batteries in place of generator
12-18-2007, 08:48
Well? I just learned last week that many of the new buses are all
electric. Now, can you run the air conditioning in these buses off the batteries? I would guess that you can not. That you would have to start the generator. Some one mentioned the refrig as being a big draw on battery bank stored energy. Seems to me an air conditioner would pull more then the refrig unless the refrig was started in a warm condition. I know nothing about this subject other then personal experience with RV roof air conditioners and I know they draw a bunch of power especially on first start up. John Heckman central Pa 1973 FC > > and 3600 watts = 30 amps at 120v. I've never worried about running an AC on > a 30amp shore hookup. > > I'm pretty sure the book says the AC units pull about 12 or 13 amps > running. If they need some surge to start I would think the big inverter > and the bank of 8 to 12 batteries could handle it? > > On Dec 18, 2007 3:20 PM, Peter T. Arnold > > > 300 Amps X 12V = 3600 watts > > > > I wouldn't think of running a 13.5 BTU air conditioner with out a 5.0 > > Generator to cove line loss and motor start surge. > > > > Pete > > > > > > On Tue, 18 Dec 2007 14:10:59 -0500, you wrote: > > > > >I could do that also. I already own a couple of portable generators, one > > >5kva and and 7.5kva. > > > > > >I'm not so much planning on running the main engine solely to charge the > > >batteries as charging the batteries while going down the road, or > > charging > > >the batteries while parked where there *is* shore power. I probably need > > >to make sure we can run one of the rooftop AC units while going down the > > >road, but I'm suspecting a big hunky alternator (say 300 amps or so) > > could > > >handle that... I'm guessing that 12.5kw gas genset and associated 30 > > >gallons of fuel must weigh over 500lbs combined, which is a fair amount > > of > > >batteries, say another 8 or more. > > > > > >On Dec 18, 2007 1:21 PM, bubblerboy64 > > wrote: > > > > > >> Dorn, Don't know if your idea would work or not, but I have decided > > >> if my generator dies I think I will make a storage bay for my > > >> portable Honda generators and do it that way. Wouldn't be able to run > > >> them going down the road but I would be able to use them as I did > > >> with my previous trailers. I own the Honda's and rather then dumping > > >> big bucks into a new onan or similar I think I would compromise as > > >> suggested. > > >> John Heckman > > >> central Pa > > >> 1973 FC > > >> > > >> > > > >> > The gas generator on my 77FC35 isn't in the best shape. (hosed up > > >> flywheel, > > >> > takes many tries to find enough teeth to make it start, then > > >> doesn't run for > > >> > more than 5 minutes without starving for fuel... (or so it seems)) > > >> > > > >> > I'm considering just pulling it out and filling the hole where it > > >> used to be > > >> > with a big pile of batteries and a big inverter/charger. > > >> > > > >> > My thought is that the generators weight in batteries would be a > > >> lot of Amp > > >> > Hours. > > >> > > > >> > I would also probably put in the biggest alternator I could get my > > >> hands on > > >> > for best charging and most useable power whilst on the road. > > >> > > > >> > I realize this arrangement probably won't run the much air > > >> conditioning, or > > >> > for long, but I don't have any immediate plans to boondock with the > > >> air > > >> > running ![]() > > >> > > > >> > Any thoughts? Anyone tried this with success or failure? > > >> > > > >> > Regards, > > >> > > > >> > Dorn Hetzel > > >> > 77FC35 > > >> > Hogansville, GA > > >> > > > >> > > > >> > [Non-text portions of this message have been removed] > > >> > > > >> > > >> > > >> > > > > > > > > >[Non-text portions of this message have been removed] > > > > -- > > > > Fraternal Regards, > > > > Peter T. Arnold > > > > Worthy Patron, Temple Chapter #53 {3rd Time} > > > > Hartford Evergreen Lodge #88 Past Master > > Meets on 1st and 3rd Mondays > > > > Washington Lodge #70, Past Master 1997 > > 2nd and 4th Monday > > > > Yahoo 6th District B.L.C. Newsgroup Co-Moderator > > > > Past A.G.M., Masonic District 6B > > Grand Lodge of Connecticut A.F. & A.M. > > > > As you can see, I'm busy on Mondays! > > > > > > > [Non-text portions of this message have been removed] > |
