Roof air parts?
05-31-2008, 08:56
Roof air parts?
Scott, I had a roof air electric motor go out as you describe. These are common motors and any well known electric motor shop- like Graingers , as Bob loomas said,can duplicate it. I believe it was around a hundred bucks. The motor has a few wires, and as Ralph suggested, get some numbers you can stick on those wires.
Ernie Ekberg 83PT40 Livingston, Montana Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food. |
05-31-2008, 09:24
Roof air parts?
My coach has all three original roof airs. When the plastic cowl is
removed on the roof, there is a small electric motor that is connected to a shaft that turns the fan that blows air over the coils. On one of my units, that shaft corroded to the point that it finally broke off right at the fan hub. As a result, the A/C will no longer cool. One of my other units has the same problem developing, as it appears that its shaft may break off soon (getting thin). My question is...is there a part I can replace? The motor spins fine, can the shaft be removed from the motor and replaced? Or, if not, can the motor/shaft assembly be replaced? Or am I looking at replacing 2 A/C's? Scott Forman 86 PT38 Memphis |
05-31-2008, 10:20
Roof air parts?
wrote: If it were me I would try and match it up at Grainger. Bob Loomas 1985 PT 36 Harahan La. > > My coach has all three original roof airs. When the plastic cowl is > removed on the roof, there is a small electric motor that is connected > to a shaft that turns the fan that blows air over the coils. On one of > my units, that shaft corroded to the point that it finally broke off > right at the fan hub. As a result, the A/C will no longer cool. One > of my other units has the same problem developing, as it appears that > its shaft may break off soon (getting thin). > > My question is...is there a part I can replace? The motor spins fine, > can the shaft be removed from the motor and replaced? Or, if not, can > the motor/shaft assembly be replaced? Or am I looking at replacing 2 > A/C's? > > Scott Forman > 86 PT38 > Memphis > |
05-31-2008, 10:24
Roof air parts?
Is the shaft removable or do I have to find a motor assembly?
Scott --- In WanderlodgeForum@yahoogroups.com, "robert nloomas" <bbpt36@...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > If it were me I would try and match it up at Grainger. > Bob Loomas 1985 PT 36 > Harahan La. > > > > > > > > > > > > My coach has all three original roof airs. When the plastic cowl > is > > removed on the roof, there is a small electric motor that is > connected > > to a shaft that turns the fan that blows air over the coils. On > one of > > my units, that shaft corroded to the point that it finally broke > off > > right at the fan hub. As a result, the A/C will no longer cool. > One > > of my other units has the same problem developing, as it appears > that > > its shaft may break off soon (getting thin). > > > > My question is...is there a part I can replace? The motor spins > fine, > > can the shaft be removed from the motor and replaced? Or, if not, > can > > the motor/shaft assembly be replaced? Or am I looking at replacing > 2 > > A/C's? > > > > Scott Forman > > 86 PT38 > > Memphis > > > |
05-31-2008, 12:18
Roof air parts?
wrote: I ment to add to my last post to replace the motor. the motor is common with the double ended shaft. Bob Loomas PT 36 85 Harahan La. > > Is the shaft removable or do I have to find a motor assembly > > Scott > > --- In WanderlodgeForum@yahoogroups.com, "robert nloomas" > <bbpt36@> wrote: > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > > wrote: > > If it were me I would try and match it up at Grainger. > > Bob Loomas 1985 PT 36 > > Harahan La. > > > > > > > > > > > > > > > > > > > > > > My coach has all three original roof airs. When the plastic cowl > > is > > > removed on the roof, there is a small electric motor that is > > connected > > > to a shaft that turns the fan that blows air over the coils. On > > one of > > > my units, that shaft corroded to the point that it finally broke > > off > > > right at the fan hub. As a result, the A/C will no longer cool. > > One > > > of my other units has the same problem developing, as it appears > > that > > > its shaft may break off soon (getting thin). > > > > > > My question is...is there a part I can replace? The motor spins > > fine, > > > can the shaft be removed from the motor and replaced? Or, if > not, > > can > > > the motor/shaft assembly be replaced? Or am I looking at > replacing > > 2 > > > A/C's? > > > > > > Scott Forman > > > 86 PT38 > > > Memphis > > > > > > |
05-31-2008, 13:04
Roof air parts?
