To Idle or Not to Idle? If So, How Long?
10-29-2008, 00:08
Howdy, Y'all.
Puleeze settle this "discussion" that Jack and I are having.
Question #1:
Jack says the normal oil temperature is 230 degrees. Jack was told toturn the engine off after the oil temp gets down to 200 degrees. Thenone can turn off the engine without damaging the turbocharger. Is thistrue for our 8v92? İmage İmage
Question #2:
When we stop at a rest area to have lunch or for Jack to rest, I wantto turn off the engine and not burn that expensive diesel. What doesthe oil temp have to be, before we turn off the engine?
TIA,
Liz
__________________
Regards,
Jack and Liz Pearce
Fulltiming in a 1993 WLWB
Summering in Buena Vista, CO
10-29-2008, 01:06
THis is the same procedure I follow...high idle, fan on, until oil is
below 200. By that point the coolant temp is pretty low as well.
Scott Forman
86 PT38
Memphis
--- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce"
> Howdy, Y'all.
> Question #1:
Is
> thistrue for our 8v92? [Confused] [Confused]
> Question #2:
wantto
doesthe oil
> TIA,
> Liz __________________
> Regards,
> Jack and Liz Pearce
10-29-2008, 03:15
The DD manual with my Series 60 states: "cool down" and idle the
engine for 4 minutes before shutting down. (I have a small digital
timer clipped to my steering wheel.)
As a practical matter, when the oil temp is below 200 and if the
engine has been at idle speed for at least a couple of minutes, then
it's relatively safe to shut down the engine without damage.
If I pull off the freeway directly into a rest stop, then I set the
timer for 4 minutes -- check the temp and shut down when the timer
sounds. If I've been driving over relatively flat city streets at
very modest speeds, then I idle for one to two minutes before
shutting down.
While there are several differences between the 8v92 and the Series
60, the cool down of the turbo is similar on both engines.
Pete Masterson
aeonix1@...
On the road at Mt. Airy, NC
On Oct 29, 2008, at 7:08 AM, Jack and Liz Pearce wrote:
> Howdy, Y'all.
> Question #1:
> Question #2:
> TIA,
> Liz
> __________________
> Regards,
> Jack and Liz Pearce
10-29-2008, 10:18
My owner's manual for the 8V92 said something about "Don't idle; turn
off the engine when not driving as it wastes fuel." I adhere to it,
but I do allow a brief cool down period to get the oil temp around 200
before shutting down. That normally takes less than a couple of
minutes.
During normal city driving my oil temp stays around 200 degrees. It
runs 215-230 degrees or so on the open freeway, especially climbing a
grade. I high idle the engine after stopping if the oil temperature is
much above 200, and turn things off around 200 give or take a few
degrees. Note that this only occurs RIGHT after pulling off the
freeway and stopping, such as a rest area. If I have to drive through
town a bit, or around a parking lot, etc, by the time I get parked the
temp has already come down and I just shut the engine off without
waiting.
However, in any case there should be no need to high idle for more
than a few minutes. If I'm just taking a quick break - run to the
bathroom and grab a drink, then get back on the road - I leave the
engine running. If I'm going to be 10-15 minutes or more, I shut it
down once oil temp is around 200.
-Ryan
'86 PT-40 8V92
On Wed, Oct 29, 2008 at 4:08 AM, Jack and Liz Pearce
> Howdy, Y'all.
> Question #1:
> Question #2:
> TIA,
> Liz
> __________________
> Regards,
> Jack and Liz Pearce
10-30-2008, 00:28
In the heavy equipment field we always said 5 minute cool down, that gives the cooling system time to cool down, but also the turbocharge is probability running anywhere from 80000-100000 rpms if the engine is hot and been pulling, the 5 minutes gives the turbo time to spool down and will stop spinning when the engine is shut off, if you shut down hot ,the turbo can spin (without cooling oil) for 3- 4 minutes.
Just my two cents worth
RE
-------------- Original message from "Ryan Wright" : --------------
minutes.
waiting.
-Ryan
'86 PT-40 8V92
<"jacklizpearce%40gmail.com"> wrote:
> Howdy, Y'all.
> Question #1:
> Question #2:
> TIA,
> Liz
> __________________
> Regards,
> Jack and Liz Pearce