12-18-2007, 09:25
Remember that you are calling on that 300 amps to do a lot more than run the
A/C. Most specifically besides normal running amp draw, you are needing a lot of its output to charge those batteries. A dozen big batteries discharged 50% would be happy to draw 600 amps for many hours if they could - at lower charge rates they will take a long run down the road to get back up! That is actually one of the bigger limitations that I have when dry-camping - I have a ProSine 2000, which can charge 105 amps, and the 6 6-volt AGMs need 330 amp-hours to charge when discharged 50%. They could take 300 amps of input if I had the charging capacity and heavy-enough cables. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 12/18/2007 at 3:37 PM Dorn Hetzel wrote: >and 3600 watts = 30 amps at 120v. I've never worried about running an AC >on >a 30amp shore hookup. > >I'm pretty sure the book says the AC units pull about 12 or 13 amps >running. If they need some surge to start I would think the big inverter >and the bank of 8 to 12 batteries could handle it? |
12-18-2007, 09:43
On 12/18/07, Dorn Hetzel
> > and 3600 watts = 30 amps at 120v. I've never worried about running an AC on > a 30amp shore hookup. You won't have 3600 watts available. Your existing alternator is probably ~150 amps give or take and you're using a good portion of that to run coach systems. So to be safe, your "extra" capacity is only another 150 amps. Further, a 300 amp alternator does not necessarily put out 300 amps, at engine idle speeds it might only put out 180, perhaps less. Someone has done this - set their coach up to run one A/C unit off their inverter while cruising. I want to say they used a 1,500 amp alternator to ensure enough power. I recall it was very expensive, in the two thousand dollar range. Perhaps someone who knows more about this will chime in. At the end of the day, Dorn, to do this "right" I suspect you're going to have more money invested than if you'd just bought a brand new generator or had your own repaired/rebuilt. -Ryan '86 PT-40 8V92 |
12-18-2007, 10:41
1500 amps would be an amazing amount of alternator! At 12 volts that would
represent 18000 watts, at 13.5 or 14.2 volts even more than that. I hope they had a huge engine, at reasonable efficiencies that would probably suck 30 or 40 HP at full power ![]() 50% more than the whole 12kw generator! Regards, Dorn Hetzel 77FC35 Hogansville, GA On Dec 18, 2007 4:43 PM, Ryan Wright > On 12/18/07, Dorn Hetzel > wrote: > > > > and 3600 watts = 30 amps at 120v. I've never worried about running an AC > on > > a 30amp shore hookup. > > You won't have 3600 watts available. Your existing alternator is > probably ~150 amps give or take and you're using a good portion of > that to run coach systems. So to be safe, your "extra" capacity is > only another 150 amps. Further, a 300 amp alternator does not > necessarily put out 300 amps, at engine idle speeds it might only put > out 180, perhaps less. > > Someone has done this - set their coach up to run one A/C unit off > their inverter while cruising. I want to say they used a 1,500 amp > alternator to ensure enough power. I recall it was very expensive, in > the two thousand dollar range. Perhaps someone who knows more about > this will chime in. > > At the end of the day, Dorn, to do this "right" I suspect you're going > to have more money invested than if you'd just bought a brand new > generator or had your own repaired/rebuilt. > > -Ryan > '86 PT-40 8V92 > > [Non-text portions of this message have been removed] |
12-18-2007, 12:18
Hi,
