Chassis heat problems
03-02-2008, 13:06
Until a few days ago, my chassis heat was working fine, now it is dead.
The chassis heat on this coach is a lot simpler than has been described for many others. No summer/winter valves, no always-on Sporlans, no Webasto or Primus. The water system consists of a single Sporlan valve and a pump, both actuated by a slide switch in the cockpit (below the backup monitor controls). The valve should open and the pump turn on whenever the switch is in the Warm position and the ignition key is on. When this is done (engine off in order to hear things), there is a discernible click at the Sporlan, and the pump starts. After a few seconds, a circuit breaker can be heard to pop, and it goes off. Maybe ten seconds later the breaker resets and things run for a few seconds more. Question: Could this be a stuck Sporlan (pump blowing breaker because of back pressure)? I've looked through the various documents available and don't see a good way to test a Sporlan valve. Don Bradner 90 PT40 "Blue Thunder" Posting today by satellite from Pea Soup Andersen's, Santa Nella, CA |
03-02-2008, 13:16
I would be checking the pump first in case the impeller is gone and
jamming the motor Stephen 77fc35 with new pumps and sporlan kits in stock http://www.dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Until a few days ago, my chassis heat was working fine, now it is dead. > > The chassis heat on this coach is a lot simpler than has been described for many others. No summer/winter valves, no always-on Sporlans, no Webasto or Primus. > > The water system consists of a single Sporlan valve and a pump, both actuated by a slide switch in the cockpit (below the backup monitor controls). The valve should open and the pump turn on whenever the switch is in the Warm position and the ignition key is on. > > When this is done (engine off in order to hear things), there is a discernible click at the Sporlan, and the pump starts. After a few seconds, a circuit breaker can be heard to pop, and it goes off. Maybe ten seconds later the breaker resets and things run for a few seconds more. > > Question: Could this be a stuck Sporlan (pump blowing breaker because of back pressure)? I've looked through the various documents available and don't see a good way to test a Sporlan valve. > > Don Bradner > 90 PT40 "Blue Thunder" > Posting today by satellite from Pea Soup Andersen's, Santa Nella, CA > |
03-02-2008, 16:07
Don, Your theory sounds good. running the pump wet ,primed and
against a closed supply is like trying to get fuel out of an unvented tank. Wonder if it is just bearings in the pumps motor or crap in the impeller (which will screw the bearings anyway). I would pull the pump and bench test it maybe some one knows the amp dray it is designed to pull. if it pulls more on the bench with a goud source, chances are it is time for a new. If the Sporlan is a vacumn Diaphram valve they fail to close more often then fail to open. If it is a valve problem it may well be crap on the supply side of the sporlan or a screen doing what you describe to the pump. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Until a few days ago, my chassis heat was working fine, now it is dead. > > The chassis heat on this coach is a lot simpler than has been described for many others. No summer/winter valves, no always-on Sporlans, no Webasto or Primus. > > The water system consists of a single Sporlan valve and a pump, both actuated by a slide switch in the cockpit (below the backup monitor controls). The valve should open and the pump turn on whenever the switch is in the Warm position and the ignition key is on. > > When this is done (engine off in order to hear things), there is a discernible click at the Sporlan, and the pump starts. After a few seconds, a circuit breaker can be heard to pop, and it goes off. Maybe ten seconds later the breaker resets and things run for a few seconds more. > > Question: Could this be a stuck Sporlan (pump blowing breaker because of back pressure)? I've looked through the various documents available and don't see a good way to test a Sporlan valve. > > Don Bradner > 90 PT40 "Blue Thunder" > Posting today by satellite from Pea Soup Andersen's, Santa Nella, CA > |
03-02-2008, 16:36
Don: Have you checked to make sure your manual valves on the engine
are open. These valves are notorious for vibrating into a closed position. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Until a few days ago, my chassis heat was working fine, now it is dead. > > The chassis heat on this coach is a lot simpler than has been described for many others. No summer/winter valves, no always-on Sporlans, no Webasto or Primus. > > The water system consists of a single Sporlan valve and a pump, both actuated by a slide switch in the cockpit (below the backup monitor controls). The valve should open and the pump turn on whenever the switch is in the Warm position and the ignition key is on. > > When this is done (engine off in order to hear things), there is a discernible click at the Sporlan, and the pump starts. After a few seconds, a circuit breaker can be heard to pop, and it goes off. Maybe ten seconds later the breaker resets and things run for a few seconds more. > > Question: Could this be a stuck Sporlan (pump blowing breaker because of back pressure)? I've looked through the various documents available and don't see a good way to test a Sporlan valve. > > Don Bradner > 90 PT40 "Blue Thunder" > Posting today by satellite from Pea Soup Andersen's, Santa Nella, CA > |
03-02-2008, 17:21
Yes, someone has nylon-tied them open.
