94pt air compressor coolant lines total shut down
02-05-2009, 14:00
Ed, here is the link to previous thread on the two issues you are
addressing. read entire thread as first repair ws not the fix Rear DDec computer circuit breakers and circuit breaker for the switch selector to chose front or rear engine start http://autos.groups.yahoo.com/group/Wand...sage/37236 pics 3fuses http://www.pbase.com/gregoryoc/image/102912951 I would not rely on the 40 foot of thin wire running the entire bus. I fixed the fuse but added a good source of power to the ignition from under the front pannel. prob is you can now start the bus from the cockpit when it shows choice of only rear start. I dont have the guts to stand behind the bus and start it anyway. Coolant lines to aircompressor replacement. http://autos.groups.yahoo.com/group/Wand...sage/36552 long line above starter http://www.pbase.com/gregoryoc/image/102146419 compressor from bedroom http://www.pbase.com/gregoryoc/image/102145955 Petes road service Corona is a good place to do tires. they have an alignment shop and that will keep the powersteering from heating up the fluid as you strain the pump to keep the wheels straight. Most folks replace their ps pumps when they boil over thinking generation of pressure is the issue when it is usuly excessive/continual demand of pressure which causes hot psf. when you drop the tires I will buy the old ones as I use them up in 8 months on my dump truck rear. Gregory O'Connor 951-830-5997 ofTim&Greg |
