Dometic refrigerator
06-01-2005, 14:37
Folks,
My refrigerator is very, very difficult to open - sometimes. My wife has to really tug on the handle, and I use the freezer door handle as a fulcrum to apply leverage to get the door open. It is intermittent though. Sometimes it opens easily, other times it's next to impossible. The door seems to use a garden variety magnetic seal which shouldn't be able to apply this kind of clamping force. There has to be a vacuum effect taking place inside the fridge, but the hose leading from the drip plate just below the inside cooling fins is free and clear. Anyone else have this problem? TIA, Dave '02 LXi, Smokey Virginia -- Internal Virus Database is out-of-date. Checked by AVG Anti-Virus. Version: 7.0.322 / Virus Database: 266.11.17 - Release Date: 5/25/2005 |
06-01-2005, 14:39
Dave:
Is the slide lock in the handle broken or the spring missing causing it to partly lock in place? Just a thought. Safe travels, Ralph and Charolette Fullenwider Dream_35_Team '85FC35 in Oklahoma Ralph's RV Solutions http://home.swbell.net/rlf47/index.htm At 10:37 PM 6/1/2005 -0400, you wrote: >Folks, > >My refrigerator is very, very difficult to open - >sometimes. My wife has to really tug on the handle, >and I use the freezer door handle as a fulcrum >to apply leverage to get the door open. It is >intermittent though. Sometimes it opens easily, >other times it's next to impossible. The door >seems to use a garden variety magnetic seal >which shouldn't be able to apply this kind of >clamping force. There has to be a vacuum >effect taking place inside the fridge, but the >hose leading from the drip plate just below >the inside cooling fins is free and clear. Anyone >else have this problem? > >TIA, >Dave >'02 LXi, Smokey >Virginia |
06-01-2005, 14:46
Dave:
Does it happen mostly when re-opening after closing, especially just after closing the freezer door? I have had this problem, after closing the door the air inside rapidly cools and contracts, causing a vacuum strong enough to prevent normal opening for about 10seconds (can hear the air pull in around the seal). - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > Folks, > > My refrigerator is very, very difficult to open - > sometimes. My wife has to really tug on the handle, > and I use the freezer door handle as a fulcrum > to apply leverage to get the door open. It is > intermittent though. Sometimes it opens easily, > other times it's next to impossible. The door > seems to use a garden variety magnetic seal > which shouldn't be able to apply this kind of > clamping force. There has to be a vacuum > effect taking place inside the fridge, but the > hose leading from the drip plate just below > the inside cooling fins is free and clear. Anyone > else have this problem? > > TIA, > Dave > '02 LXi, Smokey > Virginia > > > -- > Internal Virus Database is out-of-date. > Checked by AVG Anti-Virus. > Version: 7.0.322 / Virus Database: 266.11.17 - Release Date: 5/25/2005 |
06-01-2005, 16:22
Ralph, Jeff,
Thanks for your replies. It doesn't seem to be the latch. The latch is a pin at the top of the door which clearly retracts when I press the lever at the door handle. It does seem to be associated with a vacuum and seems to be related to cooling as Jeff suggested. If I open and close the door in quick succession, it's easy. If I wait a minute, then it's very difficult. The rapid cooling idea seems to fit. Isn't there some kind of pressure relief inside the refrigerator chamber? Dave Jeff Miller wrote: >Dave: > >Does it happen mostly when re-opening after closing, especially just >after closing the freezer door? I have had this problem, after >closing the door the air inside rapidly cools and contracts, causing >a vacuum strong enough to prevent normal opening for about 10seconds >(can hear the air pull in around the seal). > > - Jeff Miller > > >--- In WanderlodgeForum@yahoogroups.com, David Brady >wrote: > > >>Folks, >> >>My refrigerator is very, very difficult to open - >>sometimes. My wife has to really tug on the handle, >>and I use the freezer door handle as a fulcrum >>to apply leverage to get the door open. It is >>intermittent though. Sometimes it opens easily, >>other times it's next to impossible. The door >>seems to use a garden variety magnetic seal >>which shouldn't be able to apply this kind of >>clamping force. There has to be a vacuum >>effect taking place inside the fridge, but the >>hose leading from the drip plate just below >>the inside cooling fins is free and clear. Anyone >>else have this problem? >> >>TIA, >>Dave >>'02 LXi, Smokey >>Virginia >> >> >>-- >>Internal Virus Database is out-of-date. >>Checked by AVG Anti-Virus. >>Version: 7.0.322 / Virus Database: 266.11.17 - Release Date: >> >> >5/25/2005 > > > > > > >Yahoo! Groups Links > > > > > > > > > > > -- Internal Virus Database is out-of-date. Checked by AVG Anti-Virus. Version: 7.0.322 / Virus Database: 266.11.17 - Release Date: 5/25/2005 |
06-02-2005, 00:32
Hi Dave,
