94pt shuts off in traffic
09-08-2008, 16:51
Just got back from a week trip that started out with frantic phone
calls to CurtS and RobR. Rob told me to check for voltage with unique body parts but CurtS was helpful. My bus would quit, standing me roadside in L.A. (SteveG,the LA above sealevel) anything that was run with the ig key would go off and with in 1 min it would come back. I did not have the electrical prints so I was at a loss as to which breaker was tripping because it would repair. I found out that the 75 amp relay number 36 was that powered by the key so I switched the 75 amp #36 with 75 amp #37 (under front fiberglass pannel ;below windshield ;big black relay ;center top ;only two there ;large wires). One fear I had was with the tranny. it would repower in N if I am rolling on the freeway at 45 mph when it repowered, and push D, what gear does the allison choose??? therefor I would roll to a stop. and set off again only to fail four more times in 30 miles. stopping to chech for the obvious ground and wire fixes. Soon I realized that the 75 amp ig relay was losing its signal from the ig switch so I jumped the signal to the relay with a 12 volt hot wire and a toggle. power up the relay with the toggle at the cockpit and use the key switch to contact the starter. to shut down, it was necesary to turn off the toggle and the key. Now at home I have the prints in hand and can not find the location or notation of the fuse to the ignition switch. I dont think it is split at the rear but there may be some three way situation with the remote start?????? I dont think it is the ig switch because it would repair like a fuse circuit braker or heated relay. Are these ig switches internally fused???? The 94ish ig switch is not like the older pt's that were big amp switches. 94ish trip the 75 amp relay which power other relays and fused components. GregoryO'Connor 94ptRomolandCa |
09-09-2008, 04:14
traced wires to the ig::
The "engine compartment light" shares a breaker with both ig switches this may be the issue (three wires off this breaker). If the engine compartment light or the bay door switch to the light keeps tripping a fuse, you are screwed the light wires are protected by the breaker tripping and the bus stops. there are several breakers in the back (little silver boxes with two 5/16? inch studs) under and around the big reed copper shunts along the wall above the 3 start batteries. power to the ig switch is via this 40 foot long wire 'orange and black'. I think I will lablel all three breakers ;then replace ;then pick a new big wire source up near the cockpit to send 12 v to the ig switch ( add a 20 amp breaker there also). the small wire is sufficient to run the power to the ig switch because the ig switch (key) only need little amperage to flip a larger 75amp relay. but there are just too many things that can happen in 40 feet and the compartment light is just one more error prone item that can cause collateral damage. other computer issues have arisen in the past with the breakers in this area. While roadside, RobR directed me to jump one for a limp repair but removal of that breaker did not cut power. (Rob was close) it may be heat deterioration in the breakers or the fact that I dont close the engine compartment door all the way to a solid lock because the clasps are not aligned???? so now is the time to replace all the crap back there. I prob will put the breaker in the same spots but for sure will move the source of 12 v to the front ig to a big wire in the cockpit area. GregoryO'Connor 94pt RomolandCa--- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Just got back from a week trip that started out with frantic phone > calls to CurtS and RobR. Rob told me to check for voltage with > unique body parts but CurtS was helpful. > > My bus would quit, standing me roadside in L.A. (SteveG,the LA above > sealevel) anything that was run with the ig key would go off and > with in 1 min it would come back. I did not have the electrical > prints so I was at a loss as to which breaker was tripping because > it would repair. I found out that the 75 amp relay number 36 was > that powered by the key so I switched the 75 amp #36 with 75 amp #37 > (under front fiberglass pannel ;below windshield ;big black > relay ;center top ;only two there ;large wires). > > One fear I had was with the tranny. it would repower in N if I am > rolling on the freeway at 45 mph when it repowered, and push D, what > gear does the allison choose??? therefor I would roll to a stop. and > set off again only to fail four more times in 30 miles. stopping to > chech for the obvious ground and wire fixes. > > Soon I realized that the 75 amp ig relay was losing its signal from > the ig switch so I jumped the signal to the relay with a 12 volt hot > wire and a toggle. power up the relay with the toggle at the > cockpit and use the key switch to contact the starter. to shut > down, it was necesary to turn off the toggle and the key. > > Now at home I have the prints in hand and can not find the > location or notation of the fuse to the ignition switch. I dont > think it is split at the rear but there may be some three way > situation with the remote start?????? > > I dont think it is the ig switch because it would repair like a fuse > circuit braker or heated relay. Are these ig switches internally > fused???? The 94ish ig switch is not like the older pt's that were > big amp switches. 94ish trip the 75 amp relay which power other > relays and fused components. > > GregoryO'Connor > 94ptRomolandCa > |
09-09-2008, 07:35
> > below is a pic of the fused self resetting breaker for power to the cockpit and engine compartment ignition switch. it is the one all the way to the left without a shunt on the bat side ( other two are tied at bat terminal). I was surprised that the third wire was not the engine compartment light as the light remained on. It is not on the battery wall as I posted prior, it is behind the rear bumper. I am concerned that the fuse/breaker is tripping as a result of some issue???and it is not a faulty fuse. one wire was f'ed (not ig wire) and broke off while I removed the bat side . the threads of the breaker/fuse are gunked up with debris and as a result, removal of the 3/8 in nut is too aggressive to think that the fuse/breaker will internally survice a removal cleaning. a
09-09-2008, 07:47
I have deleted the spam credit report message tacked on to the prior
post. No more please...... Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > below is a pic of the fused self resetting breaker for power to the > cockpit and engine compartment ignition switch. it is the one all the > way to the left without a shunt on the bat side ( other two are tied at > bat terminal). I was surprised that the third wire was not the engine > compartment light as the light remained on. It is not on the battery > wall as I posted prior, it is behind the rear bumper. I am concerned > that the fuse/breaker is tripping as a result of some issue???and it is > not a faulty fuse. one wire was f'ed (not ig wire) and broke off while > I removed the bat side . the threads of the breaker/fuse are gunked up > with debris and as a result, removal of the 3/8 in nut is too > aggressive to think that the fuse/breaker will internally survice a > removal cleaning. > > a [DSC00714.JPG] > <http://www.pbase.com/gregoryoc/wanderlod...cts&page=4> > |
09-09-2008, 11:32
> > traced wires to the ig:: Gregg had the same problem with my 85PT 40.After replacing breakers,ignition switch etc. I finally ran .a new wire back to fuel shut off valve problem solved.Lee Condosta 85pt 40 Holden BeachN.C > The "engine compartment light" shares a breaker with both ig > switches this may be the issue (three wires off this breaker). If > the engine compartment light or the bay door switch to the light > keeps tripping a fuse, you are screwed the light wires are protected > by the breaker tripping and the bus stops. there are several > breakers in the back (little silver boxes with two 5/16? inch studs) > under and around the big reed copper shunts along the wall above the > 3 start batteries. power to the ig switch is via this 40 foot long > wire 'orange and black'. > > I think I will lablel all three breakers ;then replace ;then pick a > new big wire source up near the cockpit to send 12 v to the ig > switch ( add a 20 amp breaker there also). the small wire is > sufficient to run the power to the ig switch because the ig switch > (key) only need little amperage to flip a larger 75amp relay. but > there are just too many things that can happen in 40 feet and the > compartment light is just one more error prone item that can cause > collateral damage. > > other computer issues have arisen in the past with the breakers in > this area. While roadside, RobR directed me to jump one for a limp > repair but removal of that breaker did not cut power. (Rob was > close) it may be heat deterioration in the breakers or the fact > that I dont close the engine compartment door all the way to a solid > lock because the clasps are not aligned???? so now is the time to > replace all the crap back there. I prob will put the breaker in the > same spots but for sure will move the source of 12 v to the front ig > to a big wire in the cockpit area. > > GregoryO'Connor > 94pt > RomolandCa--- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > Just got back from a week trip that started out with frantic phone > > calls to CurtS and RobR. Rob told me to check for voltage with > > unique body parts but CurtS was helpful. > > > > My bus would quit, standing me roadside in L.A. (SteveG,the LA > above > > sealevel) anything that was run with the ig key would go off and > > with in 1 min it would come back. I did not have the electrical > > prints so I was at a loss as to which breaker was tripping because > > it would repair. I found out that the 75 amp relay number 36 was > > that powered by the key so I switched the 75 amp #36 with 75 amp > #37 > > (under front fiberglass pannel ;below windshield ;big black > > relay ;center top ;only two there ;large wires). > > > > One fear I had was with the tranny. it would repower in N if I am > > rolling on the freeway at 45 mph when it repowered, and push D, > what > > gear does the allison choose??? therefor I would roll to a stop. > and > > set off again only to fail four more times in 30 miles. stopping > to > > chech for the obvious ground and wire fixes. > > > > Soon I realized that the 75 amp ig relay was losing its signal > from > > the ig switch so I jumped the signal to the relay with a 12 volt > hot > > wire and a toggle. power up the relay with the toggle at the > > cockpit and use the key switch to contact the starter. to shut > > down, it was necesary to turn off the toggle and the key. > > > > Now at home I have the prints in hand and can not find the > > location or notation of the fuse to the ignition switch. I dont > > think it is split at the rear but there may be some three way > > situation with the remote start?????? > > > > I dont think it is the ig switch because it would repair like a > fuse > > circuit braker or heated relay. Are these ig switches internally > > fused???? The 94ish ig switch is not like the older pt's that were > > big amp switches. 94ish trip the 75 amp relay which power other > > relays and fused components. > > > > GregoryO'Connor > > 94ptRomolandCa > > > |
