Ultraguard Mud flap
03-16-2009, 13:35
Ultraguard Mud flap
Does anyone have one of those long mud flag/rock guards on their PT40? Mine
doesn't have one but it seems it may be helpful in keeping the rocks and oil off
the toad. As I mentioned before, the oil from the Detroit seems to end up on
the back of the coach and/or toad and I would like to cut that down.
If you use one, what do you recommend for an 85 PT40?
As always, I appreciate the knowledge and help on this board.
Jerry
85 PT40
Port Hueneme, CA
03-16-2009, 13:59
Ultraguard Mud flap
If you want Blue Bird Wanderlodge printed on the back, I can't help you, but Camping World has them.
http://www.campingworld.com/shopping/pro...uards/1450
Brad Barton 00LXiDFW bbartonwx@...
Date: Tue, 17 Mar 2009 00:35:10 +0000
Subject: [WanderlodgeForum] Ultraguard Mud flap
Does anyone have one of those long mud flag/rock guards on their PT40? Mine doesn't have one but it seems it may be helpful in keeping the rocks and oil off the toad. As I mentioned before, the oil from the Detroit seems to end up on the back of the coach and/or toad and I would like to cut that down.
Jerry
85 PT40
Port Hueneme, CA
Express your personality in color! Preview and select themes for Hotmail®. See how.
03-16-2009, 14:09
Ultraguard Mud flap
Brad,
I was more curious on whether or not people used them and there was one in
particular that worked better on a PT40. I've seen some pretty good ones
advertised on the internet and was hoping to get something tested and true by
Wanderlodge users.
Jerry
85 PT40
Port Hueneme, CA
> From: jburgessx2@...
> Jerry
> 85 PT40
> Port Hueneme, CA
> _________________________________________________________________
http://www.windowslive-hotmail.com/Learn...X_WL_\
HM_express_032009#colortheme
03-16-2009, 14:24
Ultraguard Mud flap
I have one on my PT38, was on there when I got the coach. Does not have any
brand name on it. I still get oil on the back of the coach and toad.
Scott Forman
86 PT38
Memphis
--- In WanderlodgeForum@yahoogroups.com, "jburgessx2" wrote:
> Brad,
Wanderlodge users.
> Jerry
> 85 PT40
> Port Hueneme, CA
> > From: jburgessx2@
> > Jerry
> > 85 PT40
> > Port Hueneme, CA
03-16-2009, 14:27
Ultraguard Mud flap
I wasn't aware that full-length mud flaps weren't standard! They definitely are
the best for toad protection, although having both wheel mud flaps and
full-length is a double-protection.
About all I can tell you is that it should be quite heavy.
Don Bradner
90 PT40 "Blue Thunder"
On 3/17/2009 at 1:09 AM jburgessx2 wrote:
>Brad,
>by Wanderlodge users.
>Jerry
>85 PT40
>Port Hueneme, CA
>cut that down.
>> Jerry
>> 85 PT40
>> Port Hueneme, CA
>Hotmail®.
>http://www.windowslive-hotmail.com/Learn...TX_WL\
_HM_express_032009#colortheme
>Yahoo! Groups Links
03-16-2009, 14:40
Ultraguard Mud flap
Don,
Well, I was hoping the extra long flap would curtail some of the oil - that's to
bad. Thanks for letting me know. I might still get one because it probably
will cut down on the rocks - couldn't hurt anyways. And, maybe it will keep
some of the oil off the toad and coach.
Jerry
85 PT40
Port Huemene, CA
--- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <scottforman75@...>
> Scott Forman
> 86 PT38
> Memphis
> > Brad,
Wanderlodge users.
> > Jerry
> > 85 PT40
> > Port Hueneme, CA
> > > From: jburgessx2@
> > > Jerry
> > > 85 PT40
> > > Port Hueneme, CA
03-16-2009, 15:05
Ultraguard Mud flap
Jerry,
I misunderstood your purpose. If you have an 8V92, even if you have relocated slobber tubes, you'll still have some oil vapor trailing you. But that's one of the very few minor disadvantages of an 8V.
