suspension dump. You can get those valves in Pittsburgh if you ever need any. Have you gone underground with yours yet? Don 89 SP 36' Butler, PA Hi Don Your are right about the triangle of SP's here. Now comes the big q uestion. How much difference is there between each coach ?It would be fun to be able and compare notes on that one. Juergen in PA 1991 WLSP 36 ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