Just to clarify a couple of pts and questions. The new all electric 450 has 2 140 amp alternators (@24V) and can run 2 of the 4 A/C -heat pumps while on the road.. There are 2 -3600 w Vanner inverters and one 1500 true sine wave inverter for the fridge and electronics. The fridge is a minor draw -Kitchenaid . To run an A/C on battery alone- no way 11-12 amps 120 V is ~140 amp at 12V Onan has a new slick method of reducing the size of the alternator and increasing battery/inevrter use http://www.cumminsonan.com/hqd/ Ross 2006 450 LXi Cambridge ON in San Antonio ----- Original Message ---- From: bubblerboy64 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, December 18, 2007 2:48:50 PM Subject: [WanderlodgeForum] Re: batteries in place of generator Well? I just learned last week that many of the new buses are all electric. Now, can you run the air conditioning in these buses off the batteries? I would guess that you can not. That you would have to start the generator. Some one mentioned the refrig as being a big draw on battery bank stored energy. Seems to me an air conditioner would pull more then the refrig unless the refrig was started in a warm condition. I know nothing about this subject other then personal experience with RV roof air conditioners and I know they draw a bunch of power especially on first start up. John Heckman central Pa 1973 FC > > and 3600 watts = 30 amps at 120v. I've never worried about running an AC on > a 30amp shore hookup. > > I'm pretty sure the book says the AC units pull about 12 or 13 amps > running. If they need some surge to start I would think the big inverter > and the bank of 8 to 12 batteries could handle it? > > On Dec 18, 2007 3:20 PM, Peter T. Arnold > > > 300 Amps X 12V = 3600 watts > > > > I wouldn't think of running a 13.5 BTU air conditioner with out a 5.0 > > Generator to cove line loss and motor start surge. > > > > Pete > > > > > > On Tue, 18 Dec 2007 14:10:59 -0500, you wrote: > > > > >I could do that also. I already own a couple of portable generators, one > > >5kva and and 7.5kva. > > > > > >I'm not so much planning on running the main engine solely to charge the > > >batteries as charging the batteries while going down the road, or > > charging > > >the batteries while parked where there *is* shore power. I probably need > > >to make sure we can run one of the rooftop AC units while going down the > > >road, but I'm suspecting a big hunky alternator (say 300 amps or so) > > could > > >handle that... I'm guessing that 12.5kw gas genset and associated 30 > > >gallons of fuel must weigh over 500lbs combined, which is a fair amount > > of > > >batteries, say another 8 or more. > > > > > >On Dec 18, 2007 1:21 PM, bubblerboy64 40hotmail.com> > > > wrote: > > > > > >> Dorn, Don't know if your idea would work or not, but I have decided > > >> if my generator dies I think I will make a storage bay for my > > >> portable Honda generators and do it that way. Wouldn't be able to run > > >> them going down the road but I would be able to use them as I did > > >> with my previous trailers. I own the Honda's and rather then dumping > > >> big bucks into a new onan or similar I think I would compromise as > > >> suggested. > > >> John Heckman > > >> central Pa > > >> 1973 FC > > >> > > >> > > > >> > The gas generator on my 77FC35 isn't in the best shape. (hosed up > > >> flywheel, > > >> > takes many tries to find enough teeth to make it start, then > > >> doesn't run for > > >> > more than 5 minutes without starving for fuel... (or so it seems)) > > >> > > > >> > I'm considering just pulling it out and filling the hole where it > > >> used to be > > >> > with a big pile of batteries and a big inverter/charger. > > >> > > > >> > My thought is that the generators weight in batteries would be a > > >> lot of Amp > > >> > Hours. > > >> > > > >> > I would also probably put in the biggest alternator I could get my > > >> hands on > > >> > for best charging and most useable power whilst on the road. > > >> > > > >> > I realize this arrangement probably won't run the much air > > >> conditioning, or > > >> > for long, but I don't have any immediate plans to boondock with the > > >> air > > >> > running ![]() > > >> > > > >> > Any thoughts? Anyone tried this with