Wireless rear cameras?
05-18-2008, 12:12
A prior owner of Blue Thunder replaced the camera inside. The window was not
replaced (why would you want to?). A block of wood was used to make the much tinier new camera sit correctly where the old one had been. Don Bradner 90 PT40 "Blue Thunder" Posting today by satellite from Jantzen Beach RV Park, Portland, OR On 5/18/2008 at 4:43 PM Ryan Wright wrote: >While we're talking cameras, has anyone replaced the inside-mounted >factory camera with another inside-mounted cam? A previous owner of my >coach removed the original and bolted a different camera outside. I >don't like the camera hanging off the coach and prefer the sleekness >of the factory camera-behind-the-window idea. > >Any thoughts on this project would be nice. I haven't looked at it >yet, but I presume I could just replace the little camera window and >mount a good camera behind it and be pretty well set. Though, it seems >like others are not retaining the inside-camera idea and I'm wondering >why? > >-Ryan >'86 PT-40 8V92 |
05-18-2008, 12:22
Ryan,
I recently experimented with this and removed the original RCA and replaced it with a color IR camera. I knew going in that the IR LEDs would be a problem because they reflect off the camera window. Therefore, the system does not work in the dark as it was designed to. However, It does a pretty good job during the day for an inexpensive system. This installation required fishing a new proprietary cable from the control unit at the front of the coach along the drivers side. I am new to this whole coach thing. I think my night driving will be minimal so I will live with this limitation for now. I am still searching for a method to keep the camera behind the glass and gain the night vision function... this may not be possible. Bill in NH 1983 FC 35 -- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > While we're talking cameras, has anyone replaced the inside-mounted > factory camera with another inside-mounted cam? A previous owner of my > coach removed the original and bolted a different camera outside. I > don't like the camera hanging off the coach and prefer the sleekness > of the factory camera-behind-the-window idea. > > Any thoughts on this project would be nice. I haven't looked at it > yet, but I presume I could just replace the little camera window and > mount a good camera behind it and be pretty well set. Though, it seems > like others are not retaining the inside-camera idea and I'm wondering > why? > > -Ryan > '86 PT-40 8V92 > > On Sun, May 18, 2008 at 4:29 PM, bubblerboy64 > > > > Don, I took your suggestion and removed the middle light. I ran a > > piece of parachute cord from that spot thru the coach up to the > > monitor location. I built myself a bracket to mount the monitor. > > When the electronics shows up hopefully the rest will be a cake walk. > > Never seems like it works out that way but to this point it's gone > > well. > > > |
05-18-2008, 12:30
Ryan
My 79 33' didn't have a factory camera installed so it didn't have the window or the recessed place to install one. If you mount a camera with night vision inside it will not work as good if mounted on the outside. That is what I have been told. Don Spithaler 89 SP 36' Butler, PA On Sun, May 18, 2008 at 7:43 PM, Ryan Wright <"ryanpwright@gmail.com"> wrote:
05-18-2008, 13:32
I replaced my inside camera with this see in the dark camera. http://www.owlseyecamera.com. I used existing cables and changed a couple of connectors. I removed my old monster TV set monitor(still have it, don't know if it works) and used two 3.5" LCD's and added a right side camera from Birtles and all is well. See Photo's in the section. I got the LCD's at http://www.lcdshow.com. I have about $650 in a system that works great even at night.
