Low volts and amps; was alternator
05-23-2005, 10:06
Some of you may remember my alternator belts broke. I just put the
belts on my alternator and took Max for a spin. It registered about
100 amps and 11.5 volts. The amp meter went to 0 and the voltage 10.
I turned on the generator and got close to normal for a couple of
miles and then it did the same thing. I checked the alternator and it
showed 11.5 volts. That may have been feedback from the batteries.
I'm ready to buy a new alternator, but with the generator not
supplying power to the chargers, think it might be something else.
When I hooked up to shore power I got over 110 amps and 12.5 volts at
the dash. Any suggestions? I need to get this solved as we are
heading the California in a week!
Sid Breese
85PT40
St. Joseph, MO
05-23-2005, 11:18
Sid,
I've been having a similar problem with low charge
rate. This weekend I took the ground connections loose from
alternator and cleaned them. I cleaned the ground connections
from the batteries to the frame and installed a new bolt.
Clean every ground you can find.
When I say clean them, use sandpaper to get the metal
shiny around the connection to the chassis. Remove all rust and
paint. Use a wire brush on the electrical connectors themselves.
Being copper, they'll clean up easier.
After I did that, it signicantly increased my rate and
voltage. Bad grounds are the cause of more electrical
problems on vehicles than anything else.
I hope this helps.
George Witt
81 FC 35
Lincoln, Nebraska--Huskers
--- In WanderlodgeForum@yahoogroups.com, "Sidney Breese"
> Sid Breese
> 85PT40
> St. Joseph, MO
05-23-2005, 12:17
Not a lot of information to go on, could take some testing to find if
the gauges are correct, if there is a short, etc.
If it is charging when plugged into shore power, it should charge the
same when on generator power (same chargers are used).
It should settle down after a while to a low charge rate (current), and
around 13v. If the current and voltage stay 110a/11.5v for an extended
period, it sounds like you have a substantial short somewhere, there
should be smoke.
Once the current/voltage settle down on shore power, try starting the
engine and run up to ~1200rpm, check the gauges again. turn off shore
power and see if the voltage/current stays as it should.
I don't have an '84-1/2 up PT chassis wiring diagram with me, but if it
is the same as the '84-'86 FC then don't expect the dash voltmeter to
be even close with the key on. Check voltages at the batteries with a
voltmeter.
- Jeff Miller
http://www.wanderlodge.net
> Sid Breese
> 85PT40
> St. Joseph, MO
05-23-2005, 12:52
Hey Sid, I just went through the alternator thing last week on our 86FC
and all I can say is WOW... It turns out that my dash guages were off
by 1 volt and we checked everything at the batteries..and the back of
the alternator..and still had a substantial amperage draw..FINALLY
figured out that the REDILINE WAS DRAWING APPX 90 AMPS when
running..also make sure to check when batteries are charged otherwise
the alternator is trying to charge back the batteries pushing alot of
amperage. I replaced the alternator with a BOSCH unit 160amp special
purpose designed to charge at lower rpms (new design used on tranist
buses) I guess we will see..got a 1 yr warranty..
Scott
86FC35
Murrells Inlet Sc
> Sid Breese
> 85PT40
> St. Joseph, MO
05-23-2005, 13:05
FC models are saddled with two engineering design problems. The first is
that to much current is running thru the dash and the second is the very
long cables between the chargers, the alternator and the batteries. The
more current you can divert from the dash, such as using Bosch relays for
the lights, relays to get the A/C current(driver and passenger sides) out
of the dash, etc. Change the battery cables to 4/0 although not the best
fix nor the optimal condition, it does seem easier then to change the
chargers to the passenger front bin. One more problem is that the FC models
were designed to use the motorola alternator and an external regulator that
senses the voltage directly across the batteries. Most people have changed
that out to the Leece_Neville with the internal regulators which cause a
problem.
Tom
1982 FC35
Vernon Center,NY
>Scott
>86FC35
>Murrells Inlet Sc
> > Sid Breese
> > 85PT40
> > St. Joseph, MO
05-23-2005, 13:07
I had some similar indications when we first got the coach. Traced it
to bad cells in the Interstate batteries, which were new. Replaced
with Deka AGM's and it has worked perfectly ever since. Might want to
run a specific gravity check of your batteries to make certain you
don't have a bad cell.
