Washer/Dryer
09-29-2008, 16:00
Washer/Dryer
Just tiding up the coach, putting back in the rear wall of the washer
dryer closet and wondered dang it's still a bit musty. I just finished
vacuuming behind the Splende 2000 last week and had cleaned up
everything. I looked behind it once more. How did I miss that. The
drain from the washer goes into a pipe stand. There is no washer or
collar around it, it's just the washer drain tube stuck into a 1 ½"
black pipe. Lots of room to vent back into the closet. I found one
source of unpleasant odor. But that just lead to another question. When
was the last time anyone changed the water hoses for the washer? Near
as I can tell in my coach never. That would make them 13 years old.
Nearly triple the recommended service life. New stainless braided hoses
and a some sort of collar or vapor lock for the drain pipe. Now I need
to pull the machine out a bit just make sure the vent tube is OK,and to
install the new hoses. It did have some lint and was very dusty in
there. And the beat goes on, and the beat goes on. On and on.
Kurt Horvath
95 Pt 42
10AC
09-29-2008, 16:08
Washer/Dryer
Just curious, does your Splendide vent through the side of the bus or below the bus. I have heard tales of critters entering the below bus dryer vents. The lint filter is just like at home. It ain't worth a damn and the exhaust pipe needs frequent cleaning. As for the water drain, mine is the same and it has a water trap.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
Don't let a dog guard your food or Congress guard the money
--- On Tue, 9/30/08, Kurt Horvath wrote:
Subject: [WanderlodgeForum] Washer/Dryer
Date: Tuesday, September 30, 2008, 12:00 AM
Kurt Horvath
95 Pt 42
10AC
09-29-2008, 16:30
Washer/Dryer
One more thing. Do you have a vent tube there???in the washer/dryer closet??? I am still trying to determine where the intake air is that allows the venture on the main vent to expel gasses while driving and or allows the Stanker fans to work properly> Anybody know, please advise.
Leroy Eckert
Dahlonega, GA
Royale Conversion
Kurt Horvath
95 Pt 42
10AC
09-30-2008, 01:47
Washer/Dryer
It also depends on the installation/floor plan in your coach. With
the "diagonal aisle" floor plan (with an aisle passing by the
bathroom (a side-bath type arrangement), my Splende is located on the
centerline of the coach, in a full-height closet (linens go above the
washer). This also puts the outlet for the dryer vent located up
high, above the axle area, just in front of the differential. The
back of the washer is against the bedroom bulkhead. There is no
access from the back side.
A search for the vent-exit from the outside proved fruitless. (The
dryer was almost totally ineffective, and I made the assumption that
the vent was blocked.)
I eventually had to pull the Splende out of its closet.
Unfortunately, the tight installation requires removing one of the
hinged doors to the washer/linen closet. Of course, BB used a piano
hinge with nearly a dozen screws -- at least they only did every
other screw.
Only a relatively small amount of lint was found behind (and under)
the washer. I discovered that years of lint build up at the screen
(to keep vermin out) at the dryer vent exit had formed a thick (1/2
inch) nearly solid seal -- it was not wonder the dryer didn't work!
The hoses looked to be in good condition -- but replacing them with
steel-braid replacements would probably be a good precaution (why
didn't I think of that while I had the washer out...). The water
outlet is, as you said, simply a typical curved 'hook' from the
washer feeding into a standing pipe connected with the plumbing. I
suspect that the tube isn't sealed to allow venting which might
otherwise cause undesirable back pressure. We have not experienced
any unpleasant sewer odors from the washer vent line. Isn't there a
trap to block odors from the holding tank? (I don't recall seeing one
in my installation, but then I don't recall not seeing one either.)
There was no sign (water spots, stains on unpainted wood, etc.) that
the outlet had ever overflowed. I do not have any moisture problems
in the washer/linen closet.
After cleaning the vent tube and outlet thoroughly, I re-installed
the washer as it had previously been -- and now the dryer, while
hardly impressive, does dry clothes. Due to the relatively small size
of the washer and anemic drying performance of the dryer (but it does
work and is consistent with reports from others) we still do the bulk
of our laundry at laundromats, etc.
Pete Masterson
aeonix1@...
On the road near Scranton, PA
> When
> hoses
> OK,and to
> Kurt Horvath
> 95 Pt 42
> 10AC
09-30-2008, 09:18
Washer/Dryer
Now were having fun! The dryer exhaust tube is pinched in half,
obviously when installed they just pushed the washer in and chinked
the tube. There was enough lint to weave a shirt, the water hose is
kinked in half and showing signs of cracking, the electric heater
under the W/D is not mounted very well it's just hanging on from the
grill and the air powered vent is seized up, the air cylinder is
functional and the on/off light is working for the first time ever.
The floor was cut away to allow access for the dryer vent hose but
they did not block it up in any way. So one side of the closet floor
is just hanging in air. Must have been a Friday Afternoon. Yes Pete I
did have to take the door off. No signs of any past water damage so
far. There is a small water trap but I sure in a few weeks of hot
weather when not being used it would evaporate. Still looking for the
elusive Pipe vent, I think it's behind the pantry.
Kurt Horvath
95 PT 42
10AC
- In WanderlodgeForum@yahoogroups.com, Pete Masterson
that
piano
> other screw.
under)
(1/2
with
a
one
that
problems
size
does
bulk
> Pete Masterson
> aeonix1@...
washer
finished
or
½"
question.
