6" SS EXHAUST STACK
10-21-2008, 07:11
6" SS EXHAUST STACK
Leroy- that Chrome shop is the best place to get stuff- I know it well.
83PT40
Weatherford, Texas
10-21-2008, 10:52
6" SS EXHAUST STACK
I WOULD LIKE TOBUY
6" Diameter, 66" in long, Stainless Steel Exhaust Stack ,with an expanded end &, curved out,.
I have looked high and low, I have called from coast to coast and from the Texas border to Ontario Canada.
Searched the net for hours, I've given up.
5" no problem, well less of a problem. 4" fairly common.
Some folks have them.
They had it put it in their coach.
Where did you get it?
Where can I get it?
Can anyone help?
Most of the parts are here or will be soon. I have a new muffler, but I don't want to use it.
I have painted it with ceramic paint and will sell it for what I have into it.
Kurt Horvath
95 PT 42
10AC
10-21-2008, 11:02
6" SS EXHAUST STACK
Kurt send me a private email with your phone number. I have a source for that stack
2008/10/21 Kurt Horvath <"kguns@hughes.net">
I WOULD LIKE TOBUY
Where can I get it?
Can anyone help?
Kurt Horvath
95 PT 42
10AC
Rob, Sue & Merlin Robinson
94 WLWB
10-21-2008, 11:05
6" SS EXHAUST STACK
I do not have any idea if this will help. In Wildwood, FL is 75 Chrome and Truck Stop. I do not have a link. I have been there and purchased various items for my bus. They have everything under the sun for trucks including exhaust so it is worth a try.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
--- On Tue, 10/21/08, Kurt Horvath wrote:
Subject: [WanderlodgeForum] 6" SS EXHAUST STACK
Date: Tuesday, October 21, 2008, 6:52 PM
I WOULD LIKE TOBUY
Where can I get it?
Can anyone help?
Kurt Horvath
95 PT 42
10AC
10-21-2008, 11:24
6" SS EXHAUST STACK
I could spend 8 hours in that place and drop $$$$$$$$$$$. I just like to sit in the model cab..
Leroy Eckert
Dahlonega, GA
--- On Tue, 10/21/08, erniecarpet@... wrote:
Subject: Re: [WanderlodgeForum] 6" SS EXHAUST STACK
Date: Tuesday, October 21, 2008, 7:11 PM
83PT40
Weatherford, Texas
10-21-2008, 16:28
6" SS EXHAUST STACK
When you figure it out Kurt, I'm all ears. I'd love to try a straight
pipe on my LXi.
David Brady
'02 LXi, NC
Kurt Horvath wrote:
I WOULD LIKE TOBUY
6" Diameter, 66" in
out,.
Ontario Canada.
5" no problem, well
their coach.
Where can I get it?
Can anyone help?
Kurt Horvath
95 PT 42
10AC
Internal Virus Database is out-of-date.
Checked by AVG. Version: 7.5.405 / Virus Database: 270.8.0/1715 - Release Date: 10/9/2008 12:00 AM
10-30-2008, 04:37
6" SS EXHAUST STACK
Kurt- is your engine access in your rear closet floor?
83PT40
Weatherford, Texas
10-30-2008, 06:05
6" SS EXHAUST STACK
I kinda wish Bluebird had copied a little from Prevost. Their engine compartment is very accessable.
83PT40
Weatherford, Texas
10-30-2008, 08:30
6" SS EXHAUST STACK
Unfortunate News,
I received news this morning that Bluebird is unable to supply exhaust pipes for the PT 42 Coaches. Unfortunate but not surprising. I had already begun fabrication of a system in lieu of such an event and I have started manufacturing a 304 Stainless Steel Exhaust systems for the PT 42.
The new exhaust system has some modifications to improve it's scavenging capabilities and for simplification of installation. I have reduced the system to three bends from four bends. Installed a SS Flex coupler with a SS liner designed for heavy flow turbocharger applications, SS V-Band clamps with SS Machined Flanges to connect all the sections, A SS 5" Stack with internal baffles with a sound absorbing ceramic coating. This stack is designed by the race car sector and while not as quite as a muffler it is better than a straight pipe and does not reduce or restrict exhaust flow. Also available is a SS Muffler that is compatible with this exhaust system and could be used in place of the aforementioned pipe, I choose not to use it due to back ordered status and it is 3X the price of the custom built stack. Some SS and chrome plated hangers supports and stack clamps.
The original mounting hardware will be discarded as well. The support arm that is mounted to the engine is designed to support the pipes, but in my estimation it only contributes to added vibration to the pipes.. In lieu of that support there will be a flexible hanger mounted to the ceiling of the engine bay and clamped after the flex connector, ( not in front of it as in the original design ), to support the middle section of pipe.
I am also having exhaust blankets made for all pipe systems in the coach, Exhaust, Air Exchanger, Radiator. Air Induction, Air Filter, While I have read as much as I could, and considered all of the Pros and Cons of exhaust blankets I have formulated the opinion the due to the heat, all types of heat, generated by the motor in the engine bay. That it's effect on all systems are compromised and it's corresponding effect on the potential gains in efficiency cannot be attained without them.
In the past 2 ½ years of having my coach serviced at Prevost in Nashville I have queried every coach owner I've meet on MPG of their coaches in casual conversation. The one constant observation I have made is the coaches that claim the best mileage all have insulated plumbing. Not imperial evidence but it cannot be ignored.
So in conclusion. Necessity is the Mother of Invention. The results will be a rust proof and greatly strengthen & enhanced exhaust system. If practical and feasible, I may offer this exhaust system to the public once that has been determined.
I will post photos soon.
Looking back at some of these past posts, I should mention that I broke down and pulled up the carpet in the bedroom over the doghouse. No access!!!!!!!!!!!!
________________________________________________________________________________​_______________
Kurt Horvath
95 PT 42 WLWB
10AC
> pipe on my LXi.
> David Brady
> '02 LXi, NC
> Kurt Horvath wrote:
> > */__/*
> > */_I WOULD LIKE TO BUY _/*
> > */_ 6" Diameter, 66" in long, Stainless Steel Exhaust Stack ,with an
> > expanded end &, curved out,._/*
> > */I have looked high and low, I have called from coast to coast and
> > from the Texas border to Ontario Canada. /*
> > */Searched the net for hours, I've given up./*
> > */5" no problem, well less of a problem. 4" fairly common./*
> > */Some folks have them. /*
> > */They had it put it in their coach./*
> > */Where did you get it?/*
> > */Where can I get it?/*
> > */Can anyone help?/*
> > */Most of the parts are here or will be soon. I have a new muffler,
> > but I don't want to use it./*
> > */I have painted it with ceramic paint and will sell it for what I
> > have into it./*
> > */Kurt Horvath/*
> > */95 PT 42/*
> > */10AC/*
> > Checked by AVG.
10-30-2008, 08:53
6" SS EXHAUST STACK
What result would be if you went from a 6" exhaust to a 5" muffler ? I know when Ron Marabito replaced his muffler, I believe 6 " stainless was either unobtainum or over priced. It took us a day to install the flex pipes and muffler. Maybe it was the novices doing the work?~ Ask me about floorcovering.
83PT40
Weatherford, Texas
