Altimeter repair
06-04-2008, 12:14
Altimeter repair
Hi group,
Pulled out the altimeter as not very accurate. Would have hated to have flown with this unit as it's 800 feet low. I know I could send it to an FAA licensed repair for bigger bucks, but was wondering if anybody has sent theirs somewhere that was reasonable. Bob Lawrence 84 PT36 Workcamping in Branson, Mo. |
06-04-2008, 12:19
Altimeter repair
Bob:
I had one done at an instrument shop at Boeing Field for $70.00. They cleaned it and check it's calibration. They didn't certify it for flying by I don't expect my Bird to get too far off the ground. They said it was within 10 to 15 feet at all altitudes up to 12,000. You might want to talk to a local instrument shop. Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Hi group, > > Pulled out the altimeter as not very accurate. Would have hated to have > flown with this unit as it's 800 feet low. > > I know I could send it to an FAA licensed repair for bigger bucks, but > was wondering if anybody has sent theirs somewhere that was reasonable. > > Bob Lawrence > 84 PT36 > Workcamping in Branson, Mo. > |
06-04-2008, 12:42
Altimeter repair
Bob,
Don't forget to check the altimeter setting. Should be local barometric pressure if I remember right. Can also set the altimeter to show a known altitude and cross check to local barometer. Dave Bob: I had one done at an instrument shop at Boeing Field for $70.00. They cleaned it and check it's calibration. They didn't certify it for flying by I don't expect my Bird to get too far off the ground. They said it was within 10 to 15 feet at all altitudes up to 12,000. You might want to talk to a local instrument shop. Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Hi group, > > Pulled out the altimeter as not very accurate. Would have hated to have > flown with this unit as it's 800 feet low. > > I know I could send it to an FAA licensed repair for bigger bucks, but > was wondering if anybody has sent theirs somewhere that was reasonable. > > Bob Lawrence > 84 PT36 > Workcamping in Branson, Mo. > |
06-04-2008, 13:06
Altimeter repair
Hi Marv,
Yeah, I should have pulled it out while in Lakewood, but to busy. No have the time and no local airport here in Branson. Glad you had a good time in Tokeland. Enjoy the rain up there..lol Bob Lawrence 84 PT36 Workcamping in Branson, Mo. > Bob: > > I had one done at an instrument shop at Boeing Field for $70.00. > They cleaned it and check it's calibration. They didn't certify it > for flying by I don't expect my Bird to get too far off the ground. > They said it was within 10 to 15 feet at all altitudes up to 12,000. > > You might want to talk to a local instrument shop. > > Marv > 2004 M380 > Ocean Shores, WA > > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > > Hi group, > > > > Pulled out the altimeter as not very accurate. Would have hated to > have > > flown with this unit as it's 800 feet low. > > > > I know I could send it to an FAA licensed repair for bigger bucks, > but > > was wondering if anybody has sent theirs somewhere that was > reasonable. > > > > Bob Lawrence > > 84 PT36 > > Workcamping in Branson, Mo. > > > |
06-04-2008, 14:07
Altimeter repair
cross check the altitude with your GPS, set the altimeter to match,
then see how it goes. As indicated, barometric pressure can cause considerable variation. Indeed, since my coach just has a big empty spot marked "altimeter" I just look at the GPS when I'm curious about the altitude. It's usually pretty accurate. I note that when flying out of small airfields (that didn't have accurate barometric reports) that we'd set the altimeter to the local posted field altitude. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jun 4, 2008, at 5:42 PM, Dave Erickson wrote: > Bob, > > Don't forget to check the altimeter setting. Should be local > barometric > pressure if I remember right. > > Can also set the altimeter to show a known altitude and cross check > to local > barometer. > > Dave > > > > Bob: > > I had one done at an instrument shop at Boeing Field for $70.00. > They cleaned it and check it's calibration. They didn't certify it > for flying by I don't expect my Bird to get too far off the ground. > They said it was within 10 to 15 feet at all altitudes up to 12,000. > > You might want to talk to a local instrument shop. > > Marv > 2004 M380 > Ocean Shores, WA > > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > >> >> Hi group, >> >> Pulled out the altimeter as not very accurate. Would have hated to > have >> flown with this unit as it's 800 feet low. >> >> I know I could send it to an FAA licensed repair for bigger bucks, > but >> was wondering if anybody has sent theirs somewhere that was > reasonable. >> >> Bob Lawrence >> 84 PT36 >> Workcamping in Branson, Mo. >> > > > > ------------------------------------ > > Yahoo! Groups Links > > > |
06-05-2008, 08:26
Altimeter repair
Bob, it always amuses me when I go to get a part and tell them what it goes into. The look on their faces are-- well priceless.
Ernie Ekberg 83PT40 Livingston, Montana Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food. |
06-05-2008, 08:28
Altimeter repair
Leroy, I believe that when Bluebird was first to make the finest coach possible- way back when, they included that, just because nobody else did. Am I right or wrong??
06-05-2008, 08:33
Altimeter repair
Leroy, since your coach is a Royal conversion- maybe Royal didn't think about an altimeter. I know from some experience, that whenever mine goes up, my fuel "economy" goes down. Weird
06-05-2008, 09:18
Altimeter repair
In a message dated 6/5/2008 7:04:21 P.M. Central Standard Time, aeonix1@... writes:
I think my dad had a Lincoln or Packard that had an altimeter in it, Pete- that Packard probably weighed as much as my coach, 39,000+
LOL!!!
06-05-2008, 11:37
Altimeter repair
Hi Dave and Pete.
Local bar. pressure is 29.9...doesn't help. Dave, my GPS is a Cobra..it doesn't have an altitude. Wish it did. Went to the local airport today (small here in Branson). Asked a local charter carrier where they got theirs done. Said they send it to Kansas City. They asked what aircraft it was in and I told them a Bluebird. They asked "Was that a Ultralight and how many engines?" Told them one engine and it used diesel. You should have seen the look on their faces..LOL..LOL it was GREAT!! I will keep looking. Bob Lawrence 84 PT36 Branson, Mo. with nonworking altimeter.... > > cross check the altitude with your GPS, set the altimeter to match, > then see how it goes. As indicated, barometric pressure can cause > considerable variation. Indeed, since my coach just has a big empty > spot marked "altimeter" I just look at the GPS when I'm curious about > the altitude. It's usually pretty accurate. > > I note that when flying out of small airfields (that didn't have > accurate barometric reports) that we'd set the altimeter to the local > posted field altitude. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Jun 4, 2008, at 5:42 PM, Dave Erickson wrote: > > > Bob, > > > > Don't forget to check the altimeter setting. Should be local > > barometric > > pressure if I remember right. > > > > Can also set the altimeter to show a known altitude and cross check > > to local > > barometer. > > > > Dave > > > > > > > > Bob: > > > > I had one done at an instrument shop at Boeing Field for $70.00. > > They cleaned it and check it's calibration. They didn't certify it > > for flying by I don't expect my Bird to get too far off the ground. > > They said it was within 10 to 15 feet at all altitudes up to 12,000. > > > > You might want to talk to a local instrument shop. > > > > Marv > > 2004 M380 > > Ocean Shores, WA > > > > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > >> > >> Hi group, > >> > >> Pulled out the altimeter as not very accurate. Would have hated to > > have > >> flown with this unit as it's 800 feet low. > >> > >> I know I could send it to an FAA licensed repair for bigger bucks, > > but > >> was wondering if anybody has sent theirs somewhere that was > > reasonable. > >> > >> Bob Lawrence > >> 84 PT36 > >> Workcamping in Branson, Mo. > >> > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > |
