Air to Turbo
06-12-2008, 18:39
Air to Turbo
When I purchased my coach, I noticed that the top of the air cleaner (cage) and the ducting to the intake was removed. I believe this was done as it is commonly believed to be known, that it does not appear to get enough air from the outside.
Some quick calculations show that the intake is 27in by 1 1/2 inches = 40 sq in.
Intake to filter is 5 in round or equivalent to 20 square inches, this should be adequate air flow, or maybe the intake to the filter should be increased say to 7 inches. (38 square inches)
Also does the turbo not suck the air in as well??
What I am planning to do is to restore everything, as
right now it is getting the very hot air from around the engine, and I believe it
should be getting the colder air from outside?
Any advice, pros and cons would be
appreciated.
Thanks in advance.
Terrace, B.C. Canada
Instant message from any web browser! Try the new Yahoo! Canada Messenger for the Web BETA
06-13-2008, 02:15
Air to Turbo
Bill, like in our topic of door wind noise, turbulance of air causes
restriction of flow.Wind noise is a visual result of air
turbulance??? I removed a big acordian scoop from a tractor that
collected cleaner air from out of the hot engine compartment and
reduced the black smoke immediatly????? I learned that there was no
restriction in the pipe but my thinking is the air restricted its
self. you may notice corrigated 2 foot drain pipes stay cleaner than
smooth and bigger concrete pipe. the turbulant flow of water
restricts flow and uses the energy to work up otherwise settling
silt. I am sure air flow has major diffs than hydrodynamics??? But
turbulance causes heat and I wonder if 'just heated air' has
density lost??
I am not sure 'hot air 'is that much less dence than cooler air. I
understood the advantage to be 'air just cooled'.?????
Now DavidB and PeteM can add some math to convince you to look for
another project... Dig a pit and wait for the WhatsHisName's kids.
it's more fun than knocking beer cans off'a fence.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs
inches = 40 sq in.
> What I am planning to do is to restore everything, as right now it
> Any advice, pros and cons would be appreciated.
> Thanks in advance.
__________________________________________________________________
> Connect with friends from any web browser - no download required.
Try the new Yahoo! Canada Messenger for the Web BETA at
http://ca.messenger.yahoo.com/webmessengerpromo.php
06-13-2008, 03:48
Air to Turbo
While I worked at NASA Ames Research Center, I learned that "fluid dynamics" often applies very directly to air flow. So, observations about hydrodynamics very often directly applies.
Air for combustion is best obtained from the coolest source. On my DD Series 60 (and I think the 8v92s) there is an "air charge cooler" that is used to cool the air after it passes through the turbocharger and before it goes into the combustion chamber. Cooling the air makes it denser. Compressing air makes it hotter.
I've heard a fair amount of anecdotal reports of improved 3208 performance by routing air intake to the front of the engine compartment, away from the behind the radiator. (Other FC owners with experience on this point would be far more help.) With a naturally aspirated front engine, a proper shape of the air inlet can result in "ram air" that gives a slight power boost.  Ram air is much less of an issue with a turbo charger, but would have a minor positive impact.
On the PT models, getting air from outside the engine compartment is ideal. I believe my coach has its combustion air inlet on the curb side above the large grate side access door. There is no scoop or other effort to increase air flow -- but my DD Series 60 shows no signs of lacking sufficient air.
I've seen some sort of scoop at the top rear on some coaches with the 8v92. The problem is that if it faces forward (for the ram air effect) it tends to pick up undesirable debris. I think the main effort is to ensure that the engine has good access to fresh air from outside the engine compartment. Since the 8v92 (and 6v92) are all turbocharged, the ram air effect isn't especially important. Sufficient cross section and control of air-movement restrictions for what ever reason are important for ideal combustion.
FWIW, I often wonder how the generator manages to work with its very restricted source of combustion air inside the sound compartment. (Indeed, my generator starts putting out tons of black smoke when the air cleaner is only a little dirty...)
Pete Masterson
El Sobrante CA
"aeonix1@mac.com"
density lost??
GregoryO'Connor
94ptRomolandCa
  --- In "WanderlodgeForum@yahoogroups.com", Wilhelmus Schreurs
inches = 40 sq in.
Thanks in advance.
Yahoo! Groups Links
<*> Your email settings:
    (Yahoo! ID required)
    "WanderlodgeForum-digest@yahoogroups.com"
    "WanderlodgeForum-fullfeatured@yahoogroups.com"
    "WanderlodgeForum-unsubscribe@yahoogroups.com"
06-13-2008, 04:41
Air to Turbo
Turbo Diesels are by nature very "Air Rich", in that respect they have very
different needs than a gas engine. Putting in 25% more air will yield nothing.
