Fridge quit cooling in the deep cold
12-21-2008, 04:58
In a message dated 12/21/2008 3:42:09 P.M. Central Standard Time, sundance101@... writes:
Wow! Guess I just slipped into the twilight zone. Was just reading Just a little Yahoo weirdness. I have had that happen, many times.
Ernie Ekberg 83PT40 Wanderlodge Weatherford, Texas |
12-21-2008, 09:36
> > On Fri, Dec 19, 2008 at 3:56 PM, timvasqz > > boiler cant make enough heat to gas off the ammonia, prob spending > > too much of its heat overcomming the ambient temps??????. > > Sounds like what I was thinking, Greg. Curious if anyone else has the > same problem under prolonged 0 degree temps? Want to make sure it > isn't just me. > I checked on our running Dometic today after several nights of temps in the low teens. The freezer had water where there should have been ice cubes. Bob Griesel '84 FC31 WLII WA |
12-21-2008, 09:41
this afternoon's posts when my message from yesterday popped up again. !?!?! Bob Griesel --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > > > > On Fri, Dec 19, 2008 at 3:56 PM, timvasqz > > > boiler cant make enough heat to gas off the ammonia, prob spending > > > too much of its heat overcomming the ambient temps??????. > > > > Sounds like what I was thinking, Greg. Curious if anyone else has the > > same problem under prolonged 0 degree temps? Want to make sure it > > isn't just me. > > > > I checked on our running Dometic today after several nights of temps in > the low teens. The freezer had water where there should have been ice > cubes. > > Bob Griesel '84 FC31 WLII WA > |
12-21-2008, 23:22
12-22-2008, 06:17
I have found that we have to run on gas when it is very cold. The electric option will not keep the refrigerator cold. Probably not enough heat generated to boil the ammonia for operation.
- Chuck Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of GARY MINKER Sent: Monday, December 22, 2008 5:22 AM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: Fridge quit cooling in the deep cold
12-23-2008, 10:40
Thanks for the continued replies, folks.
1. Haven't checked the gas regulator... but my LP furnaces are all operating simultaneously and producing plenty of hot air, so I'm assuming nothing is wrong there. 2. I'm parked at home and the coach is level. 3. The exhaust fans up top are turned off. 4. Lastly... I now have a mild, but easily discernible, ammonia smell in the fridge. ... That can''t be good? -Ryan On Sun, Dec 21, 2008 at 7:06 AM, sfedeli3 <sfedeli3@...> wrote: > Ryan (and others)- Have you checked the performance of the gas > regulator? I was attempting to fire up my smoker yesterday and could > not get the flame to come up very high- turns out that the regulator > was not working "as well" in colder temps and was freezing up. > Replaced it with a new regulator and everything was fine. If your > coach has the original gas regulator(s) in the refer compartment and > on the tank- that "could" be your problem. > > Shane Fedeli > 85PT40 > Hershey, PA |
12-23-2008, 11:56
That ammonia smell means that you will be in the market for a new fridge. Sorry, the old one is toast. Ernie-83PT40 in Texas
-----Original Message----- From: Ryan Wright To: WanderlodgeForum@yahoogroups.com Sent: Tue, 23 Dec 2008 4:40 pm Subject: Re: [WanderlodgeForum] Re: Fridge quit cooling in the deep cold Thanks for the continued replies, folks.