success or failure? > > >> > > > >> > Regards, > > >> > > > >> > Dorn Hetzel > > >> > 77FC35 > > >> > Hogansville, GA > > >> > > > >> > > > >> > [Non-text portions of this message have been removed] > > >> > > > >> > > >> > > >> > > > > > > > > >[Non-text portions of this message have been removed] > > > > -- > > > > Fraternal Regards, > > > > Peter T. Arnold > > > > Worthy Patron, Temple Chapter #53 {3rd Time} > > > > Hartford Evergreen Lodge #88 Past Master > > Meets on 1st and 3rd Mondays > > > > Washington Lodge #70, Past Master 1997 > > 2nd and 4th Monday > > > > Yahoo 6th District B.L.C. Newsgroup Co-Moderator > > > > Past A.G.M., Masonic District 6B > > Grand Lodge of Connecticut A.F. & A.M. > > > > As you can see, I'm busy on Mondays! > > > > > > > [Non-text portions of this message have been removed] > <!-- #ygrp-mkp{ border:1px solid #d8d8d8;font-family:Arial;margin:14px 0px;padding:0px 14px;} #ygrp-mkp hr{ border:1px solid #d8d8d8;} #ygrp-mkp #hd{ color:#628c2a;font-size:85%;font-weight:bold;line-height:122%;margin:10px 0px;} #ygrp-mkp #ads{ margin-bottom:10px;} #ygrp-mkp .ad{ padding:0 0;} #ygrp-mkp .ad a{ color:#0000ff;text-decoration:none;} --> <!-- #ygrp-sponsor #ygrp-lc{ font-family:Arial;} #ygrp-sponsor #ygrp-lc #hd{ margin:10px 0px;font-weight:bold;font-size:78%;line-height:122%;} #ygrp-sponsor #ygrp-lc .ad{ margin-bottom:10px;padding:0 0;} --> <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a{ text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc{ background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o{font-size:0;} .MsoNormal{ margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq{margin:4;} --> Looking for a X-Mas gift? Everybody needs a Flickr Pro Account. http://www.flickr.com/gift/ [Non-text portions of this message have been removed] |
12-18-2007, 15:38
That is not true Pete.
How many times have people gone to a campground and hooked into a 30 amp service, and run the A/C without any problem. A/C are usually 1500 watts and surge would go to 3000 maybe a little more. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Peter T. Arnold Sent: Tuesday, December 18, 2007 12:20:26 PM Subject: Re: [WanderlodgeForum] Re: batteries in place of generator 300 Amps X 12V = 3600 watts I wouldn't think of running a 13.5 BTU air conditioner with out a 5.0 Generator to cove line loss and motor start surge. Pete On Tue, 18 Dec 2007 14:10:59 -0500, you wrote: >I could do that also. I already own a couple of portable generators, one >5kva and and 7.5kva. > >I'm not so much planning on running the main engine solely to charge the >batteries as charging the batteries while going down the road, or charging >the batteries while parked where there *is* shore power. I probably need >to make sure we can run one of the rooftop AC units while going down the >road, but I'm suspecting a big hunky alternator (say 300 amps or so) could >handle that... I'm guessing that 12.5kw gas genset and associated 30 >gallons of fuel must weigh over 500lbs combined, which is a fair amount of >batteries, say another 8 or more. > >On Dec 18, 2007 1:21 PM, bubblerboy64 > >> Dorn, Don't know if your idea would work or not, but I have decided >> if my generator dies I think I will make a storage bay for my >> portable Honda generators and do it that way. Wouldn't be able to run >> them going down the road but I would be able to use them as I did >> with my previous trailers. I own the Honda's and rather then dumping >> big bucks into a new onan or similar I think I would compromise as >> suggested. >> John Heckman >> central Pa >> 1973 FC >> >> > >> > The gas generator on my 77FC35 isn't in the best shape. (hosed up >> flywheel, >> > takes many tries to find enough teeth to make it start, then >> doesn't run for >> > more than 5 minutes without starving for fuel... (or so it seems)) >> > >> > I'm considering just pulling it out and filling the hole where it >> used to be >> > with a big pile of batteries and a big inverter/charger. >> > >> > My thought is that the generators weight in batteries would