To get more power is simple, just add fuel. Different injectors {or timing on
computer controlled engines) is how you do it. Want economy? Reduce the fuel
input.
How fast you want to go? = How much fuel you want to burn?
Pete
-------------- Original message ----------------------
> Pete Masterson
> El Sobrante CA
> aeonix1@...
> > density lost??
> > GregoryO'Connor
> > 94ptRomolandCa
> > inches = 40 sq in.
> >> Thanks in advance.
> > Yahoo! Groups Links
Pete Masterson
El Sobrante CA
"aeonix1@mac.com"
density lost??
GregoryO'Connor
94ptRomolandCa
inches = 40 sq in.
Thanks in advance.
Yahoo! Groups Links
06-13-2008, 04:57
Air to Turbo
My generator has a hose-just lik a normal radiator hose-that extends
from the air cleaner outside of the gen compartment to pick up fresh
air.
Scott Forman
86 PT38
Memphis
observations
DD
turbocharger
makes
with
in
of
impact.
is
from
for
very
> Pete Masterson
> El Sobrante CA
> aeonix1@...
causes
no
than
But
> > density lost??
I
> > GregoryO'Connor
> > 94ptRomolandCa
believe
> > inches = 40 sq in.
filter
it
it
> >> Thanks in advance.
> > Yahoo! Groups Links
06-13-2008, 18:54
Air to Turbo
> turbulance??? >
> GregoryO'Connor
> 94ptRomolandCa
Gregory,
I also find the older I get, the more the wind noise becomes visual
and less audible. Smile
Glenn
1986 PT40
06-14-2008, 01:55
Air to Turbo
Glenn, Age is not the reason for my inability to articulate and
frequent mistakes. 'Abundance of attempts' and the 'law of averages'
are. I just 'talk/post too much', it is 'bound to happen'.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Glenn Allen"
> > turbulance??? >
> > GregoryO'Connor
> > 94ptRomolandCa
> Gregory,
> Glenn
> 1986 PT40
06-14-2008, 08:05
Air to Turbo
> GregoryO'Connor
> 94ptRomolandCa
Gregory,
My comment was an attempt at humor and nothing personal was implied. Over the
last
six months of lurking with a few post, I have enjoyed reading your posts and
your since of
humor. As my frequency of posts increases you will willget a glimpse of the
errors of my
ways. Howeve, rest assured that I always hope my contributions will make a
positive
impact on the Bird community.
I do hope to meet you and the many others at future gatherings.
Thanks,
Glenn
1986 PT40
Marietta, GA
> > > turbulance??? >
> > > GregoryO'Connor
> > > 94ptRomolandCa
> > Gregory,
> > Glenn
> > 1986 PT40
06-14-2008, 16:51
Air to Turbo
Glenn, I understood it as humor.
It takes quite a bit for me to be offended. Just today an elderly
women got close when she ;called me an idiot ;threw a newspaper at
me and ;told me to get the hell out of her house. She's just lucky
tomorrow isnt MothersDay.
Lookforward to meeting you also,
Greg
"Glenn Allen" wrote:
Gregory,
Over the last six months of lurking with a few post, I have enjoyed
reading your posts and your since of humor. As my frequency of posts
increases you will willget a glimpse of the errors of my ways.
positive impact on the Bird community.
Thanks,
Glenn
1986 PT40
Marietta, GA
06-15-2008, 04:53
Air to Turbo
Glenn:
You will be in for a treat LOL.
Would you believe he is no different when he is talking, so just be quick witted hehe.
Can't wait to meet Tim and Greg again.
----- Original Message
Sent: Saturday, June 14, 2008 1:05:28 PM
Subject: [WanderlodgeForum] Re: Air to Turbo
--- In "WanderlodgeForum%40yahoogroups.com", "Gregory OConnor"
> GregoryO'Connor
> 94ptRomolandCa
Gregory,
My comment was an attempt at humor and nothing personal was implied. Over the last
six months of lurking with a few post, I have enjoyed reading your posts and your since of
humor. As my frequency of posts increases you will willget a glimpse of the errors of my
ways. Howeve, rest assured that I always hope my contributions will make a positive
Thanks,
Glenn
1986 PT40
Marietta, GA
> --- In "WanderlodgeForum%40yahoogroups.com", "Glenn Allen"
> > > turbulance?? ? >
> > > GregoryO'Connor
> > > 94ptRomolandCa
> > Gregory,
> > Glenn
> > 1986 PT40
Looking for the perfect gift? Give the gift of Flickr!
