Hot water heater
05-23-2005, 20:07
Hot water heater
doesn't Stephen Birtles sell these heaters, also? ernie
05-23-2005, 21:43
Hot water heater
Where is the best place to purchase a new hot water heater?
Elmer in Sebring FL 86 PT 38
05-24-2005, 00:00
Hot water heater
west marine..randydupree93wb
Sent: Tuesday, May 24, 2005 5:43 AM
Subject: [WanderlodgeForum] Hot water heater
Yahoo! Groups Links
05-24-2005, 00:22
Hot water heater
Yes I do
Raritan 6 Gallon with heat exchanger 510.00 plus shpping
Stephen 77fc35
05-24-2005, 00:36
Hot water heater
yes,i forgot about that! randydupree93wb
Sent: Tuesday, May 24, 2005 8:07 AM
Subject: Re: [WanderlodgeForum] Hot water heater
Yahoo! Groups Links
05-24-2005, 01:23
Hot water heater
Hi Elmer,
I replaced my faulty water heater a few years ago with a near direct
replacement from Seaward Products, _http://www.seawardproducts.com/waterhtr.htm_
(http://www.seawardproducts.com/waterhtr.htm) .
I believe it was a 11 gallon unit, and it too had the motor aid feature.
Replacement was pretty easy, but took me a day or so. It was my first "big"
project with my then "new to me" BB, and I learned a lot about the quality and
workmanship of BB's. The plumbing almost hooked up like the unit I took out,
but the slight mismatch was taken care of by using those neat and flexible
stainless steel braided hoses available at all Home Depot or Lowes plumbing
depts.
I believe the unit cost me a little over $300, and I picked it up at the
factory in nearby Whittier. They do ship, and they do sell direct.
Knock on wood, but the water heater is still working, even after my install
Good luck..
Kevin McKeown
Yorba Linda, CA
1986 38' PT (same as yours)
05-24-2005, 02:05
Hot water heater
Elmer I just bought one the other day from a marine supply.
Original Message:
Date: Tue, 24 May 2005 09:43:11 -0000
<!-- |**|begin egp html banner|**| -->
Yahoo! Groups Links
<!-- |**|end egp html banner|**| -->
mail2web - Check your email from the web at
http://mail2web.com/ .
09-08-2005, 14:09
Hot water heater
I would like to thank everyone who offered help. i have gas going now
the hot water heateris a mystry and it shouldn't be. i shut the
breaker off checked continuity at the jubction box. i had continuity
from the black wire to the white wire which tells men the circuit is
complete. how long does it take to heat the 10 gal. of water?
thanks again
re
09-08-2005, 22:16
Hot water heater
It should take less than 30 minutes. When I'm out dry camping, and the
girls need that once-a-day shower, I run the gen set for 30 minutes, and that
seems sufficient to give 'em plenty of hot water (the water is already pretty
warm from the day before).
Kevin McKeown
Yorba Linda, CA
1986 38' PT
09-09-2005, 22:38
Hot water heater
Thanks, i think i am going to run me a hot wire directly to the
element when i get the cover off and have time--
and that
already pretty
> Kevin McKeown
> Yorba Linda, CA
> 1986 38' PT