be a >> lot of Amp >> > Hours. >> > >> > I would also probably put in the biggest alternator I could get my >> hands on >> > for best charging and most useable power whilst on the road. >> > >> > I realize this arrangement probably won't run the much air >> conditioning, or >> > for long, but I don't have any immediate plans to boondock with the >> air >> > running ![]() >> > >> > Any thoughts? Anyone tried this with success or failure? >> > >> > Regards, >> > >> > Dorn Hetzel >> > 77FC35 >> > Hogansville, GA >> > >> > >> > [Non-text portions of this message have been removed] >> > >> >> >> > > >[Non-text portions of this message have been removed] -- Fraternal Regards, Peter T. Arnold Worthy Patron, Temple Chapter #53 {3rd Time} Hartford Evergreen Lodge #88 Past Master Meets on 1st and 3rd Mondays Washington Lodge #70, Past Master 1997 2nd and 4th Monday Yahoo 6th District B.L.C. Newsgroup Co-Moderator Past A.G.M., Masonic District 6B Grand Lodge of Connecticut A.F. & A.M. As you can see, I'm busy on Mondays! <!-- #ygrp-mkp{ border:1px solid #d8d8d8;font-family:Arial;margin:14px 0px;padding:0px 14px;} #ygrp-mkp hr{ border:1px solid #d8d8d8;} #ygrp-mkp #hd{ color:#628c2a;font-size:85%;font-weight:bold;line-height:122%;margin:10px 0px;} #ygrp-mkp #ads{ margin-bottom:10px;} #ygrp-mkp .ad{ padding:0 0;} #ygrp-mkp .ad a{ color:#0000ff;text-decoration:none;} --> <!-- #ygrp-sponsor #ygrp-lc{ font-family:Arial;} #ygrp-sponsor #ygrp-lc #hd{ margin:10px 0px;font-weight:bold;font-size:78%;line-height:122%;} #ygrp-sponsor #ygrp-lc .ad{ margin-bottom:10px;padding:0 0;} --> <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a{ text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc{ background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o{font-size:0;} .MsoNormal{ margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq{margin:4;} --> Looking for the perfect gift? Give the gift of Flickr! http://www.flickr.com/gift/ [Non-text portions of this message have been removed] |
12-18-2007, 15:39
Dorn:
Let us know what alternator you might settle on. I am thinking of upgrading as well, escpecially with the electric brake drawing the current like it does. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Dorn Hetzel To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, December 18, 2007 12:31:07 PM Subject: Re: [WanderlodgeForum] Re: batteries in place of generator Yep, my engine run A/C doesn't run right now, but it's on my short list to repair, just putting it off until spring since I sure don't need AC now ![]() I'm looking at something like a Xantrex RS3000 and about 300 amps of alternator capacity. That should run at least one of the AC units while driving I would hope. Regards, Dorn Hetzel 77FC35 Hogansville, GA On Dec 18, 2007 2:45 PM, Jon > --- In WanderlodgeForum@ yahoogroups. com > "Dorn Hetzel" > wrote: > > > > The gas generator on my 77FC35 isn't in the best shape. (hosed up > flywheel, > > takes many tries to find enough teeth to make it start, then > doesn't run for > > more than 5 minutes without starving for fuel... (or so it seems)) > > > > I'm considering just pulling it out and filling the hole where it > used to be > > with a big pile of batteries and a big inverter/charger. > > > > My thought is that the generators weight in batteries would be a > lot of Amp > > Hours. > > > > I would also probably put in the biggest alternator I could get my > hands on > > for best charging and most useable power whilst on the road. > > > > I realize this arrangement probably won't run the much air > conditioning, or > > for long, but I don't have any immediate plans to boondock with the > air > > running ![]() > > > > Any thoughts? Anyone tried this with success or failure? > > > > Regards, > > > > Dorn Hetzel > > 77FC35 > > Hogansville, GA > > > > > > [Non-text portions of this message have been removed] > > Without saying to much I would stick with some type of generator. If > your coach is typical for being a vintage Wanderlodge than your > Engine run A/C does not operate. Now I know most of the people here > use there generator to run there topside A/C unit in hot weather when > there dash air is not operational. These old coaches can get pretty > hot inside during the summer months. I would stick to a generator > just for that reason. Jon > > > > > [Non-text portions of this message have been removed] <!