Date: Tue, 17 Mar 2009 01:09:59 +0000
Subject: [WanderlodgeForum] Re: Ultraguard Mud flap
Brad,
I was more curious on whether or not people used them and there was one in particular that worked better on a PT40. I've seen some pretty good ones advertised on the internet and was hoping to get something tested and true by Wanderlodge users.
Jerry
85 PT40
Port Hueneme, CA
--- In "WanderlodgeForum@yahoogroups.com", brad barton <bbartonwx@.<WBR>..> wrote:
> http://www.campingworld.com/shopping/product/rock-solid-protective-guards/1450
> To: "WanderlodgeForum@yahoogroups.com"
> Jerry
> 85 PT40
> Port Hueneme, CA
> http://www.windowslive-hotmail.com/LearnMore/personalize.aspx?ocid=TXT_MSGTX_WL_HM_express_032009#colortheme
Windows Live™ Contacts: Organize your contact list. Check it out.
03-16-2009, 15:09
Ultraguard Mud flap
The only way your going to stop the oil mist on your coach and toad is to
install a CCVS Closed Crankcase Ventilation System.
I installed one on my coach and it stopped 99% of the misting problem.
I took my large flap off a few months age. The coach runs cooler. Got that tip
from some old Eagle converters, seems as though the large flap disturbs the air
flow in the engine compartment.
Kurt Horvath
95 PT 42
10AC
> Don,
to bad. Thanks for letting me know. I might still get one because it probably
> Jerry
> 85 PT40
> Port Huemene, CA
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <scottforman75@>
> > Scott Forman
> > 86 PT38
> > Memphis
> > > Brad,
Wanderlodge users.
> > > Jerry
> > > 85 PT40
> > > Port Hueneme, CA
> > > > From: jburgessx2@
> > > > Jerry
> > > > 85 PT40
> > > > Port Hueneme, CA
Hotmail®.
03-16-2009, 15:11
Ultraguard Mud flap
My 8V92 doesn't throw oil, happy to say!
On 3/17/2009 at 1:40 AM jburgessx2 wrote:
>Don,
>that's to bad. Thanks for letting me know. I might still get one because
>it probably will cut down on the rocks - couldn't hurt anyways. And,
>maybe it will keep some of the oil off the toad and coach.
>Jerry
>85 PT40
>Port Huemene, CA
>any brand name on it. I still get oil on the back of the coach and toad.
>> Scott Forman
>> 86 PT38
>> Memphis
>wrote:
>> > Brad,
>> > Jerry
>> > 85 PT40
>> > Port Hueneme, CA
>> > > From: jburgessx2@
>> > > Jerry
>> > > 85 PT40
>> > > Port Hueneme, CA
>Hotmail®.
>Yahoo! Groups Links
03-16-2009, 15:32
Ultraguard Mud flap
Kurt,
That sure sounds like a better idea. Are there any drawbacks to a CCVS?
Without being too nosey, are they expensive to buy and install? I really don't
like the idea of the spraying oil.
Jerry
85 PT40
Port Hueneme, CA
> Kurt Horvath
> 95 PT 42
> 10AC
> > Don,
that's to bad. Thanks for letting me know. I might still get one because it
probably will cut down on the rocks - couldn't hurt anyways. And, maybe it will
> > Jerry
> > 85 PT40
> > Port Huemene, CA
> > > Scott Forman
> > > 86 PT38
> > > Memphis
> > > > Brad,
Wanderlodge users.
> > > > Jerry
> > > > 85 PT40
> > > > Port Hueneme, CA
> > > > > From: jburgessx2@
> > > > > Jerry
> > > > > 85 PT40
> > > > > Port Hueneme, CA
Hotmail®.