> > When
Near
old.
braided
> > hoses
need
> > OK,and to
> > Kurt Horvath
> > 95 Pt 42
> > 10AC
09-30-2008, 15:07
Washer/Dryer
There is a "P" trap in the waste water connection pipe leading to the
gray tank. If you don't use your washer every 4 to 6 weeks the "P"
trap will dry out and you will get funky odors out of the the closet
area.
I installed a 1/4" water line and valve to the drain that my Splendid
feeds. Every 3 or 4 weeks I give it a shot of water to fill the "p"
trap. You can also just run a "short" cycle on your washer, but I
fried one of the relays on the Splendid circuit board doing this. I
decided that the water line was a better alternative than replacing
the circuit board every few years.
Eric Perplies
96 42' WBWL
09-30-2008, 15:38
Washer/Dryer
Excellent idea Eric.
Since I have the W/D out of the closet, I'm redoing everything.
Bracing the floor and the electric heater, new hoses, a problem of
clearance with the dryer vent tube to resolve, and a rebuild on the
dryer vent shutter, I'm hoping it's not the air cylinder, I haven't
gotten at it yet.
The Perplies Ptrap Upgrade. Also a good way to add anti freeze the
Ptrap, not sure if filling the W/D with anti freeze is a good or bad
idea when you need to winterize.
Kurt Horvath
95 PT 42
10AC
--- In WanderlodgeForum@yahoogroups.com, "Eric Perplies"
> area.
Splendid
> Eric Perplies
> 96 42' WBWL
10-01-2008, 01:24
Washer/Dryer
Well, at least I didn't get a Friday afternoon job. Everything was
properly installed -- floor supported, etc. Must have been a
Wednesday, mid-morning installation....
I agree that the trap was small, so non-use of the washer and hot
weather could combine to allow some odor problems. My storage
location (in the SF Bay Area) doesn't present much of a challenge to
sewer traps, fortunately...
Pete Masterson
aeonix1@...
> Kurt Horvath
> 95 PT 42
> 10AC
> the
> the
> that
> piano
>> other screw.
> under)
> (1/2
> with
> a
> one
> that
> problems
> size
> does
> bulk
>> Pete Masterson
>> aeonix1@...
> washer
> finished
> or
> ½"
> question.
>>> When
> Near
> old.
> braided
>>> hoses
> need
>>> OK,and to
>>> Kurt Horvath
>>> 95 Pt 42
>>> 10AC
> Yahoo! Groups Links
10-01-2008, 08:29
Washer/Dryer
What do you guys think of poking a hole through the body to exhaust
the dryer staight out from the machine? The current vent system is a
wreck and isn't very effective even if it were rebuilt.
Kurt Horvath
95 PT 42
10AC
to
> Pete Masterson
> aeonix1@...
chinked
is
ever.
floor
Pete I
so
> > Kurt Horvath
> > 95 PT 42
> > 10AC
With
> > the
> > the
(The
> > that
> > piano
> >> other screw.
> > under)
screen
> > (1/2
work!
> > with
I
experienced
> > a
> > one
either.)
> > that
> > problems
installed
> > size
> > does
> > bulk
> >> Pete Masterson
> >> aeonix1@
> > washer
> > finished
The
> > or
> > ½"
one
> > question.
> >>> When
> > Near
> > old.
> > braided
> >>> hoses
I
> > need
> >>> OK,and to
in
> >>> Kurt Horvath
> >>> 95 Pt 42
> >>> 10AC
> > Yahoo! Groups Links
10-01-2008, 08:45
Washer/Dryer
Mine has side wall vent with a plastic louver vent.The louvers are flat when not working and open when the dryer is on. It works great.
Leroy Eckert
Dahlonega, GA
Royale Conversion
--- On Wed, 10/1/08, Kurt Horvath wrote:
Subject: [WanderlodgeForum] Re: Washer/Dryer
Date: Wednesday, October 1, 2008, 4:29 PM
Kurt Horvath
95 PT 42
10AC
In "WanderlodgeForum%40yahoogroups.com", Pete Masterson
> Wednesday, mid-morning installation. ...
to
> sewer traps, fortunately. ..
> Pete Masterson
> aeonix1@...
chinked
is
ever.
floor
Pete I
so
> > Kurt Horvath
> > 95 PT 42
> > 10AC
> > - In "WanderlodgeForum%40yahoogroups.com", Pete Masterson
> > wrote:
> >> It also depends on the installation/ floor plan in your coach..
With
> >> bathroom (a side-bath type arrangement) , my Splende is located on
> > the
> > the
(The
> > that
> > piano
> >> other screw.
> > under)
screen
> > (1/2
work!
> > with
I
experienced
> > a
> > one
either.)
> >> There was no sign (water spots, stains on unpainted wood, etc..)
> > that
> > problems
installed
> > size
> > does
> > bulk
> >> Pete Masterson
> >> aeonix1@
> > washer
> > finished
The
> > or
> > ½"
one
> > question.
> >>> When
> > Near
> > old.
> > braided
> >>> hoses
I
> > need
> >>> OK,and to
in
> >>> Kurt Horvath
> >>> 95 Pt 42
> >>> 10AC
> > Yahoo! Groups Links
