Questions for 93 Wanderlodge owners
11-21-2007, 03:19
Hi all, I have been looking at the 93 at Parliament and was hoping that
someone could help me out. Do the air vents above the driver and passenger, below the instrument panel, blow A/C air or just cabin air? How many, and what type of house batteries came stock. Also does the Primis heat system heat the domestic hot water heater and if so does it work well? And finally are there any common weaknesses in the 93 models? Thanks Marty Gregg 95 BMC 37 Kennewick WA |
11-21-2007, 04:19
The upper vents are on the coach A/C. You can install a switch in
that circuit to disable the A/C clutch and use them just as a fan on cool days when AC is not needed. I opted to install a 12V fan on each side that can be used when the coach is parked instead. There are also a set of vents at knee level on both sides. This is the coach heater vents, and you can also open the outside fresh air vent which pulls air from below the front bumper via the dash switch if you just want outside air. My coach came with 8 GEL Cells, I have seen other configs as well. My 8 new AGM's just came in today, so will be converting over to AGM this eek. The Primus can heat the domestic hot water. You control it from the front Primus control panel by pressing the button right next to the on button. You must have the summer/winter valve in the summer mode because when you press that button it changes what temp sensor it uses to control the primus. Normally it would use the temp probe located in the kitchen area to control internal temp, but when you select hot water it uses the hot water heater temp probe to tell the primus to cut on or off. So it should be in summer mode to do it. And yes, it makes the water plenty hot for my taste. You can not get a better coach than a BB, and I have owned SOB's in the past. Michael Brundridge 1992 WB40 Georgetown, TX --- In WanderlodgeForum@yahoogroups.com, "martingregg598" > > Hi all, I have been looking at the 93 at Parliament and was hoping that > someone could help me out. Do the air vents above the driver and > passenger, below the instrument panel, blow A/C air or just cabin air? > How many, and what type of house batteries came stock. Also does the > Primis heat system heat the domestic hot water heater and if so does it > work well? And finally are there any common weaknesses in the 93 > models? Thanks > Marty Gregg > 95 BMC 37 > Kennewick WA > |
11-21-2007, 05:16
Thanks Michael, are the 8 batteries group-31 or 27? Are they in 4 and 4
trays? Are they 12 volt? Are the 1992 and 1993 coach's systems mostly the same? Marty Gregg 95 BMC 37 Kennewick WA |
11-21-2007, 07:38
Mine are Group 31 configed in two banks of 4 batteries each, one
slide tray ontop of the other. All all cabled to the same lug behind the battery slide out tray. The BB use a 12 volt system, not a 24 volt like some other SOB's. So all the batteries are connected postitive to positive and negative to negative. There are very little differences between the 92 and 93. Michael Brundridge 1992 WB40 Georgetown, TX --- In WanderlodgeForum@yahoogroups.com, "martingregg598" > > Thanks Michael, are the 8 batteries group-31 or 27? Are they in 4 and 4 > trays? Are they 12 volt? Are the 1992 and 1993 coach's systems mostly > the same? > Marty Gregg > 95 BMC 37 > Kennewick WA > |
11-21-2007, 09:17
Marty,
I have a 91. Randy Dupree of this forum has a 93 however on mine air on top vents, house heat or fresh air on botton. Primus heats water. will also allow you to heat water from engine heat. if you dont have documentation hollar. Mark Dexter of Mardex sold them. Steve Birttles of this forum has parts and can advise. It may take a tad of work to get them right however Chuck Hallem, a long time engineer with BB advised me to keep it. His opinion is that is was one of the best systems out there. Usually the only problems are replacing bad pumps (I think there are 3) and it is a wonderful heat. john redden 91pt40 **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-product...0000000001) [Non-text portions of this message have been removed] |
11-21-2007, 16:39
Marty:
I have a 93 PT40 WBWL. Top vents are only AC, if it is even working, as the system used the old freon. Bottom vents are heater, or outside air. My coach has the group 31, 8 batteries for coach, and 3 more starting batteries. The group 31 are 4 in top tray, and 4 in bottome tray. Original systems had 2 battery chargers, but most have been replaced with single units that can charge gels, wet, or AGM batteries. The Primus system does not heat the domestic water. The engine can heat the water while on the road, but the water heater is electric. I do not think there are any weakness' in the unit. The only prior weakness was the Primus system, as there was no support. This has changed with Stephen Brittles helping us out with problems with these units. I have had my unit for 5 years. Ofcourse as the years get on, preventative maint gets to be a concern. Like alternators (most never fix belts or alternators on the front of the engine) , belts, the cooling hose to the compressor, and radiator replacement. As you can see these are items mostly related to engine compartment. Hope this helps, Parliment is a good outfit. I have had my unit serviced and body shop repairs done with great satisfaction. William Jensen 1993 PT40 WBWL "Maudi" Deerfield Beach, Florida --- In WanderlodgeForum@yahoogroups.com, "martingregg598" > > Hi all, I have been looking at the 93 at Parliament and was hoping that > someone could help me out. Do the air vents above the driver and > passenger, below the instrument panel, blow A/C air or just cabin air? > How many, and what type of house batteries came stock. Also does the > Primis heat system heat the domestic hot water heater and if so does it > work well? And finally are there any common weaknesses in the 93 > models? Thanks > Marty Gregg > 95 BMC 37 > Kennewick WA > |
11-21-2007, 18:45
William,
In the 1992 model the Primus does heat the dometic water. Are you sure that it does not in the 1993? It requires that the front drivers Primus control have the Hot Water button depressed, and the summer/winter valve be in summer mode. Mine heats the water plenty good, just tested it the other day in prep for out thanksgiving trip. Michael Brundridge 1992 WB40 Georgetown, TX --- In WanderlodgeForum@yahoogroups.com, "William Jensen" > > > Marty: > > I have a 93 PT40 WBWL. Top vents are only AC, if it is even working, > as the system used the old freon. Bottom vents are heater, or outside > air. > > My coach has the group 31, 8 batteries for coach, and 3 more starting > batteries. The group 31 are 4 in top tray, and 4 in bottome tray. > Original systems had 2 battery chargers, but most have been replaced > with single units that can charge gels, wet, or AGM batteries. > > The Primus system does not heat the domestic water. The engine can > heat the water while on the road, but the water heater is electric. > > I do not think there are any weakness' in the unit. The only prior > weakness was the Primus system, as there was no support. This has > changed with Stephen Brittles helping us out with problems with these > units. I have had my unit for 5 years. > > Ofcourse as the years get on, preventative maint gets to be a > concern. Like alternators (most never fix belts or alternators on the > front of the engine) , belts, the cooling hose to the compressor, and > radiator replacement. As you can see these are items mostly related > to engine compartment. > > Hope this helps, Parliment is a good outfit. I have had my unit > serviced and body shop repairs done with great satisfaction. > > William Jensen > 1993 PT40 WBWL "Maudi" > Deerfield Beach, Florida > > > --- In WanderlodgeForum@yahoogroups.com, "martingregg598" > > > > > Hi all, I have been looking at the 93 at Parliament and was hoping > that > > someone could help me out. Do the air vents above the driver and > > passenger, below the instrument panel, blow A/C air or just cabin > air? > > How many, and what type of house batteries came stock. Also does the > > Primis heat system heat the domestic hot water heater and if so does > it > > work well? And finally are there any common weaknesses in the 93 > > models? Thanks > > Marty Gregg > > 95 BMC 37 > > Kennewick WA > > > |
11-22-2007, 02:17
Michael,
You are right. I have a 93 (For Sale) and the Primus does heat the water and does it well. Switch in overhead has to be in summer position if you want water heating only. During winter, it heats both the drivers side of the coach and the water. Tommy Standard 1993 PT40 WBWL "With a Glo" Dadeville, AL [Non-text portions of this message have been removed] |