These are "Penguin" (low profile) units by Duo-Therm. Must be a
source of parts out there somewhere. I replaced two of my three roof-airs with "high efficiency" Duo-Therm units. These don't have the low profile (but my King Dome sticks up higher anyway) -- however they only draw 10 amps instead of 14.5 as the originals with the same rated BTUs. Got'em on sale at Camping World over a year ago. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at CCW in RIverside, CA On May 31, 2008, at 2:24 PM, Scott Forman wrote: > My coach has all three original roof airs. When the plastic cowl is > removed on the roof, there is a small electric motor that is connected > to a shaft that turns the fan that blows air over the coils. On > one of > my units, that shaft corroded to the point that it finally broke off > right at the fan hub. As a result, the A/C will no longer cool. One > of my other units has the same problem developing, as it appears that > its shaft may break off soon (getting thin). > > My question is...is there a part I can replace? The motor spins fine, > can the shaft be removed from the motor and replaced? Or, if not, can > the motor/shaft assembly be replaced? Or am I looking at replacing 2 > A/C's? > > Scott Forman > 86 PT38 > Memphis > |
06-01-2008, 04:47
Roof air parts?
Scott, if memory serves me, probably not, but there should be an allen wrench set screw on that squirrel cage.
06-01-2008, 07:31
Roof air parts?
We can order the dometic parts we are a service facility
Give me call I need the model and serial number of the unit Stephen 77fc35 Dupreeproducts .com --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > These are "Penguin" (low profile) units by Duo-Therm. Must be a > source of parts out there somewhere. > > I replaced two of my three roof-airs with "high efficiency" Duo-Therm > units. These don't have the low profile (but my King Dome sticks up > higher anyway) -- however they only draw 10 amps instead of 14.5 as > the originals with the same rated BTUs. Got'em on sale at Camping > World over a year ago. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at CCW in RIverside, CA > > > > On May 31, 2008, at 2:24 PM, Scott Forman wrote: > > > My coach has all three original roof airs. When the plastic cowl is > > removed on the roof, there is a small electric motor that is connected > > to a shaft that turns the fan that blows air over the coils. On > > one of > > my units, that shaft corroded to the point that it finally broke off > > right at the fan hub. As a result, the A/C will no longer cool. One > > of my other units has the same problem developing, as it appears that > > its shaft may break off soon (getting thin). > > > > My question is...is there a part I can replace? The motor spins fine, > > can the shaft be removed from the motor and replaced? Or, if not, can > > the motor/shaft assembly be replaced? Or am I looking at replacing 2 > > A/C's? > > > > Scott Forman > > 86 PT38 > > Memphis > > > |
06-01-2008, 08:21
Roof air parts?
There is a squirrel cage fan on the other shaft...how do I get that
off? I opened up the unit, not much access... Scott --- In WanderlodgeForum@yahoogroups.com, "robert nloomas" <bbpt36@...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > I ment to add to my last post to replace the motor. the motor is > common with the double ended shaft. > Bob Loomas PT 36 85 > Harahan La. > > > > Is the shaft removable or do I have to find a motor assembly > > > > Scott > > > > --- In WanderlodgeForum@yahoogroups.com, "robert nloomas" > > <bbpt36@> wrote: > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > <sforman@> > > > wrote: > > > If it were me I would try and match it up at Grainger. > > > Bob Loomas 1985 PT 36 > > > Harahan La. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > My coach has all three original roof airs. When the plastic > cowl > > > is > > > > removed on the roof, there is a small electric motor that is > > > connected > > > > to a shaft that turns the fan that blows air over the coils. > On > > > one of > > > > my units, that shaft corroded to the point that it finally > broke > > > off > > > > right at the fan hub. As a result, the A/C will no longer > cool. > > > One > > > > of my other units has the same problem developing, as it > appears > > > that > > > > its shaft may break off soon (getting thin). > > > > > > > > My question is...is there a part I can replace? The motor > spins > > > fine, > > > > can the shaft be removed from the motor and replaced? Or, if > > not, > > > can > > > > the motor/shaft assembly be replaced? Or am I looking at > > replacing > > > 2 > > > > A/C's? > > > > > > > > Scott Forman > > > > 86 PT38 > > > > Memphis > > > > > > > > > > |