1. Haven't checked the gas regulator... but my LP furnaces are all operating simultaneously and producing plenty of hot air, so I'm assuming nothing is wrong there. 2. I'm parked at home and the coach is level. 3. The exhaust fans up top are turned off. 4. Lastly... I now have a mild, but easily discernible, ammonia smell in the fridge. ... That can''t be good? -Ryan On Sun, Dec 21, 2008 at 7:06 AM, sfedeli3 <"sfedeli3%40comcast.net"> wrote: > Ryan (and others)- Have you checked the performance of the gas > regulator? I was attempting to fire up my smoker yesterday and could > not get the flame to come up very high- turns out that the regulator > was not working "as well" in colder temps and was freezing up. > Replaced it with a new regulator and everything was fine. If your > coach has the original gas regulator(s) in the refer compartment and > on the tank- that "could" be your problem. > > Shane Fedeli > 85PT40 > Hershey, PA |
12-23-2008, 12:30
I like the amonia refers as we tailgate and drycamp alot. to
replace an entire box I understand the windshield needs to come out. here is where I would go to buy new mechanicals for the origional refer http://www.rvmobile.com/ look at the cooling unit column and run those hyperlinks GregoryO'Connor ofTim&Greg 94ptCa --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Thanks for the continued replies, folks. > > 1. Haven't checked the gas regulator... but my LP furnaces are all > operating simultaneously and producing plenty of hot air, so I'm > assuming nothing is wrong there. > > 2. I'm parked at home and the coach is level. > > 3. The exhaust fans up top are turned off. > > 4. Lastly... I now have a mild, but easily discernible, ammonia smell > in the fridge. ... That can''t be good? > > -Ryan > > On Sun, Dec 21, 2008 at 7:06 AM, sfedeli3 <sfedeli3@...> wrote: > > Ryan (and others)- Have you checked the performance of the gas > > regulator? I was attempting to fire up my smoker yesterday and could > > not get the flame to come up very high- turns out that the regulator > > was not working "as well" in colder temps and was freezing up. > > Replaced it with a new regulator and everything was fine. If your > > coach has the original gas regulator(s) in the refer compartment and > > on the tank- that "could" be your problem. > > > > Shane Fedeli > > 85PT40 > > Hershey, PA > |
12-23-2008, 12:41
Ryan- sounds like she's dead. If you smell ammonia, that's usually the
last gasp of a dead fridge. Good luck- the RV market needs a little "stimulus" spending right now. I'm sure that Camping World will be glad to see you. If you never dry-camp, give Ernie's idea some serious thought. -Shane --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Thanks for the continued replies, folks. > > 1. Haven't checked the gas regulator... but my LP furnaces are all > operating simultaneously and producing plenty of hot air, so I'm > assuming nothing is wrong there. > > 2. I'm parked at home and the coach is level. > > 3. The exhaust fans up top are turned off. > > 4. Lastly... I now have a mild, but easily discernible, ammonia smell > in the fridge. ... That can''t be good? > > -Ryan > > On Sun, Dec 21, 2008 at 7:06 AM, sfedeli3 <sfedeli3@...> wrote: > > Ryan (and others)- Have you checked the performance of the gas > > regulator? I was attempting to fire up my smoker yesterday and could > > not get the flame to come up very high- turns out that the regulator > > was not working "as well" in colder temps and was freezing up. > > Replaced it with a new regulator and everything was fine. If your > > coach has the original gas regulator(s) in the refer compartment and > > on the tank- that "could" be your problem. > > > > Shane Fedeli > > 85PT40 > > Hershey, PA > |
12-23-2008, 16:31
I replaced our refrigerator last year and did not have to remove the windshield.
I did remove the doors off the refer and the restraining strap on the entry door. It was tight, but it fit with no problem. Glenn --- In WanderlodgeForum@yahoogroups.com, "timvasqz" > > I like the amonia refers as we tailgate and drycamp alot. to > replace an entire box I understand the windshield needs to come out. > here is where I would go to buy new mechanicals for the origional > refer > http://www.rvmobile.com/ > > look at the cooling unit column and run those hyperlinks > > > GregoryO'Connor ofTim&Greg > 94ptCa > > --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > > > > Thanks for the continued replies, folks. > > > > 1. Haven't checked the gas regulator... but my LP furnaces are all > > operating simultaneously and producing plenty of hot air, so I'm > > assuming nothing is wrong there. > > > > 2. I'm parked at home and the coach is level. > > > > 3. The exhaust fans up top are turned off. > > > > 4. Lastly... I now have a mild, but easily discernible, ammonia > smell > > in the fridge. ... That can''t be good? > > > > -Ryan > > > > On Sun, Dec 21, 2008 at 7:06 AM, sfedeli3 <sfedeli3@> wrote: > > > Ryan (and others)- Have you checked the performance of the gas > > > regulator? I was attempting to fire up my smoker yesterday and > could > > > not get the flame to come up very high- turns out that the > regulator > > > was not working "as well" in colder temps and was freezing up. > > > Replaced it with a new regulator and everything was fine. If your > > > coach has the original gas regulator(s) in the refer compartment > and > > > on the tank- that "could" be your problem. > > > > > > Shane Fedeli > > > 85PT40 > > > Hershey, PA > > > |
