leak in gray water tank
08-06-2008, 01:50
Ok, I guess I'm getting my BBird baptism. As I was working on my shorepower
problem, I noticed water leaking out from under the coach in the water bay. After a quick inspection, I found a pin hole sized leak in a seam in my gray water tank. Looks like just a weak spot in the construction that cracked a hair with a full load of water on it. Is this something that can be repaired with an epoxy? I think I can get a syringe in there and inject an epoxy into the hole to fill it. If not, how in the world do I go about replacing the gray water tank??? I know its doable, but I want to hear from someone who has done so before. Corey and Jenni 1996 PT42' Prosper, TX |
08-06-2008, 02:53
Corey,
I have used JB Waterweld on pressurized pipes. This stuff is amazing. It may work wor you. http://www.jbweld.net/products/water.php NH Bill 1983 FC 35 |
08-06-2008, 02:56
08-06-2008, 03:47
The repair is better done with "plastic welding" -- you'll have to look for someone with the right equipment. Basically, new plastic is melted into the crack and joins (under heat) with the original plastic. It's not a DIY project.
Epoxy might work for a short time... then fail. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 "aeonix1@mac.com" On the road at Long Beach, WA On Aug 6, 2008, at 6:50 AM, coreyg67 wrote:
08-06-2008, 06:04
Well, I am thinking it is in the tank itself, but now you have me
wondering. The actual leak is coming from the bend in the tank where it turns up to make the side. It is a pretty good ways away from the dump valve, and after I dumped the tank, the leak stopped. So, I'm not sure. I guess, I'll fill the tank and see what it does and report back. Corey and Jenni 1996 PT42' Prosper, TX --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > This may be a long shot because I have not looked at it. Are you referring to a pin hole in a weld? If so that should be the surround for the tank itself. I thought I had the same kind of leak two years ago. That leak turned out to be a bad paddle rubber in the dump valve which allowed water to seep out the top when full. The water flowed behind the dump valve and followed the bottom of the pipe into the surround for the water tank making it look like the tank was leaking. Just a thought. > > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > --- On Wed, 8/6/08, coreyg67 > From: coreyg67 > Subject: [WanderlodgeForum] leak in gray water tank > To: WanderlodgeForum@yahoogroups.com > Date: Wednesday, August 6, 2008, 9:50 AM > > > > > > > > > > > > Ok, I guess I'm getting my BBird baptism. As I was working on my shorepower problem, I > > noticed water leaking out from under the coach in the water bay. After a quick inspection, I > > found a pin hole sized leak in a seam in my gray water tank. Looks like just a weak spot in > > the construction that cracked a hair with a full load of water on it. Is this something that > > can be repaired with an epoxy? I think I can get a syringe in there and inject an epoxy into > > the hole to fill it. If not, how in the world do I go about replacing the gray water tank??? I > > know its doable, but I want to hear from someone who has done so before. > > > > Corey and Jenni > > 1996 PT42' > > Prosper, TX > |
08-06-2008, 06:14
08-06-2008, 06:22
My experience is some what limited but having had a couple trailers
and now the BB (and a couple leaks) mine have always been at points where something screws into or attaches to the tank. A drain valve or an inlet. These are easier to fix because essentially you unscrew and dope up the joint and you are done. If the tank is actually ruptured some place then you have another situation all together. Of course the real challenge which you have already found is to in fact find the leak. If there is any question I might take the chance and remove and reseal the connection points first before taking on the rest. Seems to me the vibrations and such tend to loosen the stuff and I have never had an actual break in the tank itself. Not to say that it will not or could not happen. If the tank is leaking I believe I would try to get it out of the coach and go over it top to bottom because shore as shootin if you do not you will put it back in only to find it still leaks. John Heckman central Pa 1973 FC > > Well, I am thinking it is in the tank itself, but now you have me > wondering. The actual leak is coming from the bend in the tank where > it turns up to make the side. It is a pretty good ways away from the > dump valve, and after I dumped the tank, the leak stopped. So, I'm > not sure. I guess, I'll fill the tank and see what it does and > report back. > > Corey and Jenni > 1996 PT42' > Prosper, TX > > --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > > > > This may be a long shot because I have not looked at it. Are you > referring to a pin hole in a weld? If so that should be the surround > for the tank itself. I thought I had the same kind of leak two years > ago. That leak turned out to be a bad paddle rubber in the dump valve > which allowed water to seep out the top when full. The water flowed > behind the dump valve and followed the bottom of the pipe into the > surround for the water tank making it look like the tank was leaking. > Just a thought. > > > > Leroy Eckert > > 1990 WB-40 Smoke N Mirrors > > Dahlonega, GA > > Royale Conversion > > > > --- On Wed, 8/6/08, coreyg67 > > From: coreyg67 > > Subject: [WanderlodgeForum] leak in gray water tank > > To: WanderlodgeForum@yahoogroups.com > > Date: Wednesday, August 6, 2008, 9:50 AM > > > > > > > > > > > > > > > > > > > > > > > > Ok, I guess I'm getting my BBird baptism. As I was > working on my shorepower problem, I > > > > noticed water leaking out from under the coach in the water bay. > After a quick inspection, I > > > > found a pin hole sized leak in a seam in my gray water tank. Looks > like just a weak spot in > > > > the construction that cracked a hair with a full load of water on > it. Is this something that > > > > can be repaired with an epoxy? I think I can get a syringe in > there and inject an epoxy into > > > > the hole to fill it. If not, how in the world do I go about > replacing the gray water tank??? I > > > > know its doable, but I want to hear from someone who has done so > before. > > > > > > > > Corey and Jenni > > > > 1996 PT42' > > > > Prosper, TX > > > |
08-06-2008, 07:36
08-06-2008, 11:27
i would bet that you can repair that tank permanently and easily with
this product. i have used it for many different purposes. it is one of the handiest items in my toolbox. it is available in various sizes, colors, etc. and can probably be bought cheaper via the internet. search google shopping for "eternabond". http://www.campingworld.com/shopping/ite...x-37-roll- white-with-built-in-primer/19497 good luck with it, dave diamond --- In WanderlodgeForum@yahoogroups.com, "coreyg67" > > Ok, I guess I'm getting my BBird baptism. As I was working on my shorepower problem, I > noticed water leaking out from under the coach in the water bay. After a quick inspection, I > found a pin hole sized leak in a seam in my gray water tank. Looks like just a weak spot in > the construction that cracked a hair with a full load of water on it. Is this something that > can be repaired with an epoxy? I think I can get a syringe in there and inject an epoxy into > the hole to fill it. If not, how in the world do I go about replacing the gray water tank??? I > know its doable, but I want to hear from someone who has done so before. > > Corey and Jenni > 1996 PT42' > Prosper, TX > |
08-07-2008, 08:54
I repaired leak/crack in my holding tank by using a soldering gun
with strips of the SAME material and used the strips just like I was welding. Lucky for me, Randy Dupree helped me and leak checked the tank BEFORE I put it back into the SP. LOL Regards, Hank in the desert 90SP36 an lovin it! --- In WanderlodgeForum@yahoogroups.com, david edwards > > I've fixed many leaking gray and black water tanks with epoxy. Sometimes I've used fiberglass cloth to strengthen the repair if the crack is big. I like SuperMend. It is more liquid than JB Weld or Plumber's Epoxy. I've had epoxy repairs like this hold up for many years. > I've also tried plastic welding tanks but these repairs have not been as successful as the epoxy ones. > I fixed a tank on my Bluebird last year this way. > > Kerry > 82FC 35 > Denver > |