Leroy Eckert 1990WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion Ryan Wright
05-18-2008, 14:47
Thank you for the replies on this, everyone. I'm going to check out
that Owls Eye Camera, sounds nice. Did you just email or call them to buy it? I don't see an order form on their web site. -Ryan On Sun, May 18, 2008 at 6:32 PM, Leroy Eckert > > I replaced my inside camera with this see in the dark camera. > http://www.owlseyecamera.com. I used existing cables and changed a couple of > connectors. I removed my old monster TV set monitor(still have it, don't > know if it works) and used two 3.5" LCD's and added a right side camera from > Birtles and all is well. See Photo's in the section. I got the LCD's at > http://www.lcdshow.com. I have about $650 in a system that works great even at > night. > > Leroy Eckert > 1990WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > |
05-18-2008, 17:14
We also sell rv cameras and monitors both rear and right hand side
Stephen 77fc35 dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Thank you for the replies on this, everyone. I'm going to check out > that Owls Eye Camera, sounds nice. Did you just email or call them to > buy it? I don't see an order form on their web site. > > -Ryan > > On Sun, May 18, 2008 at 6:32 PM, Leroy Eckert > > > > I replaced my inside camera with this see in the dark camera. > > http://www.owlseyecamera.com. I used existing cables and changed a couple of > > connectors. I removed my old monster TV set monitor(still have it, don't > > know if it works) and used two 3.5" LCD's and added a right side camera from > > Birtles and all is well. See Photo's in the section. I got the LCD's at > > http://www.lcdshow.com. I have about $650 in a system that works great even at > > night. > > > > Leroy Eckert > > 1990WB-40 Smoke N Mirrors > > Dahlonega, GA > > Royale Conversion > > > |
05-18-2008, 17:17
> > We also sell rv moniotrs and cameras both rear and right hand side > Stephen 77fc35 > dupreeproducts.com > > > > --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > > > > Thank you for the replies on this, everyone. I'm going to check out > > that Owls Eye Camera, sounds nice. Did you just email or call them to > > buy it? I don't see an order form on their web site. > > > > -Ryan > > > > On Sun, May 18, 2008 at 6:32 PM, Leroy Eckert > > > > > > I replaced my inside camera with this see in the dark camera. > > > http://www.owlseyecamera.com. I used existing cables and changed a couple of > > > connectors. I removed my old monster TV set monitor(still have it, > don't > > > know if it works) and used two 3.5" LCD's and added a right side > camera from > > > Birtles and all is well. See Photo's in the section. I got the > LCD's at > > > http://www.lcdshow.com. I have about $650 in a system that works great > even at > > > night. > > > > > > Leroy Eckert > > > 1990WB-40 Smoke N Mirrors > > > Dahlonega, GA > > > Royale Conversion > > > > > > |
05-18-2008, 23:59
I called them for details because at the time is was very new technology on the market.
Ryan Wright
Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Dahlonega, GA Royale Conversion |
05-19-2008, 00:01
The camera Stephen sells works great to even at night.
Stephen Birtles
05-27-2008, 16:47
I just put in a new camera, used one that I got on
Ebay that just fit in the opening in the bezel. A few small angle bracket to hold it in and it looks pretty good. No problems with reflections cause its mounted to the outside... One thing, on my '87 PT the 'window' was plastic and so worn and frosted you couldnt see through it! Replaced the CRT monitor with a LCD (also from Ebay) and now have color for the rear view :} Ive got photos if anyone is interested... /Joe '87 PT40 San Francisco Scott Forman wrote: > > > Ryan, > > Been there, done that. If you use a night vision camera with the > little IR "lights", it will be useless at night as all you can see on > the monitor is glare of the IR's on the window. However, there is a > solution: 1) Buy a non-IR camera (hard to find), or 2) cover the IR's > with electrical tape. I did option 2. The camera couldn't see in > the dark, but it was still better at night than the original one. > This was on my 82 FC. > > I am going to do something with my 86 PT, not sure what yet. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@ yahoogroups. com > > > > > > While we're talking cameras, has anyone replaced the inside-mounted > > factory camera with another inside-mounted cam? A previous owner of > my > > coach removed the original and bolted a different camera outside. I > > don't like the camera hanging off the coach and prefer the sleekness > > of the factory camera-behind- the-window idea. > > > > Any thoughts on this project would be nice. I haven't looked at it > > yet, but I presume I could just replace the little camera window and > > mount a good camera behind it and be pretty well set. Though, it > seems > > like others are not retaining the inside-camera idea and I'm > wondering > > why? > > > > -Ryan > > '86 PT-40 8V92 > > > > On Sun, May 18, 2008 at 4:29 PM, bubblerboy64 > > > > > > Don, I took your suggestion and removed the middle light. I ran a > > > piece of parachute cord from that spot thru the coach up to the > > > monitor location. I built myself a bracket to mount the monitor. > > > When the electronics shows up hopefully the rest will be a cake > walk. > > > Never seems like it works out that way but to this point it's > gone > > > well. > > > > > > |
