"Fan" belt for DD Series 60
06-28-2008, 07:43
DD Series 60 engine, 95 PT-42: The belt is about 73" long and about 1-5/8" wide. It has 12 ribs that fit grooves on the pulleys.
Does anyone have a part number for this belt? Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" |
06-28-2008, 08:14
Pete,
The Files say the following for a DD60 on a 1999 LXi: Air Conditioner Belt BB# 1907674 Gates # 9002-2070 Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > DD Series 60 engine, 95 PT-42: > > I've been servicing my AC ... and I just noticed that the first 'rib' > on the belt that serves the alternator is partially missing. I > suspect that this means the belt is likely to fail sooner rather than > later. > > The belt is about 73" long and about 1-5/8" wide. It has 12 ribs that > fit grooves on the pulleys. > > Does anyone have a part number for this belt? > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > |
06-28-2008, 08:27
Mike -- thanks ... but that's the _other_ belt. The alternator belt is very thin, flat, and wide with 12 ribs that fit in groves in the pulleys. It does not serve the Air Conditioner (I have a pair of belts to the AC that look like the one you referenced.) Are these files online?
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jun 28, 2008, at 1:14 PM, mbulriss wrote:
06-28-2008, 08:45
Found the file. Might be the Detroit 23521337 "serpentine belt" (although it's hardly serpentine -- it passes around two primary pulleys and two idler pulleys) -- Valley Power Systems is a dealer in my area. I've emailed them with specs.
06-28-2008, 08:58
Pete,
I'll be home sunday night I have a spare belt in the coach I'll send an e-mail with specs & part #'s. I got it from Williamson Detroit Diesel last year, just as a backup. Kurt Horvath 95 PT-42 10AC PT 42'S RULE!!! --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > Found the file. Might be the Detroit 23521337 "serpentine > belt" (although it's hardly serpentine -- it passes around two > primary pulleys and two idler pulleys) -- Valley Power Systems is a > dealer in my area. I've emailed them with specs. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Jun 28, 2008, at 1:14 PM, mbulriss wrote: > > > Pete, > > > > The Files say the following for a DD60 on a 1999 LXi: > > Air Conditioner Belt BB# 1907674 Gates # 9002- 2070 > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > > >> > >> DD Series 60 engine, 95 PT-42: > >> > >> I've been servicing my AC ... and I just noticed that the first 'rib' > >> on the belt that serves the alternator is partially missing. I > >> suspect that this means the belt is likely to fail sooner rather than > >> later. > >> > >> The belt is about 73" long and about 1-5/8" wide. It has 12 ribs that > >> fit grooves on the pulleys. > >> > >> Does anyone have a part number for this belt? > >> > >> Pete Masterson > >> '95 Blue Bird Wanderlodge WBDA 42 > >> El Sobrante CA > >> aeonix1@ > >> > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > |
06-28-2008, 09:01
More on the belt... I think I've found it.
Dayco part # 5120738 73.8" x 1.65" -- 12 ribs Described as "alternator belt" Metric No. 12PK1875 Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jun 28, 2008, at 1:45 PM, Pete Masterson wrote: Found the file. Might be the Detroit 23521337 "serpentine belt" (although it's hardly serpentine -- it passes around two primary pulleys and two idler pulleys) -- Valley Power Systems is a dealer in my area. I've emailed them with specs. |
06-28-2008, 09:14
Pete,
Sorry, I read your original message too fast. Glad you found the file anyway. Mike Bulriss 1991 WB40 "Texas Minivan" - Another BEST BB ever....... San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > Found the file. Might be the Detroit 23521337 "serpentine > belt" (although it's hardly serpentine -- it passes around two > primary pulleys and two idler pulleys) -- Valley Power Systems is a > dealer in my area. I've emailed them with specs. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Jun 28, 2008, at 1:14 PM, mbulriss wrote: > > > Pete, > > > > The Files say the following for a DD60 on a 1999 LXi: > > Air Conditioner Belt BB# 1907674 Gates # 9002-2070 > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > > >> > >> DD Series 60 engine, 95 PT-42: > >> > >> I've been servicing my AC ... and I just noticed that the first 'rib' > >> on the belt that serves the alternator is partially missing. I > >> suspect that this means the belt is likely to fail sooner rather than > >> later. > >> > >> The belt is about 73" long and about 1-5/8" wide. It has 12 ribs that > >> fit grooves on the pulleys. > >> > >> Does anyone have a part number for this belt? > >> > >> Pete Masterson > >> '95 Blue Bird Wanderlodge WBDA 42 > >> El Sobrante CA > >> aeonix1@ > >> > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > |
06-28-2008, 09:23
Pete,
