High pressure connection on power steering
11-28-2007, 08:28
Is it possable to disconnect and reconnect the high pressure
connection on an FC from the access panel in the floor. I need to do it tonight to have a new hose made up. I got a new power steering pump but the connection is not the same. The cost of shipping will far exceed a new hose, and a new hose is a good idea anyway. From lookiang at the pictures in the phot section it seems possible, but probably a real pain. Gardner 78FC33 |
11-28-2007, 08:42
Pull the battery box, then you can actually see the steering box.
MH ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, November 28, 2007 2:28 PM Subject: [WanderlodgeForum] High pressure connection on power steering Is it possable to disconnect and reconnect the high pressure connection on an FC from the access panel in the floor. I need to do it tonight to have a new hose made up. I got a new power steering pump but the connection is not the same. The cost of shipping will far exceed a new hose, and a new hose is a good idea anyway. From lookiang at the pictures in the phot section it seems possible, but probably a real pain. Gardner 78FC33 [Non-text portions of this message have been removed] |
11-28-2007, 14:45
I took off all the stuff around the steering column and the fitting
was right there. I could never have reached it through the battery box because it is just even with the floor and there would be no way to swing a wrench. Who ever tightened it up was on a power trip. It took every trick in the book and a trip to Sears for a longer 1 inch open end wrench to break it loose. Even then I had to use a pry bar against the wrench while pulling with all my might. It's off now and I will be going to the hose maker in the morning to get a new one made up. I got the new pulley on the new pump, then took the new pulley off the new pump so I could get the bolts out to mount the bracket. Then I put the new pulley back on. As I always say, plan ahead. Now if I could just stop saying it and do it! Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Pull the battery box, then you can actually see the steering box. > MH > ----- Original Message ----- > From: Gardner Yeaw > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, November 28, 2007 2:28 PM > Subject: [WanderlodgeForum] High pressure connection on power steering > > > Is it possable to disconnect and reconnect the high pressure > connection on an FC from the access panel in the floor. I need to do it > tonight to have a new hose made up. I got a new power steering pump but > the connection is not the same. The cost of shipping will far exceed a > new hose, and a new hose is a good idea anyway. > From lookiang at the pictures in the phot section it seems possible, > but probably a real pain. > > Gardner > 78FC33 > > > > > > [Non-text portions of this message have been removed] > |
11-28-2007, 15:02
Gardner,
Seems your doing fine. Don't stop. It's a learning process... On Nov 28, 2007 6:45 PM, Gardner Yeaw > I took off all the stuff around the steering column and the fitting > was right there. I could never have reached it through the battery > box because it is just even with the floor and there would be no way > to swing a wrench. Who ever tightened it up was on a power trip. It > took every trick in the book and a trip to Sears for a longer 1 inch > open end wrench to break it loose. Even then I had to use a pry bar > against the wrench while pulling with all my might. > > It's off now and I will be going to the hose maker in the morning to > get a new one made up. > > I got the new pulley on the new pump, then took the new pulley > off the new pump so I could get the bolts out to mount the bracket. > Then I put the new pulley back on. As I always say, plan ahead. Now > if I could just stop saying it and do it! > > Gardner > 78FC33 > > --- In WanderlodgeForum@yahoogroups.com > "Mike Hohnstein" > <MHOHNSTEIN@...> wrote: > > > > Pull the battery box, then you can actually see the steering box. > > MH > > ----- Original Message ----- > > From: Gardner Yeaw > > To: WanderlodgeForum@yahoogroups.com > > Sent: Wednesday, November 28, 2007 2:28 PM > > Subject: [WanderlodgeForum] High pressure connection on power > steering > > > > > > Is it possable to disconnect and reconnect the high pressure > > connection on an FC from the access panel in the floor. I need > to do it > > tonight to have a new hose made up. I got a new power steering > pump but > > the connection is not the same. The cost of shipping will far > exceed a > > new hose, and a new hose is a good idea anyway. > > From lookiang at the pictures in the phot section it seems > possible, > > but probably a real pain. > > > > Gardner > > 78FC33 > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
11-29-2007, 02:34
Gardner:
Just a heads up. When I replaced the return hose for my PS thru those same access panels at the steering column, I found it was necessary to use two people. The person below was needed to hold the hose at the correct angle to thread into the steering box and the person above turned the nut on the hose or box. I tried for quite a while to do it myself in the storage lot until I finally collared a fellow RV'er at the lot to help me for 10 minutes. Kerry 82 FC 35 Denver ________________________________________________________________________________\ ____ Be a better sports nut! Let your teams follow you with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_...QtBI7ntAcJ |
11-29-2007, 10:33
Hello,
On the subject of hose replacement - I am planning on replacing transmission cooler hoses on our 83 FC 35 this weekend. The upper one is leaking at the tranny connection. The coach has less than 75K on it and I'm pretty sure these are original hoses. From what I read, its probably a good Idea to change these out because of their age. Weather permitting (its getting cold up here), we will do this outside on the ground. One of the hoses connects on an angle near the top of the tranny just above the PTO cover. This is a tough spot to get to from below. After reading about the floor assess for the PS I am wondering if there is an access panel from above to get to this tranny cooler hose? If it has to be done from below are there any tips on doing this that might ease the pain? Thanks- Bill in NH 1983 FC SB --- In WanderlodgeForum@yahoogroups.com, david edwards wrote: > > Gardner: > Just a heads up. When I replaced the return hose for > my PS thru those same access panels at the steering > column, I found it was necessary to use two people. > The person below was needed to hold the hose at the > correct angle to thread into the steering box and the > person above turned the nut on the hose or box. > I tried for quite a while to do it myself in the > storage lot until I finally collared a fellow RV'er at > the lot to help me for 10 minutes. > > Kerry > 82 FC 35 > Denver > > > ________________________________________________________________________________\ ____ > Be a better sports nut! Let your teams follow you > with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_...QtBI7ntAcJ > |
