batteries in place of generator
12-18-2007, 15:59
Post: #21
On 12/18/07, Wilhelmus Schreurs
> > Ryan: > 1500 amp alternator?? are you sure. > That would be huge, how would that fit inside the engine compartment? Hah! I'm an idiot. I remembered wrong. I did some searching to find whose coach I was thinking of. Turns out it's Jay Darst's, and I mixed up amps and dollars in my poor excuse for a memory. It was a $1500, 320 amp alternator, not 1500 amps. I was right about remembering it being hideously expensive, though. From Jay's post earlier this year: > we installed a $1,500 320amp alternator which provides sufficient > power to the inverter to run an a/c unit. OK, so yes, this is making more sense to me (and probably everyone else) now. I still think Dorn would be money ahead to fix his genset. Going down this road the numbers look like $1500 for an alternator, couple grand worth of batteries, another grand worth of inverter, more for cables and connectors to tie all that power together... Aren't we approaching the price of a new Onan now? -Ryan, going senile wayyyy too early. '86 PT-40 8V92 (I think...) |
12-18-2007, 16:10
Post: #22
FYI
In my 85 PT40, is a Leece-NeVille 320amp alternator. That is the biggest I could find in a 12volt alt. Makes plenty of power to run an inverter powered A/C while running down the road. Incidentally, I have run 1 roof air with the inverter WITHOUT the Detroit running. Run it while at a lunch stop or loading and unloading. I have 6 6volt trojan T105s. Thats 660 amp hour capacity of which you can safely use about 50% when sucking on them with a big draw like A/C. The roof airs start at about 19 amps and then operate at about 12.5 amps. That means that 12.5 amps(@110V) x 110 = 1,375 watts but then inverters typically are around 92% efficient so 1,375 divided by 93% = 1,478 watts so 1,475 divied by 12.5Volts = 118 amp draw at 12.5volts so if the A/C runs at 100% duty cycle, you should be able to run the A/C for 2.8 hours. There are some other factors that will/could cause less run time, has to do with a high amp draw with no break in the action. Prawlly internal battery temps and other misc stuff. You won't start the coach on that battery bank after 2.8 hours. Ya might start it after an hour if temps are above 70 degrees, which probably would be, since you're running A/C. Ramble ramble ramble 2 cents... ;~} Jay Darst 85PT40 with Xantrex 2,500 watt Inverter/Charger and 320amp alt '91 Prevost Royale 40XL with a 24V 280amp alt using Vanner electronics to step down to 12V '00 Prevost Royale H345 with 2 alternators 1-12v140amp and 1-24v monster oil cooled, etc Springfield/Sullivan, IL --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > Dorn: > Let us know what alternator you might settle on. I am thinking of upgrading as well, escpecially with the electric brake drawing the current like it does. > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > ----- Original Message ---- > From: Dorn Hetzel > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, December 18, 2007 12:31:07 PM > Subject: Re: [WanderlodgeForum] Re: batteries in place of generator > > > > > > > > > > > > > > Yep, my engine run A/C doesn't run right now, but it's on my short list to > > repair, just putting it off until spring since I sure don't need AC now > > > > I'm looking at something like a Xantrex RS3000 and about 300 amps of > > alternator capacity. That should run at least one of the AC units while > > driving I would hope. > > > > Regards, > > > > Dorn Hetzel > > 77FC35 > > Hogansville, GA > > > > On Dec 18, 2007 2:45 PM, Jon > > > > > --- In WanderlodgeForum@ yahoogroups. com > > > "Dorn Hetzel" > > > wrote: > > > > > > > > The gas generator on my 77FC35 isn't in the best shape. (hosed up > > > flywheel, > > > > takes many tries to find enough teeth to make it start, then > > > doesn't run for > > > > more than 5 minutes without starving for fuel... (or so it seems)) > > > > > > > > I'm considering just pulling it out and filling the hole where it > > > used to be > > > > with a big pile of batteries and a big inverter/charger. > > > > > > > > My thought is that the generators weight in batteries would be a > > > lot of Amp > > > > Hours. > > > > > > > > I would also probably put in the biggest alternator I could