No need to feel alone with your Dometic, the Norcold plays the identical suction game, especially the right freezer side. I have heard Dometic and Norcold seminar speakers suggest the cause is a combination of "great sealing" combined with inadequate owner cleaning of the gaskets wherein food "sugars" breakdown chemically, become sticky and hold the gasket to the frame. I say, "nonsense." I've followed their recommendations for cleaning with warm soapy water after every trip and the one door still acts the same, but no others. Let's blame the engineers! ;-} John Suter 2000LXi Norcold 1200RIM --- David Brady > Folks, > > My refrigerator is very, very difficult to open - > sometimes. My wife has to really tug on the handle, > and I use the freezer door handle as a fulcrum > to apply leverage to get the door open. It is > intermittent though. Sometimes it opens easily, > other times it's next to impossible. The door > seems to use a garden variety magnetic seal > which shouldn't be able to apply this kind of > clamping force. There has to be a vacuum > effect taking place inside the fridge, but the > hose leading from the drip plate just below > the inside cooling fins is free and clear. Anyone > else have this problem? > > TIA, > Dave > '02 LXi, Smokey > Virginia > > > -- > Internal Virus Database is out-of-date. > Checked by AVG Anti-Virus. > Version: 7.0.322 / Virus Database: 266.11.17 - > Release Date: 5/25/2005 > > __________________________________ Discover Yahoo! Get on-the-go sports scores, stock quotes, news and more. Check it out! http://discover.yahoo.com/mobile.html |
06-02-2005, 04:20
FWIW, I have a built in refrigerator in our house that does the same
thing. I think it is an indication of getting a good seal, just the opposite if the usual complaint. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD John Suter wrote: > Hi Dave, > > No need to feel alone with your Dometic, the Norcold > plays the identical suction game, especially the right > freezer side. > > I have heard Dometic and Norcold seminar speakers > suggest the cause is a combination of "great sealing" > combined with inadequate owner cleaning of the gaskets > wherein food "sugars" breakdown chemically, become > sticky and hold the gasket to the frame. I say, > "nonsense." I've followed their recommendations for > cleaning with warm soapy water after every trip and > the one door still acts the same, but no others. > Let's blame the engineers! ;-} > > John Suter > 2000LXi Norcold 1200RIM > > > --- David Brady > > >>Folks, >> >>My refrigerator is very, very difficult to open - >>sometimes. My wife has to really tug on the handle, >>and I use the freezer door handle as a fulcrum >>to apply leverage to get the door open. It is >>intermittent though. Sometimes it opens easily, >>other times it's next to impossible. The door >>seems to use a garden variety magnetic seal >>which shouldn't be able to apply this kind of >>clamping force. There has to be a vacuum >>effect taking place inside the fridge, but the >>hose leading from the drip plate just below >>the inside cooling fins is free and clear. Anyone >>else have this problem? >> >>TIA, >>Dave >>'02 LXi, Smokey >>Virginia >> >> >>-- >>Internal Virus Database is out-of-date. >>Checked by AVG Anti-Virus. >>Version: 7.0.322 / Virus Database: 266.11.17 - >>Release Date: 5/25/2005 >> >> > > > > > > __________________________________ > Discover Yahoo! > Get on-the-go sports scores, stock quotes, news and more. Check it out! > http://discover.yahoo.com/mobile.html > > > > > Yahoo! Groups Links > > > > > > > > > |
06-02-2005, 05:22
John I cant see how a dometic could ever establish a vacuum in the
refrigerator if the vent tube that runs from a tray just under the freezer to the outside is properly routed and not plugged. I have never had that problem with either new Dometic that I installed over the last 5 years. Tom 1982 FC35 Vernon Center,NY At 05:32 AM 6/2/2005 -0700, you wrote: >Hi Dave, > > No need to feel alone with your Dometic, the Norcold >plays the identical suction game, especially the right >freezer side. > > I have heard Dometic and Norcold seminar speakers >suggest the cause is a combination of "great sealing" >combined with inadequate owner cleaning of the gaskets >wherein food "sugars" breakdown chemically, become >sticky and hold the gasket to the frame. I say, >"nonsense." I've followed their recommendations for >cleaning with warm soapy water after every trip and >the one door still acts the same, but no others. >Let's blame the engineers! ;-} > >John Suter >2000LXi Norcold 1200RIM > > >--- David Brady > > > Folks, > > > > My refrigerator is very, very difficult to open - > > sometimes. My wife has to really tug on the handle, > > and I use the freezer door handle as a fulcrum > > to apply leverage to get the door open. It is > > intermittent though. Sometimes it opens easily, > > other times it's next to impossible. The door > > seems to use a garden variety magnetic seal > > which shouldn't be able to apply this kind of > > clamping force. There has to be a vacuum > > effect taking place inside the fridge, but the > > hose leading from the drip plate just below > > the inside cooling fins is free and clear. Anyone > > else have this problem? > > > > TIA, > > Dave > > '02 LXi, Smokey > > Virginia > > > > > > -- > > Internal Virus Database is out-of-date. > > Checked by AVG Anti-Virus. > > Version: 7.0.322 / Virus Database: 266.11.17 - > > Release Date: 5/25/2005 > > > > > > > > >__________________________________ >Discover Yahoo! >Get on-the-go sports scores, stock quotes, news and more. Check it out! >http://discover.yahoo.com/mobile.html > > > > >Yahoo! Groups Links > > > > |