Does that one cross-reference to the one for the 99 in the files? If not, how about you and 10AC Kurt collaborate on building a new filter and belt cross reference chart for the 95 DD60 and add it to the cross reference File? Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > More on the belt... I think I've found it. > > Dayco part # 5120738 > 73.8" x 1.65" -- 12 ribs > Described as "alternator belt" > Metric No. 12PK1875 > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Jun 28, 2008, at 1:45 PM, Pete Masterson wrote: > > > Found the file. Might be the Detroit 23521337 "serpentine > > belt" (although it's hardly serpentine -- it passes around two > > primary pulleys and two idler pulleys) -- Valley Power Systems is a > > dealer in my area. I've emailed them with specs. > > > > Pete Masterson > > '95 Blue Bird Wanderlodge WBDA 42 > > El Sobrante CA > > aeonix1@... > > > > > > > > On Jun 28, 2008, at 1:14 PM, mbulriss wrote: > > > >> Pete, > >> > >> The Files say the following for a DD60 on a 1999 LXi: > >> Air Conditioner Belt BB# 1907674 Gates # 9002-2070 > >> > >> Mike Bulriss > >> 1991 WB40 "Texas Minivan" > >> San Antonio, TX > >> > >> > >> > >> --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > >> > >>> > >>> DD Series 60 engine, 95 PT-42: > >>> > >>> I've been servicing my AC ... and I just noticed that the first > >>> 'rib' > >>> on the belt that serves the alternator is partially missing. I > >>> suspect that this means the belt is likely to fail sooner rather > >>> than > >>> later. > >>> > >>> The belt is about 73" long and about 1-5/8" wide. It has 12 ribs > >>> that > >>> fit grooves on the pulleys. > >>> > >>> Does anyone have a part number for this belt? > >>> > >>> Pete Masterson > >>> '95 Blue Bird Wanderlodge WBDA 42 > >>> El Sobrante CA > >>> aeonix1@ > >>> > >> > >> > >> > >> ------------------------------------ > >> > >> Yahoo! Groups Links > >> > >> > >> > > > > > |
06-28-2008, 09:46
Mike and Pete,
The first part # is a 12 pack of your favorite beverage which can be cross refrenced with any four bottles of wine, which is the same as any bottle of spirits over 80 proof. I'll get a list up with what I have this coming week. Pete we can compare notes and get a file together. Well I'm off to a my wife's corp. summer dinner party, ye ha!!! Here we go!! A square peg at a party full of round holes! Kurt Horvath 95 PT-42 currently: Lake Lanier GA --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Pete, > > Does that one cross-reference to the one for the 99 in the files? If > not, how about you and 10AC Kurt collaborate on building a new filter > and belt cross reference chart for the 95 DD60 and add it to the cross > reference File? > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > wrote: > > > > More on the belt... I think I've found it. > > > > Dayco part # 5120738 > > 73.8" x 1.65" -- 12 ribs > > Described as "alternator belt" > > Metric No. 12PK1875 > > > > Pete Masterson > > '95 Blue Bird Wanderlodge WBDA 42 > > El Sobrante CA > > aeonix1@ > > > > > > > > On Jun 28, 2008, at 1:45 PM, Pete Masterson wrote: > > > > > Found the file. Might be the Detroit 23521337 "serpentine > > > belt" (although it's hardly serpentine -- it passes around two > > > primary pulleys and two idler pulleys) -- Valley Power Systems is a > > > dealer in my area. I've emailed them with specs. > > > > > > Pete Masterson > > > '95 Blue Bird Wanderlodge WBDA 42 > > > El Sobrante CA > > > aeonix1@ > > > > > > > > > > > > On Jun 28, 2008, at 1:14 PM, mbulriss wrote: > > > > > >> Pete, > > >> > > >> The Files say the following for a DD60 on a 1999 LXi: > > >> Air Conditioner Belt BB# 1907674 Gates # 9002- 2070 > > >> > > >> Mike Bulriss > > >> 1991 WB40 "Texas Minivan" > > >> San Antonio, TX > > >> > > >> > > >> > > >> --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > >> > > >>> > > >>> DD Series 60 engine, 95 PT-42: > > >>> > > >>> I've been servicing my AC ... and I just noticed that the first > > >>> 'rib' > > >>> on the belt that serves the alternator is partially missing. I > > >>> suspect that this means the belt is likely to fail sooner rather > > >>> than > > >>> later. > > >>> > > >>> The belt is about 73" long and about 1-5/8" wide. It has 12 ribs > > >>> that > > >>> fit grooves on the pulleys. > > >>> > > >>> Does anyone have a part number for this belt? > > >>> > > >>> Pete Masterson > > >>> '95 Blue Bird Wanderlodge WBDA 42 > > >>> El Sobrante CA > > >>> aeonix1@ > > >>> > > >> > > >> > > >> > > >> ------------------------------------ > > >> > > >> Yahoo! Groups Links > > >> > > >> > > >> > > > > > > > > > |
06-28-2008, 09:49
I already have a list with most of the filters, etc. Belts are new. I'm not sure about the "serpentine" belt from the 99 list as the Dayco number I found for the DD number doesn't match the Dayco number I found online with specs that match the belt I have. But the Dayco cross reference # is so different in form and length that it might be an old numbering system or some other difference.Â
I'm "stuck" at the moment as several likely sources are closed and I'll have to check further on Monday. Once I run down the numbers, I'll upload the list I have to the Yahoo web site. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jun 28, 2008, at 2:23 PM, mbulriss wrote:
