Jake Brake Problem
09-17-2008, 16:55
Jake Brake Problem
If its a prob with the computer this guy has the answer. he lists a
land line. lot of good info on his site. I sent him several
computers to reprogram
http://www.heavydutypowertrain.com/detroitecms.htm
I wonder if the two power sources for the ddec are the right two
fuse/breakers behind the rear bumper?? the left is the ign switch
and bulk oil switch
greg
> One other thing I forgot. It has been a year since I studied my
set up so I am going from memory. I specifically remember that my
coach has two main DDEC power sources spliced somewhere near the
DDEC control unit and two separate grounds. This set up presumably
as a fail safe in case one of two fuses or relays on the power side
malfunctions, and/or a bad ground in one location either of which
prevents an engine shut down because the DDEC cannot think.(no
power, no ground) I do not know if BB did this or Royale when they
converted my coach. Hope this helps.
> Leroy Eckert
> 1990 WB-40 Smoke N Mirrors
> Dahlonega, GA
> Royale Conversion
> --- On Wed, 9/17/08, Johnny M Slone wrote:
> From: Johnny M Slone
> Subject: [WanderlodgeForum] Re: Jake Brake Problem
> Date: Wednesday, September 17, 2008, 10:07 PM
> Thanks for the replies. I have been searching for a
schematic that
> shows how the Allison WTEC and DDEC III are wired and what should
be
> on each lead. I have a BB drawing that shows the control switches
> relays. I have tested as best I could these circuits and I'm
> satisfied that this part is doig what it should. There appears to
be
> a lead
> (engine brake enable) from the WTEC to a VIM. I suspect this is a
> relay. This enable lead opens when all conditions are satisfied
for
> the jake to work. This circuit contols the engine brake disable
lead
> to the DDEC III. Is anyone familiar with this circuit and know
where
> to look for it. I may be on a wild goose chase.
> When the jake brake is working its not real loud inside the coach.
> Here in the mountians you definately know when it isn't. Going
down a
> 6% grade for about a mile without a jake or a retarder will get
your
> attention.
> Thanks again.
> Johnny M Slone
> Pikeville, Ky
> 98 LXI
09-17-2008, 17:01
Jake Brake Problem
Don't know Greg. I know they are in the engine compartment but have never tracked them down..I have several auto reset breakers back there. I also know my Royale is different than others. Maybe those Prevost converters knew something.?????
Leroy Eckert
Royale Conversion
Date: Thursday, September 18, 2008, 12:55 AM
http://www.heavydut ypowertrain. com/detroitecms. htm
and bulk oil switch
greg
--- In "WanderlodgeForum%40yahoogroups.com", Leroy Eckert
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
schematic that
be
be
> a lead
for
lead
where
down a
your
> attention.
> Thanks again.
> Johnny M Slone
> Pikeville, Ky
> 98 LXI
09-17-2008, 17:17
Jake Brake Problem
My prints say the two to the right go to a "Power Harness Connector" one other wire to that same P H connector isfrom the coolant level sensor somy thinking is it was the power to the DDec???
aİmage
b
greg
> Leroy Eckert
> Royale Conversion
> --- On Thu, 9/18/08, Gregory OConnor Gregoryoc@... wrote:
> From: Gregory OConnor Gregoryoc@...
> and bulk oil switch
> greg
> --- In WanderlodgeForum@ yahoogroups. com, Leroy Eckert
> > Leroy Eckert
> > Dahlonega, GA
> > Royale Conversion
> > To: WanderlodgeForum@ yahoogroups. com
> schematic that
> be
> and
> be
> > a lead
> for
> lead
> where
> down a
> your
> > attention.
> > Thanks again.
> > Johnny M Slone
> > Pikeville, Ky
> > 98 LXI
09-17-2008, 17:38
Jake Brake Problem
I replace all three and opened up the hermetic seal. they were all
full of rust, (not nearly as good a seal as Ed McMahon's mayonnaise
jar). I think they are put at the bumper to keep the heat away???? I
added one more source to power the front ign switch and learned
that all the running lights and most every thing is powered off the
house batteries. if you turn off the house batteries and unplug the
chargers, all you have is starter, ignition and computer. I found
only one fuse under the front panel that was powered off the
batteries hot all the time, 10 ga wire, red, BAK3. I added one more
15 amp off this to the ign. I wonder if that will let the rear 20
amp and the newfront 15 amp burn 35 amp to the ignition switch?????
likewies, the two 20 amps at the rear giving the computer 40 amps
prior to trip off????
greg
Connector" one
> other wire to that same P H connector is from the coolant level
sensor
> so my thinking is it was the power to the DDec???
