Another compressor problem
12-30-2007, 07:06
John, on my previous coach, 84 35FC, the air dryer was located in the middle
of the coach just inboard of the steps.
83PT40
-- Ocala, Fla
**************************************See AOL's top rated recipes
(http://food.aol.com/top-rated-recipes?NC...0000000004)
12-30-2007, 07:32
John, I believe that the 77 vintage birds did not have an air dryer. They
started incorporating them in the early 80s models. You should have a spitter
assembly attached to the bottom of your primary air tank. It spits air and oil
from it on a low volume basis. Sometimes makes a mess. You also should have a
valve at the bottom of all three air tanks that should be opened
occasionally to drain any moisture and oil that accumulates in the tanks.(Also
making a
mess).
Steve Anderson
79 FC 35
Currently wintering in Arizona
In a message dated 12/30/2007 4:53:08 P.M. US Mountain Standard Time,
jehdds@... writes:
Scott, Where would the air dryer be? I have an little gizmo which I
assumed was some kind of filter on the side of the compressor. Other
then that I don't know what I am looking for.
John Heckman
central Pa
1973 FC
> If you have an air dryer, check the relief valve, sometimes they
stick
> open. Often of you cover the outlet on the bottom with the palm of
> your hand with the engine running, it will fix itself for that
trip.
> If you find this happening, you need new relief valve.
> Scott Forman
> 86 PT38
> Memphis
> --- In _WanderlodgeForum@WanderlodgeFWan_
(mailto:WanderlodgeForum@yahoogroups.com) , "bubblerboy64"
> > Upon trying to take the son-in-law for a turn in the bus I found
that
> > the compressor would not bring the air up to release the brakes.
> > Checked and the belt is Ok and the compressors seems to be
turning
> Ok.
> > Is there a solenoid or a switch which activates and deactivates
> > compressor. I get about 30lbs on the air gauge but no more. The
only
> > other clue is that when the compressor is running normally it
makes
> > enough noise that I can hear it and it is not doing that. Don't
know
> > beans about what I am dealing with but any help or suggestions as
to
> > what to look at or for would certainly be appreciated.
> > John Heckman
> > central Pa
> > 1973 FC converted to 3208 CAT
12-30-2007, 11:07
Upon trying to take the son-in-law for a turn in the bus I found that
Checked and the belt is Ok and the compressors seems to be turning Ok.
Is there a solenoid or a switch which activates and deactivates the
compressor. I get about 30lbs on the air gauge but no more. The only
other clue is that when the compressor is running normally it makes
enough noise that I can hear it and it is not doing that. Don't know
beans about what I am dealing with but any help or suggestions as to
John Heckman
central Pa
12-30-2007, 11:15
If you have an air dryer, check the relief valve, sometimes they stick
your hand with the engine running, it will fix itself for that trip.
Scott Forman
86 PT38
Memphis
--- In WanderlodgeForum@yahoogroups.com, "bubblerboy64"
Ok.
> John Heckman
> central Pa
12-30-2007, 11:52
John Heckman
central Pa
1973 FC
stick
trip.
> Scott Forman
> 86 PT38
> Memphis
that
turning
> Ok.
only
makes
know
to
> > John Heckman
> > central Pa
12-30-2007, 12:19
Here's a nice booklet that fully describes how an air brake system
works:
<http://www.gnb.ca/0276/vehicle/pdf/ab_manual-e.pdf>
The air dryer is located between the "wet" and "dry" air systems. The
compressor will provide air to the wet air reservoir -- it then
passes through the air dryer to the dry air reservoir.
Most BBs use a Bendix AD-9 system -- a Google search will find some
photos. They look sort of like a big oil filter (but are attached to
the air lines).
If you're in cold weather, another common problem is for the step to
be 'stuck' in a partially extended position, sometimes this leaves
the air valve open and venting, keeping pressure from building up.
Pete Masterson
El Sobrante CA
aeonix1@...
> the middle
> Ernie Ekberg
> 83PT40
> Weatherford, Tx
> -- Ocala, Fla
12-30-2007, 13:20
Could be anywhere. On my 82 FC is was just about at the center
(length and width) of the underside. Your coach is older, it may not
have one. The dryer is the thing that makes the "pssshh" sound as it
spits air when the compressor reaches its governed PSI. Follow the
sound.
Scott
I
Other
> John Heckman
> central Pa
> 1973 FC
> stick
of
> trip.
> > Scott Forman
> > 86 PT38
> > Memphis
found
> that
brakes.
> turning
> > Ok.
> the
The
> only
> makes
Don't
> know
as
> to
> > > John Heckman
> > > central Pa
12-30-2007, 13:35
I believe that older coaches (older than 83'Wink mostly did not have a air
drier--
unless someone added one after the fact.
My 81 FC-33SB did not have one, however my friends 83' had one from the
factory.
I'm sure others may chime in on this, but I do think it was a factory
addition around 83.
Stephen H
81 FC-33SB Former owner- now looker!
Plant City, FL
> sound.
> Scott
> "bubblerboy64"
> I
> Other
> > John Heckman
> > central Pa
> > 1973 FC
> > stick
> of
> > trip.
> > > Scott Forman
> > > 86 PT38
> > > Memphis
> > > --- In
> "bubblerboy64"
> found
> > that
> brakes.
> > turning
> > > Ok.
> > the
> The
> > only
> > makes
> Don't
> > know
> as
> > to
> > > > John Heckman
> > > > central Pa
12-30-2007, 14:19
John,
The problem could also be the governor itself on the compressor,
which is an inexpensive fix, try tapping on it with a hammer,
sometimes they get a little moisture in there that in cold weather
freezes, or in my case it was rust, so I just changed it.
Make sure if you change it, to install a new one as they are only a
few more dollars than a remanufactured governor. Check out this page
on my web site for more information and the location of the governor
itself on an FC model 'Bird.
http://www.pbase.com/iamflagman/image/68481426
JOHN FINN
1982 FC35RB BLUEBIRD WANDERLODGE
HOPKINS, SOUTH CAROLINA
VISIT THE FINN'S INN EXPRESS REMODELING ADVENTURE AND TECH. TIPS
http://www.pbase.com/image/24977457
I'M SO SLOW ON THE HILLS,
THAT I GET TO SMELL THE FLOWERS AS I GO BY
.....AND WATCH THEM GROW TOO!!
REMEMBER 9/11
that
Ok.
only
know
to
> John Heckman
> central Pa
12-30-2007, 15:38
I know my '78 does not have an air dryer. I can usually tell by the
sound if my compressor is running/working as opposed to bypassing.
If yours is not working then I would suspect the governor. It is
unlikely that the compressor would fail suddenly.
Other problems may include broken/leaking air lines, failing
pressure regulators, or other leaks in the system. Since the front
and rear brake tanks should be independant, I would look for a leak
in the primary/wet tank circuits.
On my coach I found tons of oil sludge in the tanks and I suspect
no one ever drained them. The sludge caused some of the inline
regulators to stick and cause low pressure problems. Mine seemed to
clear up with repeated attempts to charge the system.
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, "John"
> John,
a
page
governor
> JOHN FINN
> REMEMBER 9/11
> that
turning
> Ok.
> only
makes
> know
as
> to
> > John Heckman
> > central Pa
