COACH BATTERIES
08-08-2008, 08:59
COACH BATTERIES
I need some info for the Batteries in our 1973 Gas Coach.. When we
bought it, there were 2 WalMart Maxx 29 Deep Cycle Marine Batteries,
875 cranking amps & 675 cold cranking amps. One was installed in the
front battery compartment by the drivers seat & one in the Gennie
Compartment. I installed another of the same "Up Front", and another
under the entry steps, in the places provided. These are all 12V units.
Now they are about ready to be replaced.
Question is: Replaced with what?
My Coach is stored in a Storage area without connections of any kind,
and all the batteries have the knife type disconnect switches.
Would several 6V type be better for my use? AND WHY???
Also, is a smaller size battery, (of same cranking amps) any different
from a physically much larger unit.. Will the larger one have
more "Innerds" and last longer between charges, or have a longer
battery life.??
Most of the camping will be with hookups, but occasionally we will
DryCamp for a couple of days.
Jack Smith
1973FC31
SoCal
08-08-2008, 09:24
COACH BATTERIES
Jack, The reason for using a pair of 6 volt golf cart batteries as
house batteries to replace a 12 volt battery is that the golf cart
batteries are supposed to be more robust and also able to take more
charge/discharge cycles.
Most of the time, the pair of 6 volt batteries wired together in
series have a higher amp hour rating than the battery they replaced
as well, a nice bonus.
So far as I know (not that I have any personal experience here), most
RV'ers who have tried this setup have been more satisfied with it
than with their previous 12v house battery.
The only downside I know of, aside from extra cost and trying to find
the extra room for those big batteries is maintenance: you have to
top up the golf cart batteries with distilled water regularly. As far
as I know, they aren't "sealed".
John Alldredge
--- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith"
Batteries,
another
units.
kind,
different
> battery life.??
> Jack Smith
> 1973FC31
> SoCal
08-08-2008, 11:04
COACH BATTERIES
It takes more battery to get more total AH. In my case, the original batteries
were Group 24s, and there was no room to go sideways but plenty of overhead.
6-volt GC batteries are taller, so more battery in the same physical length and
width. Typical Group 24 will be 160-170AH for two, and GC batteries 210-220AH
for two (using two because 6-volt must always be in pairs).
CCA is not particularly related to life or total Amp-hours - depends on how they
engineer the battery. 6-volt GC batteries do not have particularly high CCA
values, but with enough of them that does not matter - 6 of them turn an 8V92
over nicely.
Sealed is a factor of battery type, and 6-volts are made in most (all?) types.
If the type is sealed, the GC battery will be sealed. I have Lifeline AGM
batteries, just as sealed as any other AGM. Never did like checking/topping with
water.
Don Bradner
90 PT40 "Blue Thunder"
Eureka, CA, headed East in a week if the doc gives the OK (fingers crossed!)
>John Alldredge
>Batteries,
>the
>another
>units.
>kind,
>different
>> battery life.??
>> Jack Smith
>> 1973FC31
>> SoCal
>Yahoo! Groups Links
08-08-2008, 12:38
COACH BATTERIES
Batteries,
another
units.
kind,
different
> battery life.??
> Jack Smith
> 1973FC31
> SoCal
08-08-2008, 12:44
COACH BATTERIES
OK, first my bonafides.
I have an electrical engineering degree and worked in quality and
reliability in electronics over 30 years. While I'm not the world's
foremost expert in wet storage batteries. I have had some experience
with the quality and reliability of "backup" electrical sources.
ALL known types of rechargeable electrical storage devices (batteries
included) have "memory". The ability for the battery to absorb, store
and discharge energy is related to how much energy was stored and
discharged in recent cycles. It's very much like flexibility in
humans, if you don't slightly over stress your joints occasionally
over time you lose flexibility. You can reduce failure and extend
useful life by totally (over) depleting the battery bank once a month
or more. A perfect way to do this in an RV type application is to run
the air-conditioner until the batteries were clearly struggling then
turm on incandescent lights and leave them on for 6-12 hour AFTER you
can't see the filament glowing. Switch off all loads and use a good
REGULATED low charge rate charger, not the alternator and regulator.
Actually a trickle charger would be perfect.
Now this is not a very practical routine but the closer you could
come to the deep, deep discharge and slow full, full charge the
longer your batteries would last.
In the most basic lead storage battery, the more lead the more
overall storage capacity so in a crude sense the heavier the battery
the more ampere-hours, unless the weight is in the case not the lead.
While shear lead volume determines capacity from the standpoint of
physics, performance is determined by configuration. The thinner the
lead plates are the faster they will charge or discharge (cranking
power). The thinner the plates are the more the battery might be
prone to failure from environmental factors like temperature and
vibration. Here is the dilemma preventing you from picking the best
battery using a scale.
One really good indicator of battery quality is the case and
terminals. Is the case a heavy thick walled rubber compound or is it
a nice thin walled high performance polymer? At the factory the cost
differential is at most $2. What they are charging retail is some
indicator of value. If you can see the plate structure, what does the
workmanship look like? Check the materials of the terminals and the
seals. On almost all batteries the top is a separate piece. Check the
joint construction and workmanship. ANY inconsistency or voids is a
sign of lower quality craftsmanship. Check a couple of different
sizes and cases from the same manufacturer.
There is absolutely no inherent reason why 6 volt golf cart batteries
should be more capable of better handling numerous charge and
discharge cycles than 12 volt batteries although the design of any
battery will impact that and it may be a valid argument that
batteries specifically designed for full charge / discharge
applications will last longer. There are however 12 volt batteries
designed for these same cycles and the extra connections in a 6 volt
system negatively impact reliability and efficiency.
As a general rule you should get better performance and life from
sealed batteries. Typically they will be newer designs, often made on
more modern production lines and there is far less chance that the
electrolyte will become (even slightly) contaminated or non-optimal.
Price vs. performance vs. reliability.
Two $75 55ah 12 volt batteries will be more reliable than one $150
100ah battery but take up twice the space. You can limp in on one of
the $75 cheapies and with proper care ONE of them will last longer
than the $150 battery. Will four $37.50 six volt batteries outperform
either of the other options ... Nope, if one of those four fail,
you're walking.
If you're looking at spending $500 or more on batteries, in a none
emergency replacement, it might be worthwhile to contact the
manufacturer and get the detail specs and reliability data on the
models you are considering.
Happy to help if you have questions.
Regards,
GPSGary
08-08-2008, 12:46
COACH BATTERIES
Jack:
I am a fan of TROJAN T105 six volt batteries......Two in series is
all u need for house power.......I had mine over seven years and
still fine in motorhome in Australia using a solar setup.
Understand SAMs club has some a little cheaper and a few less
amps....for myself, I like the BEST and for ME, TROJAN T105's are the
best for house batteries.
They list at $169 in Vegas but I got them last month here for $130.
I hear SAMS club batteries are cheaper....Take your pick.
LOL
Regards,
Hank still in Vegas
90SP36
Batteries,
another
units.
kind,
different
> battery life.??
> Jack Smith
> 1973FC31
> SoCal
08-08-2008, 14:26
COACH BATTERIES
This is what I use more power less space no water
& one in the Gennie
battery life.??
Jack Smith
1973FC31
SoCal
08-09-2008, 04:51
COACH BATTERIES
GPS Gary:
Regarding your article; You stated the following;
"The extra connections in a six volt system negatively impact
reliability and efficiency,"
On my two six volt Trojan T-105's, I have a "00" wire six inches long
connecting the negative and positive to make it 12 volts.
Please explain the "negative reliability and efficiency impact" of
this "extra connection."
Regards,
Hank
90SP36
--- In WanderlodgeForum@yahoogroups.com, "hippieforever3"
experience
(batteries
store
month
run
then
you
regulator.
battery
lead.
it
cost
batteries
volt
on
optimal.
of
outperform
> you're walking.
> Regards,
> GPSGary
08-09-2008, 05:44
COACH BATTERIES
GPSGary,
If you deep discharge your lead acid batteries like you suggest you
will destroy them. That type of cycling is for Nicad and other types,
not lead/acid.
Gardner
experience
(batteries
store
month
run
then
you
regulator.
battery
lead.
it
cost
batteries
volt
on
optimal.
of
outperform
> you're walking.
> Regards,
> GPSGary
08-09-2008, 06:01
COACH BATTERIES
As others have pointed out, there are some technical issues with your comments.
I think if you research the topic you will find a steady stream of "Lead-acid is
not subject to memory' on technical sites. Rule-of-thumb is to avoid discharge
below 50% whenever possible. I wouldn't personally go so far as to say a 100%
discharge will destroy a battery, but it will definitely shorten life.
One other issue is this part:
As you noted correctly "sheer lead volume determines capacity" so it is not
possible to have a 100AH battery that is the same size as a 55AH battery unless
the latter has an extreme amount of wasted space.