06-02-2005, 07:38
Tom, our vacuum develops in the right-hand freezer
section of the Norcold. Both freezer sections appear sealed and I don't recall seeing any vent tubes from there; however, the refrigerator has a catch pan under its fins, with a tube to the rear and outside for drainage. John --- Tom Warner > John I cant see how a dometic could ever establish a > vacuum in the > refrigerator if the vent tube that runs from a tray > just under the freezer > to the outside is properly routed and not plugged. I > have never had that > problem with either new Dometic that I installed > over the last 5 years. > > Tom > 1982 FC35 > Vernon Center,NY > > At 05:32 AM 6/2/2005 -0700, you wrote: > >Hi Dave, > > > > No need to feel alone with your Dometic, the > Norcold > >plays the identical suction game, especially the > right > >freezer side. > > > > I have heard Dometic and Norcold seminar > speakers > >suggest the cause is a combination of "great > sealing" > >combined with inadequate owner cleaning of the > gaskets > >wherein food "sugars" breakdown chemically, become > >sticky and hold the gasket to the frame. I say, > >"nonsense." I've followed their recommendations > for > >cleaning with warm soapy water after every trip and > >the one door still acts the same, but no others. > >Let's blame the engineers! ;-} > > > >John Suter > >2000LXi Norcold 1200RIM > > > > > >--- David Brady > > > > > Folks, > > > > > > My refrigerator is very, very difficult to open > - > > > sometimes. My wife has to really tug on the > handle, > > > and I use the freezer door handle as a fulcrum > > > to apply leverage to get the door open. It is > > > intermittent though. Sometimes it opens easily, > > > other times it's next to impossible. The door > > > seems to use a garden variety magnetic seal > > > which shouldn't be able to apply this kind of > > > clamping force. There has to be a vacuum > > > effect taking place inside the fridge, but the > > > hose leading from the drip plate just below > > > the inside cooling fins is free and clear. > Anyone > > > else have this problem? > > > > > > TIA, > > > Dave > > > '02 LXi, Smokey > > > Virginia > > > > > > > > > -- > > > Internal Virus Database is out-of-date. > > > Checked by AVG Anti-Virus. > > > Version: 7.0.322 / Virus Database: 266.11.17 - > > > Release Date: 5/25/2005 > > > > > > > > > > > > > > > >__________________________________ > >Discover Yahoo! > >Get on-the-go sports scores, stock quotes, news and > more. Check it out! > >http://discover.yahoo.com/mobile.html > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > __________________________________ Discover Yahoo! Use Yahoo! to plan a weekend, have fun online and more. Check it out! http://discover.yahoo.com/ |
06-02-2005, 07:52
Simple physics. The cooling air contracts, if there is insufficient
make-up air volume to keep up with the contracting air then a parital vacuum is established. It is possible that your Dometics didn't seal properly, I have found that the Norcold tends to seal better, and the units larger than your FC model are more prone to the temporary vacuum, especially the side-by- side. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > John I cant see how a dometic could ever establish a vacuum in the > refrigerator if the vent tube that runs from a tray just under the freezer > to the outside is properly routed and not plugged. I have never had that > problem with either new Dometic that I installed over the last 5 years. > > Tom > 1982 FC35 > Vernon Center,NY |
06-02-2005, 11:05
Dave,
What's the issue? Too many of us cannot keep the refrigerator door closed. Have you looked at some of the rally pictures lately? ;-) Tom McCarthy 95 PT42 Poway, CA --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > Folks, > > My refrigerator is very, very difficult to open - > sometimes. My wife has to really tug on the handle, > and I use the freezer door handle as a fulcrum > to apply leverage to get the door open. It is > intermittent though. Sometimes it opens easily, > other times it's next to impossible. The door > seems to use a garden variety magnetic seal > which shouldn't be able to apply this kind of > clamping force. There has to be a vacuum > effect taking place inside the fridge, but the > hose leading from the drip plate just below > the inside cooling fins is free and clear. Anyone > else have this problem? > > TIA, > Dave > '02 LXi, Smokey > Virginia > > > -- > Internal Virus Database is out-of-date. > Checked by AVG Anti-Virus. > Version: 7.0.322 / Virus Database: 266.11.17 - Release Date: 5/25/2005 |
