Musical horn module
02-16-2009, 13:36
Musical horn module
Sorry,i posted this with wrong subject line
Trying to find the location of my musical hornmodule.There is a blue ribbon wire at the switches that goes into an abyss up under the dash and disappears.
I assume it is behind the lower dash but if someone knows for certain I might save a little time.
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge WLWB41
02-16-2009, 14:37
Musical horn module
Our coaches are far apart year-wise, but mine is located behind the
panel in front of the co-pilot seat. It's a metal box about the size
of 2 decks of cards side by side. Wouldn't surprise me if yours is
there, too. Had mine reprogrammed 2 years ago.
Scott Forman
86 PT38
Memphis
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse"
> Trying to find the location of my musical horn module.There is a
> Fred & Jeanne Hulse
> Morristown Arizona
02-16-2009, 14:49
Musical horn module
Hi Scott
Thanks for responding,you are referring to the panel below the dashboard?
Fred & Jeanne Hulse
Morristown Arizona
02-16-2009, 14:51
Musical horn module
Hi ya Fred,
Mine is located inside the small locker, below the the radio/rear view
monitor. It is in the EXTREME rear of the locker, up high, on the
right side. After removing the door I could just reach the module. I
identified mine by the wide ribbon connector that plugs into it. If I
recall correctly there is a second smaller ribbon connector also
connected to the module.
Good luck and happy trails,
Eric Perplies
96 42 WBWL
02-16-2009, 15:20
Musical horn module
Hey Eric,
Thank you for the location,
I just went out and waded through a/c ducting and other things under there and located it!
Tomorrow I will see how to get it out successfully.
Missed you guys @ Quartzsite.
Fred & Jeanne Hulse
Morristown Arizona
02-17-2009, 02:37
Musical horn module
Hi guys,
My musical horn does not work either and I have also been trying to locate it. This is great info. Thanks for exploring it. I have a 1995 WLWB 42" and I am hoping that the module is also located at the same place as you guys.
Another question. where is the fuse located for this device if it has one?
Ron Thompson -Waller, Tx.
1995 WLWB 42'
(cockyfox@...)
--- On Mon, 2/16/09, Fred Hulse wrote:
Subject: Re: [WanderlodgeForum] Re: Musical horn module
Date: Monday, February 16, 2009, 9:20 PM
Hey Eric,
Fred & Jeanne Hulse
Morristown Arizona
02-17-2009, 02:53
Musical horn module
Hi Ron
The fuse is labeled#50 outsidein the front load center.
Fred & Jeanne Hulse
Morristown Arizona
02-17-2009, 03:05
Musical horn module
Fred,
Thanks for that info. Now to show my ignorance about everything on this coach. Where exactly is the outside front load center you are talking about? Is that the one on the front of the coach where you have to take the sheet metal panel off? No electrical info was in the blue box when I bought this coach from an RV dealer. I suspect that the techs that worked for them extracted all the schematics and drawings from the Blue Box.
I appreciate your help.
1995 WLWB 42'
(cockyfox@...)
Date: Tuesday, February 17, 2009, 8:53 AM
Hi Ron
Fred & Jeanne Hulse
Morristown Arizona
02-17-2009, 03:14
Musical horn module
Ron
You are correct.
The load center is behind that wide body panel above the headlites.
I think your coach has those aircraft style screws that twist90 degrees to release.
Fred & Jeanne Hulse
Morristown Arizona
02-17-2009, 03:20
Musical horn module
Fred,
Thanks, I thought that was what you meant. Yes it has those type screws. You don't happen to have a list of all those fuses and circuit breakers out there, do you, or know where I can get one?
Thanks again for your help. Things are so well hidden in these coaches that just searching without drawings or someone to help is futile.
1995 WLWB 42'
(cockyfox@...)
Date: Tuesday, February 17, 2009, 9:14 AM
Ron
You are correct.
Fred & Jeanne Hulse
Morristown Arizona