> a View full size
> <http://pictures.aol.com/ap/singleImage.do?
pid=9120PCTTwcnwYsmgQfB1MFCZ8\
> VkyhYjbO8s2v4xQp5Fd3Ig%3D> b
> greg
have
there.
> > Leroy Eckert
> > Royale Conversion
lists a
> > and bulk oil switch
> > greg
presumably
side
which
they
> > > Leroy Eckert
> > > Dahlonega, GA
> > > Royale Conversion
> > schematic that
should
> > be
switches
> > and
to
> > be
> > > a lead
is a
> > for
> > lead
> > where
coach.
> > down a
> > your
> > > attention.
> > > Thanks again.
> > > Johnny M Slone
> > > Pikeville, Ky
> > > 98 LXI
09-18-2008, 00:38
Jake Brake Problem
I wonder if ATEC and WTEC are the same trans ECU. The schematic I have
from the Allison website.
Leroy I'm not sure that I have the drawing you mention as I didn't get
many with the coach.
Kurt, would these pin locations be at the trans ECU and DDEC.
My big problem is that I can understand a trouble on paper but cannot
locate where it on the coach. Comes with age I guess.
Thanks.
Johnny Slone
Pikeville, Ky
98 LXI
09-18-2008, 01:00
Jake Brake Problem
could also be that the prompts are working and it is issue with the
input, like the fuel pedal not returing all the way relaxed??? the
mechanical end of the electronics.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Johnny M Slone"
have
get
cannot
> Thanks.
> Johnny Slone
> Pikeville, Ky
> 98 LXI
09-18-2008, 01:36
Jake Brake Problem
Johnny,
I just posted some photos of the location of the Cannon Plugs, I
thought I had 5, but there are 6 of them.
Click on new photos on the home page, For the blueprint I'll have to
e-mail them directly to you. they are too big for the Forum. If your
transmission is down shifting the problem lies in the Jake
Brake/Engine wiring, I would think, but this is not my specialty. I'm
sure some of the guys will lend a hand in this.
Kurt Horvath
95 PT-42
10AC
have
get
cannot
> Thanks.
> Johnny Slone
> Pikeville, Ky
> 98 LXI
09-18-2008, 01:40
Jake Brake Problem
I cannot help you since you have a S60. I assume DDEC III. I doubt that the ATEC and WTEC are the same. The DDEC on mine is on the top rear of the engine. It is a large rectangular sealed box. If it has not been painted the numbers should be on the wires. Without a diagram I don't know what to tell you. Maybe someone on the site has a schematic.
Just keep in mind that other than the fuel allocation system to the injectors and in your case the Jake system the remainder of the DDEC is basically a monitor and is preprogrammed with acceptable parameters; receives information from several sensors or senders and reacts to them if the data is outside the parameters..That is how I understand it. It is not really as smart as the newer models and the codes just steer you in a general direction. If I can find it, I will post a link to the general layout of the
DDEC III. It will not be coach specific but should give you a general idea of what you are dealing with.
Leroy Eckert
Dahlonega, GA
Royale Conversion
Date: Thursday, September 18, 2008, 8:38 AM
Thanks.
Johnny Slone
Pikeville, Ky
98 LXI
09-18-2008, 01:45
Jake Brake Problem
That's true. If the sensor on the pedal does not go to 0 it will not
activate the Jake. Unfortunatly I replaced min last year, so I'm
looking further down the line. It is something for Johnny to check
Kurt Horvath
95 PT-42
10AC
> GregoryO'Connor
> 94ptRomolandCa
> have
didn't
> get
> cannot
> > Thanks.
> > Johnny Slone
> > Pikeville, Ky
> > 98 LXI
09-18-2008, 01:49
Jake Brake Problem
Here is a link to the general overview of a generic DDEC system and
its inputs and outputs.. Others may have additional options.
http://www.powerlinecomponents.com/liter...ematic.htm
Leroy Eckert
Dahlonega, GA
> Thanks.
> Johnny Slone
> Pikeville, Ky
> 98 LXI