-- #ygrp-mkp{ border:1px solid #d8d8d8;font-family:Arial;margin:14px 0px;padding:0px 14px;} #ygrp-mkp hr{ border:1px solid #d8d8d8;} #ygrp-mkp #hd{ color:#628c2a;font-size:85%;font-weight:bold;line-height:122%;margin:10px 0px;} #ygrp-mkp #ads{ margin-bottom:10px;} #ygrp-mkp .ad{ padding:0 0;} #ygrp-mkp .ad a{ color:#0000ff;text-decoration:none;} --> <!-- #ygrp-sponsor #ygrp-lc{ font-family:Arial;} #ygrp-sponsor #ygrp-lc #hd{ margin:10px 0px;font-weight:bold;font-size:78%;line-height:122%;} #ygrp-sponsor #ygrp-lc .ad{ margin-bottom:10px;padding:0 0;} --> <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a{ text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc{ background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o{font-size:0;} .MsoNormal{ margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq{margin:4;} --> Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail. Click on Options in Mail and switch to New Mail today or register for free at http://mail.yahoo.ca [Non-text portions of this message have been removed] |
12-18-2007, 15:44
Running A/C on batteries alone is almost impossible. The draw is continous at
about 1400 watts, as a fridge is about 500watt cyclic, the bigger fridges somewhat more maybe 700 or so. I believe the electric buses have a smaller engine running an alternator or generator to continously charge the batteries, but having the engine running at a constant speed reduces fuel consumption. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: bubblerboy64 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, December 18, 2007 12:48:50 PM Subject: [WanderlodgeForum] Re: batteries in place of generator Well? I just learned last week that many of the new buses are all electric. Now, can you run the air conditioning in these buses off the batteries? I would guess that you can not. That you would have to start the generator. Some one mentioned the refrig as being a big draw on battery bank stored energy. Seems to me an air conditioner would pull more then the refrig unless the refrig was started in a warm condition. I know nothing about this subject other then personal experience with RV roof air conditioners and I know they draw a bunch of power especially on first start up. John Heckman central Pa 1973 FC > > and 3600 watts = 30 amps at 120v. I've never worried about running an AC on > a 30amp shore hookup. > > I'm pretty sure the book says the AC units pull about 12 or 13 amps > running. If they need some surge to start I would think the big inverter > and the bank of 8 to 12 batteries could handle it? > > On Dec 18, 2007 3:20 PM, Peter T. Arnold > > > 300 Amps X 12V = 3600 watts > > > > I wouldn't think of running a 13.5 BTU air conditioner with out a 5.0 > > Generator to cove line loss and motor start surge. > > > > Pete > > > > > > On Tue, 18 Dec 2007 14:10:59 -0500, you wrote: > > > > >I could do that also. I already own a couple of portable generators, one > > >5kva and and 7.5kva. > > > > > >I'm not so much planning on running the main engine solely to charge the > > >batteries as charging the batteries while going down the road, or > > charging > > >the batteries while parked where there *is* shore power. I probably need > > >to make sure we can run one of the rooftop AC units while going down the > > >road, but I'm suspecting a big hunky alternator (say 300 amps or so) > > could > > >handle that... I'm guessing that 12.5kw gas genset and associated 30 > > >gallons of fuel must weigh over 500lbs combined, which is a fair amount > > of > > >batteries, say another 8 or more. > > > > > >On Dec 18, 2007 1:21 PM, bubblerboy64 40hotmail.com> > > > wrote: > > > > > >> Dorn, Don't know if your idea would work or not, but I have decided > > >> if my