George Lowry
Spearfish, SD
> should be smoke.
> voltmeter.
> - Jeff Miller
>>Sid Breese
>>85PT40
>>St. Joseph, MO
> Yahoo! Groups Links
05-23-2005, 14:14
Hindsight is 20/20 isn't it?
Granted the dash in your early '82 FC could have benefitted from the
addition of a few load-reduction relays: headlamps, ignition, A/C
switches for example. Fortunately BlueBird figured that out many
years ago also and made production changes.
Your alternator and wiring also ended in late '82, all of the 3208Ta
engines had the Leece-Neville alternator with internal regulator as
original equipment. The external voltage sense was retained, through
at least the late '90s S-60 powered WLWB coaches, and was intended to
maintain proper voltage at the power buss regardless of voltage drop
over the wiring run. Many alternator folks don't understand this
wiring and I usually see it mis-wired by now.
Although the charger wiring is long, 1AWG is probably considered
adequate for the original 90a peak charging current over perhaps 25'.
Some of the battery wiring was upsized in mid-CY-1982 with the
addition of the battery isolator next to the slide-out battery tray.
I'm not sure that 4/0 battery cables for the 18" from battery to
junction would be practical (or necessary). Perhaps a jump to 1/0
would be more manageable? Trying to use the slide-out battery tray
with 4/0 wires would be difficult and other than starting current
there isn't anything that normally will cause significant voltage
drop in that wiring.
- Jeff Miller
first is
very
The
relays for
sides) out
best
FC models
regulator that
changed
cause a
> problem.
> Tom
> 1982 FC35
> Vernon Center,NY
05-24-2005, 01:02
Sent: Monday, May 23, 2005 9:14 PM
Subject: [WanderlodgeForum] Re: Low volts and amps; was alternator
I know on the 85 PT they were still useing to small of cable from the batt. (
1.0 ) to the starter useing it as a junction still 1.0 cable to the house cable
witch is 4.0 cable talk about a voltage drop. I did change out the 1.0 cable
from my batt.to the main house wireing to 4.0 cable it does make a differnce in
less volage drop Also on mine 85 PT B/B still were not useing relays in the head
lights and to small of wire.After i up greaded to relays for the head lights and
rewired the the dash lights to 10 gage wireing I can see the road at nite with
out the use of driving lights and the gages with out the use of a flash
light.The upgrad wireing was a inprovment to me and worth the time and money.
Old birds were not built for dry camping very little batt. capacities. Birds
were more suited to run the generator or go from poll to poll so who cared about
voltage drop other then the fluorescent lighting with the black tube ends do to
low voltage
In my opinon the great thing about B/B is the over all heavy construction it
gives a person something to work with and spend your money and time on. Plus you
can reengineer it any way you choose to.
Bob Loomas 85 PT 36
05-24-2005, 08:35
Jeff - How did BB accomplish the 'external voltage sense' with L-N
alternator? Is the external sensing point the place to put the
voltmeter when adjusting the L-N regulator?
Also, a general comment: When an electrical problem seems to be due
to the length or size of a cable, remember to check the
terminations. Crimped-on lugs do NOT get better at conducting
current with age. Same is true where a lug fastens to a terminal.
If in doubt, install new lugs and clean all contact points until the
metal is shiny. Then apply a product like Rid-Ox before assembly.
Remember that each cable end is actually TWO connections: One from
cable to lug, and another from lug to terminal. That's FOUR points of
failure for each run of cable (True of ground straps also).
Bob Griesel
3208Ta
through
to
drop
25'.
> - Jeff Miller
The
> first is
> very
batteries.
> The
> relays for
> sides) out
> best
> the
> FC models
> regulator that
have
> changed
> cause a
> > problem.
> > Tom
> > 1982 FC35
> > Vernon Center,NY
05-24-2005, 11:11
The alternator is shipped with two straps connecting the voltage
regulator to the positive and negative posts on the alternator.
BlueBird removed (or ordered with it removed) the strap from the
positive to the voltage regulator, and connected the voltage regulator
to the coach electrical system instead.
- Jeff Miller
--- In WanderlodgeForum@yahoogroups.com, "freewill2008"
> Bob Griesel
User(s) browsing this thread: 11 Guest(s)
