Suspension not filling up...??? Tag pressure not going up???
01-18-2009, 10:30
Hello...All... as always I greatley appreciate any assistance from the
group...
I am getting ready to make the journey to the Q-ralley and I went to
drive our 84 PT-40 for a quick trip and I cannot get the suspension to
fill....
The front & rear pressure reads 75 pounds but the tag pressure is
zero.....
I have filpped both dump switches repeatedly but no change....
any suggestions????
01-18-2009, 10:55
air up your tanks with the suspension fill switches off. Let it blow off and then flip your switches.
Ernie Ekberg 83PT40 in Texas
In a message dated 01/18/09 16:30:45 Central Standard Time, brianp@... writes:
group...
fill....
zero.....
any suggestions????
01-18-2009, 10:56
Dump switch in "UP" position.
Then possiblities are governor, compressor, compressor belt,
But first check for an air leak.
Bill 88 FC Michigan
> group...
to
to
> fill....
> zero.....
> any suggestions????
01-18-2009, 10:56
Bill, our air compressor is direct drive. Wish I was going to Q.
In a message dated 01/18/09 16:56:35 Central Standard Time, billpatty@... writes:
Bill 88 FC Michigan
> group...
to
to
> fill....
> zero.....
> any suggestions????
01-18-2009, 11:06
Opps, No belt, Just like my pants,
I wish I was the fourth Amigo.........
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, erniecarpet
> Bill 88 FC Michigan
from
> the
> > group...
> to
suspension
> to
> > fill....
> > zero.....
> > any suggestions????
01-18-2009, 15:26
Keep in mind that the Front/Rear are brakes, not air bags. Those should peak
around 120psi.
In mine, the sequence is that the brakes air first, to about 75-90lbs, then the
air bags, then the auxiliary items, then the brakes fill the rest of the way. If
yours is the same, it sounds like something is leaking badly during the air bag
fill.
Don Bradner
90 PT40 "Blue Thunder"
Posting today by satellite from Quartzsite
>group...
>fill....
>zero.....
>any suggestions????
>Yahoo! Groups Links
01-18-2009, 17:19
Thank You everybody for your suggestions......
A combination of filling the suspension a few times after a short
around the block drive did the trick!!!!!!
However is this a sign of something on its way to a failure???
or... is it simply a sign of older parts that every once in awhile
need a little kick start to get going???
the bird did 'rest' for 6 months since it's last venture....
but she is up and ready to go now...
again thank you all for your suggestions...
should peak around 120psi.
90lbs, then the air bags, then the auxiliary items, then the brakes
fill the rest of the way. If yours is the same, it sounds like
something is leaking badly during the air bag fill.
> Don Bradner
> >group...
to
suspension to
> >fill....
> >zero.....
> >any suggestions????
> >Yahoo! Groups Links
01-19-2009, 03:40
I had many problems with this. When you flip the tag axle switch do you hear a rush of air?? On my wbwl when you remove the front panell covering the electric in the center od the coach there are three valves (forgot the name) they some times got stuck so the tag would not fill. flip the switch ah tap on there valves. I ended up replacing them and solved the problem
Jim Riordan
88 WBWL XXV
Stuart, Fl
772-260-1328
group...
fill....
zero.....
any suggestions????
01-19-2009, 03:45
I might of misread your post...main pressure guage only 75 pounds? sb 120, possible leak in air system. run bus pressure up shut off buss (carefully listen for leaks.). I had to replace the air dryer, in front of the rear axles in the center of the coach, underneath, this helped with the system spped in filling.
Jim Riordan
group...
fill....
zero.....
any suggestions????
01-19-2009, 04:18
IF your location is in a temperature below 32* freeze area,
moisture, & condensation will cause all kinds of strange issues.
there are numerous check valves , pressure reducing,etc valves, with
diaphragms that do not like freezing temps.
Bill 88 FC michigan
> > Don Bradner
from
> the
> > >group...
went
> to
> suspension to
> > >fill....
is
> > >zero.....
> > >any suggestions????
> > >Yahoo! Groups Links
