Roof air parts?
05-31-2008, 08:56
Roof air parts?
Scott, I had a roof air electric motor go out as you describe. These are common motors and any well known electric motor shop- like Graingers , as Bob loomas said,can duplicate it. I believe it was around a hundred bucks. The motor has a few wires, and as Ralph suggested, get some numbers you can stick on those wires.
83PT40
Livingston, Montana
Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food.
05-31-2008, 09:24
Roof air parts?
My coach has all three original roof airs. When the plastic cowl is
removed on the roof, there is a small electric motor that is connected
to a shaft that turns the fan that blows air over the coils. On one of
my units, that shaft corroded to the point that it finally broke off
right at the fan hub. As a result, the A/C will no longer cool. One
of my other units has the same problem developing, as it appears that
its shaft may break off soon (getting thin).
My question is...is there a part I can replace? The motor spins fine,
can the shaft be removed from the motor and replaced? Or, if not, can
the motor/shaft assembly be replaced? Or am I looking at replacing 2
A/C's?
Scott Forman
86 PT38
Memphis
05-31-2008, 10:20
Roof air parts?
If it were me I would try and match it up at Grainger.
Bob Loomas 1985 PT 36
Harahan La.
is
connected
one of
off
One
that
fine,
can
2
> A/C's?
> Scott Forman
> 86 PT38
> Memphis
05-31-2008, 10:24
Roof air parts?
Is the shaft removable or do I have to find a motor assembly?
Scott
--- In WanderlodgeForum@yahoogroups.com, "robert nloomas"
<bbpt36@...> wrote:
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@>
> Harahan La.
> is
> connected
> one of
> off
> One
> that
> fine,
not,
> can
replacing
> 2
> > A/C's?
> > Scott Forman
> > 86 PT38
> > Memphis
05-31-2008, 12:18
Roof air parts?
I ment to add to my last post to replace the motor. the motor is
common with the double ended shaft.
Bob Loomas PT 36 85
Harahan La.
> Scott
<sforman@>
> > Harahan La.
cowl
> > is
> > connected
On
> > one of
broke
> > off
cool.
> > One
appears
> > that
spins
> > fine,
> not,
> > can
> replacing
> > 2
> > > A/C's?
> > > Scott Forman
> > > 86 PT38
> > > Memphis
05-31-2008, 13:04
Roof air parts?
These are "Penguin" (low profile) units by Duo-Therm. Must be a
source of parts out there somewhere.
I replaced two of my three roof-airs with "high efficiency" Duo-Therm
units. These don't have the low profile (but my King Dome sticks up
higher anyway) -- however they only draw 10 amps instead of 14.5 as
the originals with the same rated BTUs. Got'em on sale at Camping
World over a year ago.
Pete Masterson
aeonix1@...
On the road at CCW in RIverside, CA
> one of
> A/C's?
> Scott Forman
> 86 PT38
> Memphis
06-01-2008, 04:47
Roof air parts?
Scott, if memory serves me, probably not, but there should be an allen wrench set screw on that squirrel cage.
83PT40
Livingston, Montana
06-01-2008, 07:31
Roof air parts?
We can order the dometic parts we are a service facility
Give me call
I need the model and serial number of the unit
Stephen 77fc35
Dupreeproducts .com
> Pete Masterson
> aeonix1@...
> > one of
> > A/C's?
> > Scott Forman
> > 86 PT38
> > Memphis
06-01-2008, 08:21
Roof air parts?
There is a squirrel cage fan on the other shaft...how do I get that
off? I opened up the unit, not much access...
Scott
> Bob Loomas PT 36 85
> Harahan La.
> > Scott
> <sforman@>
> > > Harahan La.
> cowl
> > > is
> > > connected
> On
> > > one of
> broke
> > > off
> cool.
> > > One
> appears
> > > that
> spins
> > > fine,
> > not,
> > > can
> > replacing
> > > 2
> > > > A/C's?
> > > > Scott Forman
> > > > 86 PT38
> > > > Memphis
