12 volt problems (was comfort control 2003 LXI)
06-14-2009, 00:57
I've discovered that my water pump, am-fm radio, tank monitor, bedroom clock
etc. are also not working. Apparently a 12 volt problem someplace. Ray Pander 2003 LXI Now in Topsail Island, NC |
06-14-2009, 04:00
the newer rigs have a more advanced system of electronic control and wire loom.
I forget the name wanderlode system use. It would be fun to learn how these systems work but for repairs it might be best to spend the effort to find a shop or tech that wont be charging you tuition. These systems are a breeze with diagnostics which lead to quick repair if the tech has the equipment and ability. The systems are not very unique to just one brand but a god set of prints could save time in a repair shop. It may be that the biggest fail item (waterpump)in your list was the reason all the things went offline. If you find that it is a single fuse, I would simply replace the fuse then set up a way to power the pump independently or buy a new pump to keep the amp load of the old from popping the fuse????? There is no such thing as a bad fuse. Blown fuses are an 'issue result' not a cause. I like blade fuses over the automatic resettables because you never know if there is an issue with self resettables as they often reset out of any sign of a looming (pun) problem. Taillights are one of the places where selfresettables are dangerous. they often work when you start out a trip with cool bulbs and wires but go off during the run only to reset for the next pretrip checkup. Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "raypander" > > I've discovered that my water pump, am-fm radio, tank monitor, bedroom clock etc. are also not working. Apparently a 12 volt problem someplace. > > Ray Pander > 2003 LXI > Now in Topsail Island, NC > |
06-14-2009, 04:08
I found an old thread with some info on the old forum.
Greg of Tim and Greg 94ptca Re: [wanderlodge] Re: 450LXi multiplexed lighting ROTFLMBO! Hmmm, I've heard they're hiring... David Brady '02 LXi, Smokey NC Gregory OConnor wrote: > > David, your mistaken, BB engineeres used canabis not canbus. > Greg > > --- In wanderlodge@yahoogroups.com > > > > > I learned that the 450LXi uses a multiplexed house electrical > > control system made by Intellitec. Still trying to figure out if > > it's industry standard CAN Bus based. I sure hope it is. > > > > David Brady > > '02 LXi, Smokey > > NC > > > > Gary McFarland wrote: > > > > > > Well.... > > > > > > Some of my beer drinking buddies are in on the development of > canbus > > > systems at bosch. > > > > > > it is a great system for controlling a whole whopping bunch o' > stuff > > > with one wire, but interfacing to it in the aftermarket sucks > rocks. > > > > > > We have a standing problem here where integrating engine > management > > > systems knocks some of the gauges out of service. > > > > > > Gary > > > gearheadgary@... > > > http://www.gearheadgary.com > > > > > > ----- Original Message ---- > > > From: Ken Sann > > > To: wanderlodge@yahoogroups.com > > > > Sent: Wednesday, July 18, 2007 10:15:38 AM > > > Subject: Re: [wanderlodge] 450LXi multiplexed lighting > > > > > > Yup, 'sactly. A fantastic way to do things. Even one of my > motorcycles > > > is a > > > CANBUS system. > > > > > > ken > > > wannabe in SoCal > > > > > > On 7/18/07, Gary McFarland > > > > > > > > CAN BUS ? > > > > > > > > As in Controller Area Network Bus? Designed by Bosch? > > > > > > > > Gary > > > > gearheadgary@ yahoo.com > > > > http://www.gearheadgary. com > > > > > > > > ----- Original Message ---- > > > > From: David Brady > > > > To: wanderlodge@ yahoogroups. com > > > > Sent: Tuesday, July 17, 2007 10:58:54 PM > > > > Subject: [wanderlodge] 450LXi multiplexed lighting > > > > > > > > Anyone know the name of the vendor who > > > > supplies the multiplexed interior control system > > > > (lighting, etc) for the 450LXi. I think it's CAN > > > > bus based? > > > > > > > > Thanks, > > > > David Brady > > > > '02 LXi, Smokey > > > > NC > > > > > > > > of Use <http://docs. yahoo.com/ info/terms/>| Unsubscribe > > > > > > > > . > > > > > > > > > > > > > > > > > > -- > > > Ken Sann --- In WanderlodgeForum@yahoogroups.com, "raypander" > > I've discovered that my water pump, am-fm radio, tank monitor, bedroom clock etc. are also not working. Apparently a 12 volt problem someplace. > > Ray Pander > 2003 LXI > Now in Topsail Island, NC > |
