crash down in the middle of the night!
11-11-2007, 05:09
Hi group,
been home 2 nights, last night in the middle of a deep sleep (I still
sleep in the coach when we are home as my daughter is taking care of
the homefront and has my room in the house)..
I was awakened by a crash and things falling...
I had both back levelers up to level the coach on a slight incline.
When I went out and looked the levelers were actually under the coach
in the wrong direction....I started her up, let the air build and then
retracted the levelers. They went back up fine, phew! Don't know why
everything had shifted back, the air brake was set etc....guess maybe
I had them too high? I put them back down but it appeared the LR one
was at slight angle forward so I put them back up for the night.
Haven't got around to putting them down as I will likely move the
coach to a different park spot for the couple weeks we will be home.
Anyone had this experience?
Thanks
Rose Mary
82 FC 35
JP's White Bird
at home in Oregon for Thanksgiving
11-11-2007, 06:04
The air brake only sets the rear brakes. If you have the rear jacks
set and lift the rear wheels while on an incline there is nothing to
keep the coach from rolling.
Robert Britton
87FC
Hollister, California
--- In WanderlodgeForum@yahoogroups.com, "Rose Mary"
> Hi group,
still
coach
then
maybe
> Thanks
> Rose Mary
> 82 FC 35
> JP's White Bird
11-11-2007, 06:16
+1 on that answer.
It's happened to lots of folks. That's why many use wheel chocks also.
Hopefully you didn't bend any of the jacks. :^(
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "Robert Britton"
> Robert Britton
> 87FC
> > Hi group,
> still
> coach
> then
> maybe
> > Thanks
> > Rose Mary
> > 82 FC 35
> > JP's White Bird
11-11-2007, 06:36
Hi Rose Mary,
Don't feel bad as I have done the same thing to our bus.
In my case, I tried lifting the bus after we first got her to see if
I could lift the entire bus off the ground with just the jacks..a guy
thing...anyway, she lifted up, stayed ok for about 1 minute, then
fell forward off the jacks. What a crash!!
Since the front jacks swivel back, no problem..the back jacks are on
a swivel bolt and swiveled back and the right rear pulled off the
fluid hose. Only damage done. Had a new hose made, simple repair.
If your hose is still attached to jack and it goes down without a
leak, you got lucky.
You would need wheel chocks to use on the front tires if you are on
another incline so this doesn't happen again.
Back wheels off the ground equals no brakes on the ground.
Bob Lawrence
84 PT36
Fulltiming presently in Fernley Nv (outside of Reno)
> Hi group,
still
coach
then
maybe
> Thanks
> Rose Mary
> 82 FC 35
> JP's White Bird
11-11-2007, 07:35
If the rear wheels were off the ground, there's no parking brake
holding you from moving. If that was the case, but wheel chocks under
the front wheels. A good idea in any event.
Pete Masterson
aeonix1@...
On the road at Lockhart Texas
On Nov 11, 2007, at 11:09 AM, Rose Mary wrote:
> Hi group,
> Thanks
> Rose Mary
> 82 FC 35
> JP's White Bird
11-11-2007, 08:53
Yup, that's what killed the dead guy who's widow I bought my first FC from. Had
brandy new rear jacks, I suspect he figgered he was good to go on workin' under
the bus. His body was the wheel chock he shoulda used, rear dual got him as it
rolled forward. Guess he figured the front brakes locked when the parking brake
set.
MH
Sent: Sunday, November 11, 2007 12:04 PM
Subject: [WanderlodgeForum] Re: crash down in the middle of the night!
Robert Britton
87FC
> Hi group,
still
coach
then
maybe
> Thanks
> Rose Mary
> 82 FC 35
> JP's White Bird
11-11-2007, 09:09
Mike,
That story about the prior owner of your coach makes me cringe every
time you mention it! It also justifies my wooden ramps, wheel chocks,
two extra 20 ton hydraulic jacks and two 20 ton jack stands. I've had
friends ask me why I carry all that 'crap' and it takes me a while to
position everything before I crawl under there, but I don't care, I'm
coming back out on my own!
FC from. Had brandy new rear jacks, I suspect he figgered he was good
to go on workin' under the bus. His body was the wheel chock he
shoulda used, rear dual got him as it rolled forward. Guess he
figured the front brakes locked when the parking brake set.
> MH
> From: Robert Britton
> Robert Britton
> 87FC
> > Hi group,
> still
> coach
> then
> maybe
> > Thanks
> > Rose Mary
> > 82 FC 35
> > JP's White Bird
11-11-2007, 09:31
> Mike,
chocks,
had
to
I'm
> Mike Bulriss
> San Antonio, TX
good
> > MH
night!
jacks
nothing to
> > Robert Britton
> > 87FC
> > wrote:
> > > Hi group,
(I
> > still
care of
incline.
> > coach
> > then
know why
etc....guess
> > maybe
LR one
night.
be home.
> > > Thanks
> > > Rose Mary
> > > 82 FC 35
> > > JP's White Bird
Thanks for that info on the leveling jacks! I don't have those but
it was interesting to find out only the back brakes are locked in
place when you shut down the coach.
Jipjob
78 Wanderlodge
11-11-2007, 11:09
Back in the early 90's we were camped in florissant,Wy.(terrible
campground-lots of rocks) we were in our 85pt-40 and had the same
thing happen the left rear slipped and the jack flipped up and
knocked the return spring off. We were on our way back to Illinois
so made a trip back via way of Moscow,Iowa (HWH) Paul had a mechanic
from the shop come out and reinstall the spring, Really big pry bars
we were glad we stopped as they knew the technique to get it done...
When in doubt we always use the wheel chocks NOW.....Bob 93pt40..Il.
s
> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@>
> > Mike,
every
> chocks,
I've
> had
while
> to
> I'm
> > Mike Bulriss
> > San Antonio, TX
first
> good
> > > MH
> night!
> jacks
> nothing to
> > > Robert Britton
> > > 87FC
> > > wrote:
> > > > Hi group,
sleep
> (I
> > > still
taking
> care of
> incline.
> the
> > > coach
build
> and
> > > then
> know why
> etc....guess
> > > maybe
> LR one
> night.
move
> the
> be home.
> > > > Thanks
> > > > Rose Mary
> > > > 82 FC 35
> > > > JP's White Bird
> Jipjob
> 78 Wanderlodge
11-11-2007, 13:13
I've had it happen to me also. In my case a fitting broke off at the
jack and fluid was everywhere. I had to remove the jack to e-z out
the fitting.
FWIW the coach was on what I would consider relatively flat ground. I
had wheel chocks front and back of one front wheel. I had these wheel
chocks
http://www.northerntool.com/webapp/wcs/s...t_6970_137
76_13776
After the big fall the front tire was actually on top of, squishing
the wheel chock. I wish I had taken a photo, but I was too upset.
The next day I ordered the chocks John Finn recommended!
Tom Sorrentino
1987 PT38
Bedford Hills, NY
> Hi group,
still
coach
then
maybe
> Thanks
> Rose Mary
> 82 FC 35
> JP's White Bird
