Suspect: Mr Donut Charge: Tire Abuse Verdict: Guilty or Not Guilty?
05-17-2005, 07:18
Hay Bob can you get that hammer to straiten your wife out if she's giving to
much trouble about your driving habits also? Jon
freewill2008 wrote: I like to check tire pressure regularly
with a gauge, but an even
quicker way to prevent driving off with a soft rear tire is the
hammer trick that is quickly learned by watching truckers at a rest
stop. Bounce a 3-4 pound hammer off the tread a few times and you
will quickly learn when the rebound is "soft".
This is not a substitute for maintaining the correct pressure with a
gauge, but since it is fast and convenient it can keep you from
missing a soft tire. It also makes you walk around the vehicle and
observe everything else.
Bob Griesel '84 FC31 WLII WA
--- In WanderlodgeForum@yahoogroups.com, "mrdonut12"
> I had tire pressure problems from the day I got my bird, a year and
> a half ago. I was constantly airing up the tires. They'd lose a
few
> pounds a day.
> The fronts were new and no problem. The rears were Michelin
> 11R 22.5 LRH and lost air. I went to a truck tire place last Fall
> had all the valve stems replaced and that fixed the leaks. I rarely
> had to add air after that.
> Took a trip a month ago and aired tires before I left.
> Went 1400 miles round trip. Tires were fine. I always check
> tire temp when I stop. No problems.
> Left for a 170 mile trip Friday, didn't check tires before I
> left. Mistake #1, won't make that one again. ;o)
> 23 miles into the trip, wife wants front heater turned on. I
> have to crawl under front to open valve. Notice right rear inner
> dual appears to be flat. It is!
> Air it up from on-board compressor, have new hose and tire
guage.
> It was flat. Zero pressure. Push in sidewall easily with hand.
Flat.
> Checked it with soapy water. No leaks found. Held air fine
> for the next 2 days.
> Cause for low pressure unknown, no cause can be found, unless
> someone let the air out, in which case they laid there for nearly a
> half an hour, pushing in the valve stem.
> The question is, these are 4 years old, due to be replaced next
> Fall. Have I damaged the tires with my actions? I'd rather wait
> until Fall to buy tires. I need to drive to Rhode Island in June.
> So, Guilty or Not Guilty?
> George Witt
> 81 FC 35 WLSB
> Lincoln, Nebraska--Huskers
Yahoo! Groups Links
One of my favorite sayings goes! "You never own anything, everything owns you!"
Yahoo! Mail Mobile
Take Yahoo! Mail with you! Check email on your mobile phone.
05-18-2005, 01:31
Even better, try these:
http://www.alltiresupply.com/Merchant2/m...DMHI-\
F9A1AK810C1&Product_Code=43-098&Category_Code=
If that long URL does not work, try this one: http://tinyurl.com/ck4fl
Checking tire pressures was never eaiser. No more excuses for not
checking pressures. I've been using mine for a few months now and
love them.
- Rick
87FC35
Rochester, MN
--- In WanderlodgeForum@yahoogroups.com, "freewill2008"
> I like to check tire pressure regularly with a gauge, but an even
05-18-2005, 01:37
I've had them on two coaches. They work great.
<http://www.alltiresupply.com/Merchant2/m...MDMHI\
-F9A1AK810C1&Product_Code=43-098&Category_Code=>
> love them.
> - Rick
> 87FC35
> Rochester, MN
