Generator tray re-model
10-18-2008, 04:42
Has anyone ripped out the big generator and replaced it with some
combination of a smaller generator, 2nd battery set, converter and solar panels. I'm figuring a 3kw generator, 5-600aH battery bank, appropriate converter/charger and solar panels would be really user friendly. Has anyone done this or something similar? Are you happy w/ what you did? Movin on down the road, GPSGary |
10-18-2008, 05:22
I haven't done it yet, but I'm definitely going to...
I'm leaning towards a generator with just enough juice to start one AC unit, and then about 1000 to 1500 AH of batteries, maybe even LiPoly batteries if they come down a little (in which case it would be more like 3000AH) Dorn Hetzel 77FC35 Hogansville, GA On Sat, Oct 18, 2008 at 12:42 PM, hippieforever3 <"debra@ticogps.com"> wrote:
10-18-2008, 15:56
I haven’t removed the Kohlar, but we do carry a Small (2800w) Honda. I first carried it because we get into some pretty cold weather dry camping and I was concerned about getting the diesels started in really cold weather. We have ended up using it other times to bring the batteries back up or for Kathy’s morning coffee when camping. It will run the microwave and water heater, or two of the block heaters, or one ac unit. I have a 7500w unit that I use when I have the Kohlar out. It will run everything. - Chuck Wheeler-
FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of hippieforever3 Sent: Saturday, October 18, 2008 11:42 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Generator tray re-model Has anyone ripped out the big generator and replaced it with some combination of a smaller generator, 2nd battery set, converter and solar panels. I'm figuring a 3kw generator, 5-600aH battery bank, appropriate converter/charger and solar panels would be really user friendly. Has anyone done this or something similar? Are you happy w/ what you did? Movin on down the road, GPSGary |
10-19-2008, 06:52
Gary - I have done what you suggest, except that the FC31 had a smaller
7.5KW genset to start with that is still in place. The new system has dual split/dual batteries for house and engine, smart chargers, AM Solar charging, a 'modified sine wave' inverter for the galley, and a smaller 'true sine wave' inverter for computers and entertainment electronics in the front salon. Very pleased with the results so far. The 200W solar system seems adequate for our needs but many find a 400W system more suitable. Additional info available. Bob Griesel FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" wrote: > > Has anyone ripped out the big generator and replaced it with some > combination of a smaller generator, 2nd battery set, converter and > solar panels. > > I'm figuring a 3kw generator, 5-600aH battery bank, appropriate > converter/charger and solar panels would be really user friendly. > > Has anyone done this or something similar? Are you happy w/ what you > did? > > Movin on down the road, > GPSGary > |
