batery saver switch
06-07-2005, 01:04
batery saver switch
Glenn,
What was the date on that bulletin?
Mark, 80FC35 in PA
Discover Yahoo!
Get on-the-go sports scores, stock quotes, news & more. Check it out!
06-07-2005, 04:11
batery saver switch
Printer didn't print the whole page and the date is missing but believe it to be
1982
Sent: Tuesday, June 07, 2005 8:04 AM
Subject: Re: [WanderlodgeForum] batery saver switch
Glenn,
Mark, 80FC35 in PA
Discover Yahoo!
Yahoo! Groups Links
06-08-2005, 05:30
batery saver switch
As originally equipped:
'83 and older, one master switch under the dash ahead of driver's
right knee, - turns off everything except radio memory, clocks /
monitor panel, alarm, refrigerator, LP alarm/shutoff.
Late '83 on, a second switch in the left overhead at the rear of the
sofa, should turn off all remaining electronic loads. Some still have
alarm and refrigerator power which would need to be turned off
separately.
- Jeff Miller
--- In WanderlodgeForum@yahoogroups.com, wrote:
> Send me an email. I have part of the BB bulletin that says how to
install a switch that will do as we need. Also says it should have
been done prior to our birds MFG. I'm in KC close to Liberty and
would love to see a bird close to mine. Its the only one I've ever
been around and it ain't like anything I've ever had dealings with.
(SOB's)
> Glenn Shehorn
> 83FC35 RB
> Kansas City MO ( Tornado Alley)
> From: dwalks@a...
> Sent: Monday, June 06, 2005 4:38 PM
> Subject: Re: [WanderlodgeForum] Re: batery saver switch
> Glenn, Phil is right. On my 84fc it is just where he said. Only
it doesn't
> shut off everything in my bird. I shut off both master switch's,
the other
> being by your right knee, under the dash.
> Wish I knew how I can shut off the total deal without taking a
battery cable
> off.
> Any help on this ????????
> walker
> 84FC35
> kcmo
> Yahoo! Groups Links
Service.
06-08-2005, 05:42
batery saver switch
The load center referenced is in the first (small) overhead cabinet
forward of your galley overhead cabinets. You coach would not have
(originally) had this switch, an easy install though.
- Jeff Miller
--- In WanderlodgeForum@yahoogroups.com, "glenn_shehorn"
> I found a BB Engineering bulletin that refers to a switch that shuts
> off the filtered circuits that the master switch doesnt. It says to
> locate it in the overhead cabinet beside the left front load center.
I
> havn't found this load center. Any ideas.
> Glenn Shehorn
> 83FC35RB
> Kansas City Mo
06-08-2005, 08:50
batery saver switch
Thanks, there is a stereo speaker in that door and I might never have seen the
latch unless I was laying on the couch looking aft and up. No switch but looks
like a simple fix that should save Wally World a ton of warranty batteries, this
last set brings the total to sixteen. I may be able to justify good batteries in
the near future
Glenn
83FC35RB
Kansas City Mo
Sent: Wednesday, June 08, 2005 12:42 PM
Subject: [WanderlodgeForum] Re: batery saver switch
- Jeff Miller
I
> Glenn Shehorn
> 83FC35RB
> Kansas City Mo
Yahoo! Groups Links
09-14-2005, 05:38
batery saver switch
I installed a master disconnect in the battery house, forward of the Driver
steer tire. Calterm #41860 12VDC 50A from O'Reillys. simple instal. 3 holes two
1/4 20 bolts and a battery cable. About $30
Glenn Shehorn
83FC35
Kansas City Mo
Glenn, Phil is right. On my 84fc it is just where he said. Only it doesn't
shut off everything in my bird. I shut off both master switch's, the other
Wish I knew how I can shut off the total deal without taking a battery cable
off.
walker
84FC35
kcmo
Yahoo! Groups Links