generator dies I think I will make a storage bay for my > > >> portable Honda generators and do it that way. Wouldn't be able to run > > >> them going down the road but I would be able to use them as I did > > >> with my previous trailers. I own the Honda's and rather then dumping > > >> big bucks into a new onan or similar I think I would compromise as > > >> suggested. > > >> John Heckman > > >> central Pa > > >> 1973 FC > > >> > > >> > > > >> > The gas generator on my 77FC35 isn't in the best shape. (hosed up > > >> flywheel, > > >> > takes many tries to find enough teeth to make it start, then > > >> doesn't run for > > >> > more than 5 minutes without starving for fuel... (or so it seems)) > > >> > > > >> > I'm considering just pulling it out and filling the hole where it > > >> used to be > > >> > with a big pile of batteries and a big inverter/charger. > > >> > > > >> > My thought is that the generators weight in batteries would be a > > >> lot of Amp > > >> > Hours. > > >> > > > >> > I would also probably put in the biggest alternator I could get my > > >> hands on > > >> > for best charging and most useable power whilst on the road. > > >> > > > >> > I realize this arrangement probably won't run the much air > > >> conditioning, or > > >> > for long, but I don't have any immediate plans to boondock with the > > >> air > > >> > running ![]() > > >> > > > >> > Any thoughts? Anyone tried this with success or failure? > > >> > > > >> > Regards, > > >> > > > >> > Dorn Hetzel > > >> > 77FC35 > > >> > Hogansville, GA > > >> > > > >> > > > >> > [Non-text portions of this message have been removed] > > >> > > > >> > > >> > > >> > > > > > > > > >[Non-text portions of this message have been removed] > > > > -- > > > > Fraternal Regards, > > > > Peter T. Arnold > > > > Worthy Patron, Temple Chapter #53 {3rd Time} > > > > Hartford Evergreen Lodge #88 Past Master > > Meets on 1st and 3rd Mondays > > > > Washington Lodge #70, Past Master 1997 > > 2nd and 4th Monday > > > > Yahoo 6th District B.L.C. Newsgroup Co-Moderator > > > > Past A.G.M., Masonic District 6B > > Grand Lodge of Connecticut A.F. & A.M. > > > > As you can see, I'm busy on Mondays! > > > > > > > [Non-text portions of this message have been removed] > <!-- #ygrp-mkp{ border:1px solid #d8d8d8;font-family:Arial;margin:14px 0px;padding:0px 14px;} #ygrp-mkp hr{ border:1px solid #d8d8d8;} #ygrp-mkp #hd{ color:#628c2a;font-size:85%;font-weight:bold;line-height:122%;margin:10px 0px;} #ygrp-mkp #ads{ margin-bottom:10px;} #ygrp-mkp .ad{ padding:0 0;} #ygrp-mkp .ad a{ color:#0000ff;text-decoration:none;} --> <!-- #ygrp-sponsor #ygrp-lc{ font-family:Arial;} #ygrp-sponsor #ygrp-lc #hd{ margin:10px 0px;font-weight:bold;font-size:78%;line-height:122%;} #ygrp-sponsor #ygrp-lc .ad{ margin-bottom:10px;padding:0 0;} --> <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a{ text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc{ background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o{font-size:0;} .MsoNormal{ margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq{margin:4;} --> Looking for a X-Mas gift? Everybody needs a Flickr Pro Account. http://www.flickr.com/gift/ [Non-text portions of this message have been removed] |
12-18-2007, 15:46
Don:
You are very correct there. I have smaller batteries in my FC, and when driving down the road, having heat on in the coach, fans running and using my electric brake in these hills, it literally takes hours to charge up, and it is over at 100 to 120 amps. Having even more batteries, well that would make things that much worse. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Don Bradner To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, December 18, 2007 1:25:52 PM Subject: Re: [WanderlodgeForum] Re: batteries in place of generator Remember that you are calling on that 300 amps to do a lot more than run the A/C. Most specifically besides normal running amp draw, you are needing a lot of its output to charge those batteries. A dozen big batteries discharged 50% would be happy to draw 600 amps for many hours if they could - at lower charge rates they will take a long run down the road to get back up! That is actually one of the bigger limitations that I have when dry-camping - I have a ProSine 2000, which can charge 105 amps, and the 6 6-volt AGMs need 330 amp-hours to charge when discharged 50%. They could take 300 amps of input if I had the charging capacity and heavy-enough cables. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 12/18/2007 at 3:37 PM Dorn Hetzel wrote: >and 3600 watts = 30 amps at 120v. I've never worried about running an AC >on >a 30amp shore hookup. > >I'm pretty sure the book says the AC units pull about 12 or 13 amps >running. If they need some surge to start I would think the big inverter >and the bank of 8 to 12 batteries could handle it? <!-- #ygrp-mkp{ border:1px solid #d8d8d8;font-family:Arial;margin:14px 0px;padding:0px 14px;} #ygrp-mkp hr{ border:1px solid #d8d8d8;} #ygrp-mkp #hd{ color:#628c2a;font-size:85%;font-weight:bold;line-height:122%;margin:10px 0px;} #ygrp-mkp #ads{ margin-bottom:10px;} #ygrp-mkp .ad{ padding:0 0;} #ygrp-mkp .ad a{ color:#0000ff;text-decoration:none;} --> <!-- #ygrp-sponsor #ygrp-lc{ font-family:Arial;} #ygrp-sponsor #ygrp-lc #hd{ margin:10px 0px;font-weight:bold;font-size:78%;line-height:122%;} #ygrp-sponsor #ygrp-lc .ad{ margin-bottom:10px;padding:0 0;} --> <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a{ text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc{ background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o{font-size:0;} .MsoNormal{ margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq{margin:4;} --> Looking for the perfect gift? Give the gift of Flickr! http://www.flickr.com/gift/ [Non-text portions of this message have been removed] |
12-18-2007, 15:49
Ryan:
1500 amp alternator?? are you sure. That would be huge, how would that fit inside the engine compartment? Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Ryan Wright To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, December 18, 2007 1:43:20 PM Subject: Re: [WanderlodgeForum] Re: batteries in place of generator On 12/18/07, Dorn Hetzel > > and 3600 watts = 30 amps at 120v. I've never worried about running an AC on > a 30amp shore hookup. You won't have 3600 watts available. Your existing alternator is probably ~150 amps give or take and you're using a good portion of that to run coach systems. So to be safe, your "extra" capacity is only another 150 amps. Further, a 300 amp alternator does not necessarily put out 300 amps, at engine idle speeds it might only put out 180, perhaps less. Someone has done this - set their coach up to run one A/C unit off their inverter while cruising. I want to say they used a 1,500 amp alternator to ensure enough power. I recall it was very expensive, in the two thousand dollar range. Perhaps someone who knows more about this will chime in. At the end of the day, Dorn, to do this "right" I suspect you're going to have more money invested than if you'd just bought a brand new generator or had your own repaired/rebuilt. -Ryan '86 PT-40 8V92 <!-- #ygrp-mkp{ border:1px solid #d8d8d8;font-family:Arial;margin:14px 0px;padding:0px 14px;} #ygrp-mkp hr{ border:1px solid #d8d8d8;} #ygrp-mkp #hd{ color:#628c2a;font-size:85%;font-weight:bold;line-height:122%;margin:10px 0px;} #ygrp-mkp #ads{ margin-bottom:10px;} #ygrp-mkp .ad{ padding:0 0;} #ygrp-mkp .ad a{ color:#0000ff;text-decoration:none;} --> <!-- #ygrp-sponsor #ygrp-lc{ font-family:Arial;} #ygrp-sponsor #ygrp-lc #hd{ margin:10px 0px;font-weight:bold;font-size:78%;line-height:122%;} #ygrp-sponsor #ygrp-lc .ad{ margin-bottom:10px;padding:0 0;} --> <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a{ text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc{ background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o{font-size:0;} .MsoNormal{ margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq{margin:4;} --> Looking for the perfect gift? Give the gift of Flickr! http://www.flickr.com/gift/ [Non-text portions of this message have been removed] |
