COACH BATTERIES
08-09-2008, 15:14
Post: #21
COACH BATTERIES
> I am not an engineer ( nor did I play one on TV) but what you are
> suggesting goes against avery article I have ever read. Some were > written by battery mfr. engineers. Show me one. > You are never supposed to mix old > and new battreies in a battery bank! Why??? Please use science, physics or electronics or references. > 6 volt golf cart batteries will > give you longer life than any common wet cell deep cycle 12 volt. They > are sturdy and made to handle frequent discharge. It is very likely that the manufacturers design almost all 6 volt batteries to withstand more abuse like 100% discharge, temperature extremes and vibration. However if you get a 12 volt battery from the same manufacturer, built to the same design spec and use it in the same application, the 12 volt system will last longer and outperform the 6 volt with less maintenance. Regards, GPSGary |
08-09-2008, 15:28
Post: #22
COACH BATTERIES
On 8/10/2008 at 3:03 AM hippieforever3 wrote:
>That would be true if batteries weren't made in standard sizes. >However to offer choices to the marketplace, manufacturers will stuff >the guts of a 100ah battery into EXACTLY the same case as a 55ah >battery. Really? Do you have a reference for a 100AH battery made to Group 22 size? 9-3/8x5-1/2x9-1/4, by far the most common cheap battery put in a cheap car. While you're at it, please reconcile your statement that 2 55AH batteries will be better than a single 100AH battery, when extra connections are such a bad thing. |
08-09-2008, 16:12
Post: #23
COACH BATTERIES
Jack, 'battery systems' in Santee has blems some times at half
price, full warrenty. great customerservice. http://batterysystems.net/locations/loca...e=CA&id=28 the big box stores sell "marine starting", "marine/rv" and "rv" batteries. the marine starting are not deepcycle. Unless you can 'series connect' a pair of 6V, you may have to stay with 12Volt batteries. It seems safe to go with Trogen brand. how is the possum? GregoryO'Connor 94ptRomolandCA --- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith" > > I need some info for the Batteries in our 1973 Gas Coach.. When we > bought it, there were 2 WalMart Maxx 29 Deep Cycle Marine Batteries, > 875 cranking amps & 675 cold cranking amps. One was installed in the > front battery compartment by the drivers seat & one in the Gennie > Compartment. I installed another of the same "Up Front", and another > under the entry steps, in the places provided. These are all 12V units. > Now they are about ready to be replaced. > Question is: Replaced with what? > My Coach is stored in a Storage area without connections of any kind, > and all the batteries have the knife type disconnect switches. > Would several 6V type be better for my use? AND WHY??? > Also, is a smaller size battery, (of same cranking amps) any different > from a physically much larger unit.. Will the larger one have > more "Innerds" and last longer between charges, or have a longer > battery life.?? > Most of the camping will be with hookups, but occasionally we will > DryCamp for a couple of days. > Jack Smith > 1973FC31 > SoCal > |
08-09-2008, 16:28
Post: #24
COACH BATTERIES
size? 9-3/8x5-1/2x9-1/4, by far the most common cheap battery put in a cheap car. Nope that's a pretty small case, but there are 55ah batteries in larger cases that share cases with 100ah batteries. > While you're at it, please reconcile your statement that 2 55AH batteries will be better than a single 100AH battery, when extra connections are such a bad thing. > IF and on IF one 55ah battery will still crank you over, you have 100% redundancy. Any of the extra connections can fail and you can still get home. One connection fails on the 100ah setup and you're walking. Regards, GPSGary |
08-10-2008, 01:52
Post: #25
COACH BATTERIES
08-10-2008, 01:56
Post: #26
COACH BATTERIES
That's funny, and very well done.
BradBarton00LXiDFW bbartonwx@... To: WanderlodgeForum@yahoogroups.com From: tommy@... Date: Sun, 10 Aug 2008 06:52:20 -0700 Subject: [WanderlodgeForum] Re: COACH BATTERIES
Reveal your inner athlete and share it with friends on Windows Live. Share now! |
08-10-2008, 02:50
Post: #27
COACH BATTERIES
Years ago, I worked for a college and had CERTIFICATION authority to
confer degrees at graduation. I no longer have that authority as I am now just another "honest" run of the mill attorney at law retired in my wanderlodge "contibuting," on occasion to this Forum. However, after reading most recent comments, awarding a degree of "ditchdigger" would seem appropriate as one continues to "dig" a deep hole.. Regards, Hank 90SP36 --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" wrote: > > > I am not an engineer ( nor did I play one on TV) but what you are > > suggesting goes against avery article I have ever read. Some were > > written by battery mfr. engineers. > > Show me one. > > > > You are never supposed to mix old > > and new battreies in a battery bank! > > Why??? Please use science, physics or electronics or references. > > > > 6 volt golf cart batteries will > > give you longer life than any common wet cell deep cycle 12 volt. > They > > are sturdy and made to handle frequent discharge. > > It is very likely that the manufacturers design almost all 6 volt > batteries to withstand more abuse like 100% discharge, temperature > extremes and vibration. However if you get a 12 volt battery from the > same manufacturer, built to the same design spec and use it in the > same application, the 12 volt system will last longer and outperform > the 6 volt with less maintenance. > > Regards, > GPSGary > |
08-10-2008, 03:27
Post: #28
COACH BATTERIES
Hank, "Ditch digger" is not an honorary degree. and Honest attorneys
are not "run of the mill". "Contributing" require the skin to admit you erred and learned your assumptions were untrue. I dont think the hippie will learn. Some folks need GPS to find their way home. GregoryO'Connor digger of ditches --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > Years ago, I worked for a college and had CERTIFICATION authority to > confer degrees at graduation. > > I no longer have that authority as I am now just another "honest" > run of the mill attorney at law retired in my > wanderlodge "contibuting," on occasion to this Forum. > > However, after reading most recent comments, awarding a degree > of "ditchdigger" would seem appropriate as one continues to "dig" a > deep hole.. > > Regards, > Hank > 90SP36 > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" > wrote: > > > > > I am not an engineer ( nor did I play one on TV) but what you are > > > suggesting goes against avery article I have ever read. Some were > > > written by battery mfr. engineers. > > > > Show me one. > > > > > > > You are never supposed to mix old > > > and new battreies in a battery bank! > > > > Why??? Please use science, physics or electronics or references. > > > > > > > 6 volt golf cart batteries will > > > give you longer life than any common wet cell deep cycle 12 volt. > > They > > > are sturdy and made to handle frequent discharge. > > > > It is very likely that the manufacturers design almost all 6 volt > > batteries to withstand more abuse like 100% discharge, temperature > > extremes and vibration. However if you get a 12 volt battery from > the > > same manufacturer, built to the same design spec and use it in the > > same application, the 12 volt system will last longer and > outperform > > the 6 volt with less maintenance. > > > > Regards, > > GPSGary > > > |
08-10-2008, 03:46
Post: #29
COACH BATTERIES
I can't help but comment on this one.
Old and new batteries mixed would most likely have eddy currents flowing between the batteries due to deterioration of th internal currents and would definitely have reducing effect on the AH and therefore the cranking amps too. There are good points on both sides of this discussion. No need to beat each other up. Oh by the way my qualifications are over 30 years experience electronics with an engineering background. Not a graduate engineer but definitely schooled in several good engineering schools. In summary I was a practical applications electronic tech. Just my two cents. Ron Thompson 1995 WLWB 42' hippieforever3
Ron Thompson -Waller, Tx. 1995 WLWB 42'Blue Bird (cockyfox@...) |
08-10-2008, 03:55
Post: #30
COACH BATTERIES
Don't you just love this Forum!!!
We all get a chance to "share" our inputs and others keep our feet to the fire if we get a bit off the mark as we have witnessed on this "COACH BATTERIS" subject. Maybe it is time to shut this topic down as we have probably learned enough. I would appreciate more SOLAR panel input from members before I buy a panel or two for my bird roof. I liked unisolar 64 but that is seven years ago technology. Any new stuff out there???? Thanks. Regards, Hank 90SP36 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Hank, "Ditch digger" is not an honorary degree. and Honest attorneys > are not "run of the mill". "Contributing" require the skin to admit > you erred and learned your assumptions were untrue. > I dont think the hippie will learn. Some folks need GPS to find > their way home. > > GregoryO'Connor > digger of ditches > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > > > Years ago, I worked for a college and had CERTIFICATION authority > to > > confer degrees at graduation. > > > > I no longer have that authority as I am now just another "honest" > > run of the mill attorney at law retired in my > > wanderlodge "contibuting," on occasion to this Forum. > > > > However, after reading most recent comments, awarding a degree > > of "ditchdigger" would seem appropriate as one continues to "dig" > a > > deep hole.. > > > > Regards, > > Hank > > 90SP36 > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" > > wrote: > > > > > > > I am not an engineer ( nor did I play one on TV) but what you > are > > > > suggesting goes against avery article I have ever read. Some > were > > > > written by battery mfr. engineers. > > > > > > Show me one. > > > > > > > > > > You are never supposed to mix old > > > > and new battreies in a battery bank! > > > > > > Why??? Please use science, physics or electronics or references. > > > > > > > > > > 6 volt golf cart batteries will > > > > give you longer life than any common wet cell deep cycle 12 > volt. > > > They > > > > are sturdy and made to handle frequent discharge. > > > > > > It is very likely that the manufacturers design almost all 6 > volt > > > batteries to withstand more abuse like 100% discharge, > temperature > > > extremes and vibration. However if you get a 12 volt battery > from > > the > > > same manufacturer, built to the same design spec and use it in > the > > > same application, the 12 volt system will last longer and > > outperform > > > the 6 volt with less maintenance. > > > > > > Regards, > > > GPSGary > > > > > > |
