Fuel Pump Leak - 12.5 K Perkins Generator
01-14-2008, 16:31
Dear Friends:
On my roadtrip last summer, I discovered a fuel leak under my 12.5K
Perkins gen set. I traced the leak to the fuel pump on the geny.
There must be positive fuel pressure, because the leak developed with
the generator off! I'm not sure how much fuel I lost, but I plugged
the line, and have not used the generator since.
I actually bought a little Honda 2,000 watt generator that I have been
using to charge up the batteries - it even heats the water in my hot
water heater. And it hardly uses any fuel!
I'm hoping to replace the Perkins/Kohler fuel pump in the next few
weeks. I'm driving my coach to Punxsutawney, PA for Ground Hogs' Day.
I contacted Nixon Power Systems and provided them with the numbers on
the Geny. However, they are still having trouble identifying what
generator I have.
Might anybody know the part #s for the Perkins/Kohler fuel pump?
Also, might anybody know where I could get a copy of an owners or
parts manual for the geny? I bought my coach with a full box of
Bluebird documents, however, it included nothing for the generator.
Thanks everyone! Anybody else going to Punxsutawney?
Andy Coleman,
83' FC-35
Spring Lake Hts, NJ
01-14-2008, 17:13
Hi Andy,
Is the pump that is leaking the injector pump on the perkins??? If so I have had the same thing happen to me in October of last year... You do not need a new pump, you just have to take it off and ship it to a rebuilder, like Superior Diesel in SC... That is where I had mine repaired, it only cost $400 + shipping... John Finn had his done there also... They were very good... I had a problem with mine when I replaced after getting it back from them, it would not pump fuel... I was heading to Florida for a trip to Key West and did not need the genny so I went to their shop to see what was wrong with the pump... They worked on it for an hour, had to take it off and see what was wrong... Well it turned out to be that when I removed the pump to ship it to them I did not know about the shaft that was
in side the housing that runs the pump and I had lost it, luckily they had an extra one in the shop... Put it in, bled it and started right up... So if you take out the injector pump make sure you take out the shaft with it... For all the extra work and the shaft, they charged me $42... Cheap at twice the price...
HTH
Sea Ya
Larry
NYC
84 35FCSB
----- Original Message ----
To:
WanderlodgeForum@yahoogroups.com
Sent: Monday, January 14, 2008 11:31:33 PM
Subject: [WanderlodgeForum] Fuel Pump Leak - 12.5 K Perkins Generator
Dear Friends:
generator I have.
Andy Coleman,
83' FC-35
Spring Lake Hts, NJ
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. [url=http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR...o8Wcj9tAcJ ] Try it now.[/url]
01-14-2008, 19:37
Andy. If you need the fuel pump on the right side of the engine look on the front of the engine, i can't remember the right or left you will find the number of the perkins engine. With this number any perkins dealer will get you parts. It's been a while since i have needed parts and i can't remember the basic numbers. If you have a leak at the injector pump on the left front it can be rebuilt.
Paul Downey
Versailles Ky
83PT35
Our Rollin Home
Start the year off right. Easy ways to stay in shape in the new year.