get my > > > hands on > > > > for best charging and most useable power whilst on the road. > > > > > > > > I realize this arrangement probably won't run the much air > > > conditioning, or > > > > for long, but I don't have any immediate plans to boondock with the > > > air > > > > running > > > > > > > > Any thoughts? Anyone tried this with success or failure? > > > > > > > > Regards, > > > > > > > > Dorn Hetzel > > > > 77FC35 > > > > Hogansville, GA > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > Without saying to much I would stick with some type of generator. If > > > your coach is typical for being a vintage Wanderlodge than your > > > Engine run A/C does not operate. Now I know most of the people here > > > use there generator to run there topside A/C unit in hot weather when > > > there dash air is not operational. These old coaches can get pretty > > > hot inside during the summer months. I would stick to a generator > > > just for that reason. Jon > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > <!-- > > #ygrp-mkp{ > border:1px solid #d8d8d8;font-family:Arial;margin:14px 0px;padding:0px 14px;} > #ygrp-mkp hr{ > border:1px solid #d8d8d8;} > #ygrp-mkp #hd{ > color:#628c2a;font-size:85%;font-weight:bold;line- height:122%;margin:10px 0px;} > #ygrp-mkp #ads{ > margin-bottom:10px;} > #ygrp-mkp .ad{ > padding:0 0;} > #ygrp-mkp .ad a{ > color:#0000ff;text-decoration:none;} > --> > > > > <!-- > > #ygrp-sponsor #ygrp-lc{ > font-family:Arial;} > #ygrp-sponsor #ygrp-lc #hd{ > margin:10px 0px;font-weight:bold;font-size:78%;line-height:122%;} > #ygrp-sponsor #ygrp-lc .ad{ > margin-bottom:10px;padding:0 0;} > --> > > > > <!-- > > #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} > #ygrp-mlmsg table {font-size:inherit;font:100%;} > #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} > #ygrp-mlmsg pre, code {font:115% monospace;} > #ygrp-mlmsg * {line-height:1.22em;} > #ygrp-text{ > font-family:Georgia; > } > #ygrp-text p{ > margin:0 0 1em 0;} > #ygrp-tpmsgs{ > font-family:Arial; > clear:both;} > #ygrp-vitnav{ > padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} > #ygrp-vitnav a{ > padding:0 1px;} > #ygrp-actbar{ > clear:both;margin:25px 0;white-space:nowrap;color:#666;text- align:right;} > #ygrp-actbar .left{ > float:left;white-space:nowrap;} > .bld{font-weight:bold;} > #ygrp-grft{ > font-family:Verdana;font-size:77%;padding:15px 0;} > #ygrp-ft{ > font-family:verdana;font-size:77%;border-top:1px solid #666; > padding:5px 0; > } > #ygrp-mlmsg #logo{ > padding-bottom:10px;} > > #ygrp-vital{ > background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} > #ygrp-vital #vithd{ > font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text- transform:uppercase;} > #ygrp-vital ul{ > padding:0;margin:2px 0;} > #ygrp-vital ul li{ > list-style-type:none;clear:both;border:1px solid #e0ecee; > } > #ygrp-vital ul li .ct{ > font-weight:bold;color:#ff7900;float:right;width:2em;text- align:right;padding-right:.5em;} > #ygrp-vital ul li .cat{ > font-weight:bold;} > #ygrp-vital a{ > text-decoration:none;} > > #ygrp-vital a:hover{ > text-decoration:underline;} > > #ygrp-sponsor #hd{ > color:#999;font-size:77%;} > #ygrp-sponsor #ov{ > padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} > #ygrp-sponsor #ov ul{ > padding:0 0 0 8px;margin:0;} > #ygrp-sponsor #ov li{ > list-style-type:square;padding:6px 0;font-size:77%;} > #ygrp-sponsor #ov li a{ > text-decoration:none;font-size:130%;} > #ygrp-sponsor #nc{ > background-color:#eee;margin-bottom:20px;padding:0 8px;} > #ygrp-sponsor .ad{ > padding:8px 0;} > #ygrp-sponsor .ad #hd1{ > font-family:Arial;font-weight:bold;color:#628c2a;font- size:100%;line-height:122%;} > #ygrp-sponsor .ad a{ > text-decoration:none;} > #ygrp-sponsor .ad a:hover{ > text-decoration:underline;} > #ygrp-sponsor .ad p{ > margin:0;} > o{font-size:0;} > .MsoNormal{ > margin:0 0 0 0;} > #ygrp-text tt{ > font-size:120%;} > blockquote{margin:0 0 0 4px;} > .replbq{margin:4;} > --> > > > > > > > > > Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail. Click on Options in Mail and switch to New Mail today or register for free at http://mail.yahoo.ca > > [Non-text portions of this message have been removed] > |
12-18-2007, 16:42
Post: #23
Thanks Jay, interesting, something different in each coach.
Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Jay Darst To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, December 18, 2007 8:10:09 PM Subject: [WanderlodgeForum] Re: batteries in place of generator FYI In my 85 PT40, is a Leece-NeVille 320amp alternator. That is the biggest I could find in a 12volt alt. Makes plenty of power to run an inverter powered A/C while running down the road. Incidentally, I have run 1 roof air with the inverter WITHOUT the Detroit running. Run it while at a lunch stop or loading and unloading. I have 6 6volt trojan T105s. Thats 660 amp hour capacity of which you can safely use about 50% when sucking on them with a big draw like A/C. The roof airs start at about 19 amps and then operate at about 12.5 amps. That means that 12.5 amps(@110V) x 110 = 1,375 watts but then inverters typically are around 92% efficient so 1,375 divided by 93% = 1,478 watts so 1,475 divied by 12.5Volts = 118 amp draw at 12.5volts so if the A/C runs at 100% duty cycle, you should be able to run the A/C for 2.8 hours. There are some other factors that will/could cause less run time, has to do with a high amp draw with no break in the action. Prawlly internal battery temps and other misc stuff. You won't start the coach on that battery bank after 2.8 hours. Ya might start it after an hour if temps are above 70 degrees, which probably would be, since you're running A/C. Ramble ramble ramble 2 cents... ;~} Jay Darst 85PT40 with Xantrex 2,500 watt Inverter/Charger and 320amp alt '91 Prevost Royale 40XL with a 24V 280amp alt using Vanner electronics to step down to 12V '00 Prevost Royale H345 with 2 alternators 1-12v140amp and 1-24v monster oil cooled, etc Springfield/ Sullivan, IL --- In WanderlodgeForum@ yahoogroups. com, Wilhelmus Schreurs > > Dorn: > Let us know what alternator you might settle on. I am thinking of upgrading as well, escpecially with the electric brake drawing the current like it does. > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > ----- Original Message ---- > From: Dorn Hetzel > To: WanderlodgeForum@ yahoogroups. com > Sent: Tuesday, December 18, 2007 12:31:07 PM > Subject: Re: [WanderlodgeForum] Re: batteries in place of generator > > > > > > > > > > > > > > Yep, my engine run A/C doesn't run right now, but it's on my short list to > > repair, just putting it off until spring since I sure don't need AC now > > > > I'm looking at something like a Xantrex RS3000 and about 300 amps of > > alternator capacity. That should run at least one of the AC units while > > driving I would hope. > > > > Regards, > > > > Dorn Hetzel > > 77FC35 > > Hogansville, GA > > > > On Dec 18, 2007 2:45 PM, Jon > > > > > --- In WanderlodgeForum@ yahoogroups. com 40yahoogroups. com>, > > > "Dorn Hetzel" > > > wrote: > > > > > > > > The gas generator on my 77FC35 isn't in the best shape. (hosed up > > > flywheel, > > > > takes many tries to find enough teeth to make it start, then > > > doesn't run for > > > > more than 5 minutes without starving for fuel... (or so it seems)) > > > > > > > > I'm considering just pulling it out and filling the hole where it > > > used to be > > > > with a big pile of batteries and a big inverter/charger. > > > > > > > > My thought is that the generators weight in batteries would be a > > > lot of Amp > > > > Hours. > > > > > > > > I would also probably put in the biggest alternator I could get my > > > hands on > > > > for best charging and most useable power whilst on the road. > > > > > > > > I realize this arrangement probably won't run the much air > > > conditioning, or > > > > for long, but I don't have any immediate plans to boondock with the > > > air > > > > running > > > > > > > > Any thoughts? Anyone tried this with success or failure? > > > > > > > > Regards, > > > > > > > > Dorn Hetzel > > > > 77FC35 > > > > Hogansville, GA > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > Without saying to much I would stick with some type of generator. If > > > your coach is typical for being a vintage Wanderlodge than your > > > Engine run A/C does not operate. Now I know most of the people here > > > use there generator to run there topside A/C unit in hot weather when > > > there dash air is not operational. These old coaches can get pretty > > > hot inside during the summer months. I would stick to a generator > > > just for that reason. Jon > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > <!-- > > #ygrp-mkp{ > border:1px solid #d8d8d8;font- family:Arial; margin:14px 0px;padding: 0px 14px;} > #ygrp-mkp hr{ > border:1px solid #d8d8d8;} > #ygrp-mkp #hd{ > color:#628c2a; font-size: 85%;font- weight:bold; line- height:122%; margin:10px 0px;} > #ygrp-mkp #ads{ > margin-bottom: 10px;} > #ygrp-mkp .ad{ > padding:0 0;} > #ygrp-mkp .ad a{ > color:#0000ff; text-decoration: none;} > --> > > > > <!-- > > #ygrp-sponsor #ygrp-lc{ > font-family: Arial;} > #ygrp-sponsor #ygrp-lc #hd{ > margin:10px 0px;font-weight: bold;font- size:78%; line-height: 122%;} > #ygrp-sponsor #ygrp-lc .ad{ > margin-bottom: 10px;padding: 0 0;} > --> > > > > <!-- > > #ygrp-mlmsg {font-size:13px; font-family: arial, helvetica, clean, sans-serif;} > #ygrp-mlmsg table {font-size:inherit; font:100% ;} > #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} > #ygrp-mlmsg pre, code {font:115% monospace;} > #ygrp-mlmsg * {line-height: 1.22em;} > #ygrp-text{ > font-family: Georgia; > } > #ygrp-text p{ > margin:0 0 1em 0;} > #ygrp-tpmsgs{ > font-family: Arial; > clear:both;} > #ygrp-vitnav{ > padding-top: 10px;font- family:Verdana; font-size: 77%;margin: 0;} > #ygrp-vitnav a{ > padding:0 1px;} > #ygrp-actbar{ > clear:both;margin: 25px 0;white-space: nowrap;color: #666;text- align:right; } > #ygrp-actbar .left{ > float:left;white- space:nowrap; } > .bld{font-weight: bold;} > #ygrp-grft{ > font-family: Verdana;font- size:77%; padding:15px 0;} > #ygrp-ft{ > font-family: verdana;font- size:77%; border-top: 1px solid #666; > padding:5px 0; > } > #ygrp-mlmsg #logo{ > padding-bottom: 10px;} > > #ygrp-vital{ > background-color: #e0ecee;margin- bottom:20px; padding:2px 0 8px 8px;} > #ygrp-vital #vithd{ > font-size:77% ;font-family: Verdana;font- weight:bold; color:#333; text- transform:uppercase ;} > #ygrp-vital ul{ > padding:0;margin: 2px 0;} > #ygrp-vital ul li{ > list-style-type: none;clear: both;border: 1px solid #e0ecee; > } > #ygrp-vital ul li .ct{ > font-weight: bold;color: #ff7900;float: right;width: 2em;text- align:right; padding-right: .5em;} > #ygrp-vital ul li .cat{ > font-weight: bold;} > #ygrp-vital a{ > text-decoration: none;} > > #ygrp-vital a:hover{ > text-decoration: underline; } > > #ygrp-sponsor #hd{ > color:#999;font- size:77%; } > #ygrp-sponsor #ov{ > padding:6px 13px;background- color:#e0ecee; margin-bottom: 20px;} > #ygrp-sponsor #ov ul{ > padding:0 0 0 8px;margin:0; } > #ygrp-sponsor #ov li{ > list-style-type: square;padding: 6px 0;font-size: 77%;} > #ygrp-sponsor #ov li a{ > text-decoration: none;font- size:130% ;} > #ygrp-sponsor #nc{ > background-color: #eee;margin- bottom:20px; padding:0 8px;} > #ygrp-sponsor .ad{ > padding:8px 0;} > #ygrp-sponsor .ad #hd1{ > font-family: Arial;font- weight:bold; color:#628c2a; font- size:100%;line- height:122% ;} > #ygrp-sponsor .ad a{ > text-decoration: none;} > #ygrp-sponsor .ad a:hover{ > text-decoration: underline; } > #ygrp-sponsor .ad p{ > margin:0;} > o{font-size: 0;} > .MsoNormal{ > margin:0 0 0 0;} > #ygrp-text tt{ > font-size:120% ;} > blockquote{margin: 0 0 0 4px;} > .replbq{margin: 4;} > --> > > > > > > > > > Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail. Click on Options in Mail and switch to New Mail today or register for free at http://mail. yahoo.ca > > [Non-text portions of this message have been removed] > <!-- #ygrp-mkp{ border:1px solid #d8d8d8;font-family:Arial;margin:14px 0px;padding:0px 14px;} #ygrp-mkp hr{ border:1px solid #d8d8d8;} #ygrp-mkp #hd{ color:#628c2a;font-size:85%;font-weight:bold;line-height:122%;margin:10px 0px;} #ygrp-mkp #ads{ margin-bottom:10px;} #ygrp-mkp .ad{ padding:0 0;} #ygrp-mkp .ad a{ color:#0000ff;text-decoration:none;} --> <!-- #ygrp-sponsor #ygrp-lc{ font-family:Arial;} #ygrp-sponsor #ygrp-lc #hd{ margin:10px 0px;font-weight:bold;font-size:78%;line-height:122%;} #ygrp-sponsor #ygrp-lc .ad{ margin-bottom:10px;padding:0 0;} --> <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a{ text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc{ background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o{font-size:0;} .MsoNormal{ margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq{margin:4;} --> Looking for a X-Mas gift? Everybody needs a Flickr Pro Account. http://www.flickr.com/gift/ [Non-text portions of this message have been removed] |
12-18-2007, 16:47
Post: #24
Ryan:
Is that the sign of old age LOL. Maybe Dorn would be better off with a smaller generator, 12.5kw is overkill, I have not been able to put 80% load as it should have, but in my case I will once I start to travel full time, as my wife is a potter and we will be plugging that in from time to time, 30 amps 240 volts. I would think a 6 kw would be plenty, even to run 2 A/C at the same time, and some load management on the rest. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Ryan Wright To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, December 18, 2007 7:59:05 PM Subject: Re: [WanderlodgeForum] Re: batteries in place of generator On 12/18/07, Wilhelmus Schreurs > > Ryan: > 1500 amp alternator?? are you sure. > That would be huge, how would that fit inside the engine compartment? Hah! I'm an idiot. I remembered wrong. I did some searching to find whose coach I was thinking of. Turns out it's Jay Darst's, and I mixed up amps and dollars in my poor excuse for a memory. It was a $1500, 320 amp alternator, not 1500 amps. I was right about remembering it being hideously expensive, though. From Jay's post earlier this year: > we installed a $1,500 320amp alternator which provides sufficient > power to the inverter to run an a/c unit. OK, so yes, this is making more sense to me (and probably everyone else) now. I still think Dorn would be money ahead to fix his genset. Going down this road the numbers look like $1500 for an alternator, couple grand worth of batteries, another grand worth of inverter, more for cables and connectors to tie all that power together... Aren't we approaching the price of a new Onan now? -Ryan, going senile wayyyy too early. '86 PT-40 8V92 (I think...) <!-- #ygrp-mkp{ border:1px solid #d8d8d8;font-family:Arial;margin:14px 0px;padding:0px 14px;} #ygrp-mkp hr{ border:1px solid #d8d8d8;} #ygrp-mkp #hd{ color:#628c2a;font-size:85%;font-weight:bold;line-height:122%;margin:10px 0px;} #ygrp-mkp #ads{ margin-bottom:10px;} #ygrp-mkp .ad{ padding:0 0;} #ygrp-mkp .ad a{ color:#0000ff;text-decoration:none;} --> <!-- #ygrp-sponsor #ygrp-lc{ font-family:Arial;} #ygrp-sponsor #ygrp-lc #hd{ margin:10px 0px;font-weight:bold;font-size:78%;line-height:122%;} #ygrp-sponsor #ygrp-lc .ad{ margin-bottom:10px;padding:0 0;} --> <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a{ text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc{ background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o{font-size:0;} .MsoNormal{ margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq{margin:4;} --> Ask a question on any topic and get answers from real people. Go to Yahoo! Answers and share what you know at http://ca.answers.yahoo.com [Non-text portions of this message have been removed] |
12-18-2007, 18:25
Post: #25
I would heave ho the old genset and replace it with a used RV 5 K
Onan. The construction gensets are not designed to be recontained and they are noisy. you can find rv gensets all over the place with low hours. Craigslist.org is a good place to start. I purchased 2 at an Onan repair facility for under 400. each and ran them with electric demo hammers for several years. dumping a hunk of crap aint gonna have an impact on resale. You are better off with empty storage than a faulty genset as far as that goes. I have 6 L16 trogen forklift batteries with major storage. the problem is when you use it up, you need major runtime to recharge. proper usage management will help. things like scheduling run/charge time during high electrical usage demand will maxamize utility with the least investment need. running the genset twice a day for 1/2 the time will reduce battery storage need. Gensets actually like to be run fully loaded. Its all Math GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Dorn Hetzel" > > The gas generator on my 77FC35 isn't in the best shape. (hosed up flywheel, > takes many tries to find enough teeth to make it start, then doesn't run for > more than 5 minutes without starving for fuel... (or so it seems)) > > I'm considering just pulling it out and filling the hole where it used to be > with a big pile of batteries and a big inverter/charger. > > My thought is that the generators weight in batteries would be a lot of Amp > Hours. > > I would also probably put in the biggest alternator I could get my hands on > for best charging and most useable power whilst on the road. > > I realize this arrangement probably won't run the much air conditioning, or > for long, but I don't have any immediate plans to boondock with the air > running > > Any thoughts? Anyone tried this with success or failure? > > Regards, > > Dorn Hetzel > 77FC35 > Hogansville, GA > > > [Non-text portions of this message have been removed] > |