On 3/3/2008 at 4:36 AM ronmarabito2002 wrote: >Don: Have you checked to make sure your manual valves on the engine >are open. These valves are notorious for vibrating into a closed >position. > >R.E. (Ron) Marabito, Dallas, TX 92WB40 > >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > >> >> Until a few days ago, my chassis heat was working fine, now it is dead. >> >> The chassis heat on this coach is a lot simpler than has been >described for many others. No summer/winter valves, no always-on >Sporlans, no Webasto or Primus. >> >> The water system consists of a single Sporlan valve and a pump, both >actuated by a slide switch in the cockpit (below the backup monitor >controls). The valve should open and the pump turn on whenever the >switch is in the Warm position and the ignition key is on. >> >> When this is done (engine off in order to hear things), there is a >discernible click at the Sporlan, and the pump starts. After a few >seconds, a circuit breaker can be heard to pop, and it goes off. Maybe >ten seconds later the breaker resets and things run for a few seconds >more. >> >> Question: Could this be a stuck Sporlan (pump blowing breaker >because of back pressure)? I've looked through the various documents >available and don't see a good way to test a Sporlan valve. >> >> Don Bradner >> 90 PT40 "Blue Thunder" >> Posting today by satellite from Pea Soup Andersen's, Santa Nella, CA >> > > > > > >Yahoo! Groups Links > > > |
03-14-2008, 12:27
Revisting this one: As far as I can tell, the pump and sporlan valve are
functioning correctly (can see the pump, and took the valve apart, at which point I can observe that the pump is pumping). The slide switch that controls heat is attached to a circuit board that is a timer circuit. Output is either +12V, or nothing, and the further to the right you move it the longer the on-cycle lasts. There is no full-on condition. The cycling I heard appears to be normal, and what I thought was a breaker is a relay, #12 in the front nose panel. I was alerted me to the presence of another valve, located under the top front step. It is difficult to reach, and I investigated it using a camera. I can put a hand on it, and there is no obvious vibration or sound when the relay kicks the other valve and the pump cycles. The valve does not exactly match what was described, but it is certainly in the water line to the front heater core. There may not be any decent way to test it except by pulling it out, not a fun job. Picture of the valve at http://www.arcatapet.net/image/heatvalve.jpg On 3/2/2008 at 5:06 PM Don Bradner wrote: >Until a few days ago, my chassis heat was working fine, now it is dead. > >The chassis heat on this coach is a lot simpler than has been described >for many others. No summer/winter valves, no always-on Sporlans, no >Webasto or Primus. > >The water system consists of a single Sporlan valve and a pump, both >actuated by a slide switch in the cockpit (below the backup monitor >controls). The valve should open and the pump turn on whenever the switch >is in the Warm position and the ignition key is on. > >When this is done (engine off in order to hear things), there is a >discernible click at the Sporlan, and the pump starts. After a few >seconds, a circuit breaker can be heard to pop, and it goes off. Maybe ten >seconds later the breaker resets and things run for a few seconds more. > >Question: Could this be a stuck Sporlan (pump blowing breaker because of >back pressure)? I've looked through the various documents available and >don't see a good way to test a Sporlan valve. > >Don Bradner >90 PT40 "Blue Thunder" >Posting today by satellite from Pea Soup Andersen's, Santa Nella, CA > > > > > >Yahoo! Groups Links > > > |
03-14-2008, 17:25
Could be the pump works when not held against a closed loop???? maybe
the return line is simply plugged up. or your fan is staying on, and the detroit isnt getting hot?? The camera trick is one CurtS taught me to do. I have even taken 10 meg picks of part labels then was able to read them on the computer screen. When you look at all the controls and appliances exposed to the weather on these rigs it is a wonder that anything works. GregoryO'Connor 94ptRomolandCa |
03-14-2008, 18:10
My concern is that the front valve may be the plug in the loop, if it is not
