Power Seat problems
04-26-2009, 03:39
Power Seat problems
Hi!
The power seat control for the co-pilot's seat in our '86 PT-40 has decided it doesn't want to go back. All other directions work fine, so I'm pretty sure it's not the motor. Any insights or experience before I start tearing things apart? Thanks! Greg Young 1986 PT-40 "Bluefire" currently Escondido, CA at home base Each time you judge yourself you break your heart. -Kirpal Venanji |
04-26-2009, 04:12
Power Seat problems
Hi Greg:
3 choices. 1. Bad/corroded plug in or pins on connector to seat switch. 2. Corroded or broken wire, 3 bad motor. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 08:39 AM 4/26/2009 -0700, you wrote: >Hi! > >The power seat control for the co-pilot's seat in our '86 PT-40 has >decided it doesn't want to go back. All other directions work fine, so >I'm pretty sure it's not the motor. Any insights or experience before I >start tearing things apart? > >Thanks! >Greg Young >1986 PT-40 "Bluefire" >currently Escondido, CA at home base > >Each time you judge yourself you break your heart. >-Kirpal Venanji > > > |
04-26-2009, 04:20
Power Seat problems
04-26-2009, 09:05
Power Seat problems
If you havea 3 lever control on the wall likeI have in my 1985 PT40, it's a Chrysler power seat controll used in Chrysler vehicles in the late 1970s thru somewhere in the 1980s. If you take it apart and clean up the contacts and it still acts up, you can go to the auto salvage yard and find another one. It's best to take from the passenger side of the car, as that side probably has had much less use.
Wayne
1985 PT40
From: Greg Young To: Wanderlodge Forum Sent: Sunday, April 26, 2009 10:39:33 AM Subject: [WanderlodgeForum] Power Seat problems Hi! The power seat control for the co-pilot's seat in our '86 PT-40 has decided it doesn't want to go back. All other directions work fine, so I'm pretty sure it's not the motor. Any insights or experience before I start tearing things apart? Thanks! Greg Young 1986 PT-40 "Bluefire" currently Escondido, CA at home base Each time you judge yourself you break your heart. -Kirpal Venanji |