11-29-2007, 11:05
1/2" drive crows foot will work occasionally. Hard tool to find, probably
Snap-on $$$. Pulling the engine cover makes it very accessible. Never easy workin' on a bird. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: William To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 29, 2007 4:33 PM Subject: [WanderlodgeForum] Re:High pressure connection on power steering Hello, On the subject of hose replacement - I am planning on replacing transmission cooler hoses on our 83 FC 35 this weekend. The upper one is leaking at the tranny connection. The coach has less than 75K on it and I'm pretty sure these are original hoses. From what I read, its probably a good Idea to change these out because of their age. Weather permitting (its getting cold up here), we will do this outside on the ground. One of the hoses connects on an angle near the top of the tranny just above the PTO cover. This is a tough spot to get to from below. After reading about the floor assess for the PS I am wondering if there is an access panel from above to get to this tranny cooler hose? If it has to be done from below are there any tips on doing this that might ease the pain? Thanks- Bill in NH 1983 FC SB --- In WanderlodgeForum@yahoogroups.com, david edwards wrote: > > Gardner: > Just a heads up. When I replaced the return hose for > my PS thru those same access panels at the steering > column, I found it was necessary to use two people. > The person below was needed to hold the hose at the > correct angle to thread into the steering box and the > person above turned the nut on the hose or box. > I tried for quite a while to do it myself in the > storage lot until I finally collared a fellow RV'er at > the lot to help me for 10 minutes. > > Kerry > 82 FC 35 > Denver > > > __________________________________________________________ > Be a better sports nut! Let your teams follow you > with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_...QtBI7ntAcJ > [Non-text portions of this message have been removed] |
11-29-2007, 12:55
--- In WanderlodgeForum@yahoogroups.com, "William"
> > Hello, > > On the subject of hose replacement - I am planning on replacing transmission cooler > hoses on our 83 FC 35 this weekend. The upper one is leaking at the tranny connection. > The coach has less than 75K on it and I'm pretty sure these are original hoses. From > what I read, its probably a good Idea to change these out because of their age. Weather > permitting (its getting cold up here), we will do this outside on the ground. One of the > hoses connects on an angle near the top of the tranny just above the PTO cover. This is a > tough spot to get to from below. After reading about the floor assess for the PS I am > wondering if there is an access panel from above to get to this tranny cooler hose? If it > has to be done from below are there any tips on doing this that might ease the pain? > > Thanks- Bill in NH > 1983 FC SB > > --- In WanderlodgeForum@yahoogroups.com, david edwards > wrote: > > > > Gardner: > > Just a heads up. When I replaced the return hose for > > my PS thru those same access panels at the steering > > column, I found it was necessary to use two people. > > The person below was needed to hold the hose at the > > correct angle to thread into the steering box and the > > person above turned the nut on the hose or box. > > I tried for quite a while to do it myself in the > > storage lot until I finally collared a fellow RV'er at > > the lot to help me for 10 minutes. > > > > Kerry > > 82 FC 35 > > Denver > > > > > > > ______________________________________________________________________ ______________ > > Be a better sports nut! Let your teams follow you > > with Yahoo Mobile. Try it now. > http://mobile.yahoo.com/sports;_ylt=At9_...QtBI7ntAcJ > > That reminds me that I have a new set of those hoses in my coach and haft to do the same thing. I'm sure mine haven't been changed out and like you I'm not looking forward to doing that particular job. Maybe it would be better to let some shop do that work? Another job just like back in my old shipyard days- no room and no fun- X-Marine Machinist Full time retired Wanderlodge Owner > |
11-29-2007, 15:43
Kerry,
Yup, I fought with it for a long while tonight. I finally tied a piece of wire to the hose below the connector and between the wire, a lot of explatives and perserverence I finally got it threaded. Once I had everything installed I used a 1/2 inch drill with a socket adapter to turn the pump to flush and then prime the system. It worked very well and when I finally started the engine I did not have to add any more fluid. The new pump didn't growel at all, however I will reserve judgement until I have put a few miles on it. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, david edwards > > Gardner: > Just a heads up. When I replaced the return hose for > my PS thru those same access panels at the steering > column, I found it was necessary to use two people. > The person below was needed to hold the hose at the > correct angle to thread into the steering box and the > person above turned the nut on the hose or box. > I tried for quite a while to do it myself in the > storage lot until I finally collared a fellow RV'er at > the lot to help me for 10 minutes. > > Kerry > 82 FC 35 > Denver > > > _____________________________________________________________________ _______________ > Be a better sports nut! Let your teams follow you > with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_...QtBI7ntAcJ > |