opening. Temperature of the engine is not an issue - I ran it at idle today up to about 160 so that I would have it warm enough to be sure to feel the heat. All lines stayed cold, including the top of the pump, until I allowed the pump to run open via the dismantled Sporlan. Only took a couple of quarts of coolant spilled to heat up everything through the pump to the valve. On 3/15/2008 at 4:25 AM Gregory OConnor wrote: >Could be the pump works when not held against a closed loop???? maybe >the return line is simply plugged up. or your fan is staying on, and >the detroit isnt getting hot?? > >The camera trick is one CurtS taught me to do. I have even taken 10 >meg picks of part labels then was able to read them on the computer >screen. > >When you look at all the controls and appliances exposed to the >weather on these rigs it is a wonder that anything works. > >GregoryO'Connor >94ptRomolandCa |
03-14-2008, 18:52
If you cant remove the valve maybe try and bypass it to see that
that is the problem first???? KevinMk did that with a remote air regulator or somthing???? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > My concern is that the front valve may be the plug in the loop, if it is not opening. Temperature of the engine is not an issue - I ran it at idle today up to about 160 so that I would have it warm enough to be sure to feel the heat. All lines stayed cold, including the top of the pump, until I allowed the pump to run open via the dismantled Sporlan. Only took a couple of quarts of coolant spilled to heat up everything through the pump to the valve. > > On 3/15/2008 at 4:25 AM Gregory OConnor wrote: > > >Could be the pump works when not held against a closed loop???? maybe > >the return line is simply plugged up. or your fan is staying on, and > >the detroit isnt getting hot?? > > > >The camera trick is one CurtS taught me to do. I have even taken 10 > >meg picks of part labels then was able to read them on the computer > >screen. > > > >When you look at all the controls and appliances exposed to the > >weather on these rigs it is a wonder that anything works. > > > >GregoryO'Connor > >94ptRomolandCa > |
03-15-2008, 12:45
Well, it is back to the drawing board. The valve has been removed and replaced,
and the voltage tested. What I learned: The valve up front is a normally-open valve, closed by power coming from the timing circuit. Plus 12 volts is fed down to the valve, then back through another wire to (somewhere) that gets power to the #12 relay. When the relay is powered, there is no power to the circulation pump or the Sporlan valve. So, power on, both valves are closed, one by the presence of power, the other by the absence of power, and the pump is off. When the valve was re-installed I left the power connection off, so the valve was open (bench test had shown it working, and it was left in the open position). When the key was turned on, the Sporlan opened, and the pump ran continuously. The pump never faltered, but nothing in the system got even warm to the touch (outside temp in the 40s, engine about 160). I pulled the top of the pump off and managed to lose about 4 gallons of coolant in the process - certainly the supply side of the pump is unobstructed! Replaced the gasket and reassembled, after ascertaining that the pump runs well and there is no damage to any of the impellor blades. Both gate valves are wide open, which I assume is the correct setting (and I presume they should have been closed before I messed with the pump!) Looking for new possiblities, if anyone has any ideas. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 3/15/2008 at 5:52 AM Gregory OConnor wrote: >If you cant remove the valve maybe try and bypass it to see that >that is the problem first???? KevinMk did that with a remote air >regulator or somthing???? >GregoryO'Connor >94ptRomolandCa > >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > >> >> My concern is that the front valve may be the plug in the loop, if >it is not opening. Temperature of the engine is not an issue - I ran >it at idle today up to about 160 so that I would have it warm enough >to be sure to feel the heat. All lines stayed cold, including the >top of the pump, until I allowed the pump to run open via the >dismantled Sporlan. Only took a couple of quarts of coolant spilled >to heat up everything through the pump to the valve. >> >> On 3/15/2008 at 4:25 AM Gregory OConnor wrote: >> >> >Could be the pump works when not held against a closed loop???? >maybe >> >the return line is simply plugged up. or your fan is staying on, >and >> >the detroit isnt getting hot?? >> > >> >The camera trick is one CurtS taught me to do. I have even taken >10 >> >meg picks of part labels then was able to read them on the >computer >> >screen. >> > >> >When you look at all the controls and appliances exposed to the >> >weather on these rigs it is a wonder that anything works. >> > >> >GregoryO'Connor >> >94ptRomolandCa >> > > > >------------------------------------ > >Yahoo! Groups Links > > > |
