reverse polarity/general maintenance
07-04-2009, 14:04
07-04-2009, 22:47
Turn off the Main circuit breakers. and Try again,
Check the AC cable to the Bird and both plugs. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, Randal Akers > > To follow up on the electrical problem, the electrician says it is a short in the alternating current. E verything works with the generator but the electrical line keeps throwing the breaker at the house. He tried following the line into the coach but was unsuccessful. I'd like to find a knowledgeable BB guy in the Kennesaw, GA area or as far south as Atlanta. Thanks. Randy Akers > --- On Wed, 7/1/09, Randal Akers > > > From: Randal Akers > Subject: reverse polarity/general maintenance > To: WanderlodgeForum@yahoogroups.com > Date: Wednesday, July 1, 2009, 12:47 PM > > > > > > > I recently purchased an 86 38' BB from Scott Forman. He told me about this forum. Â The coach has developed a problem in the electrical system. Everytime I try to plug it in to an outlet it throws a breaker at my house. The problem is not at my house. Also, I'd like to find someone that knows Bluebirds to do maintenance on mine. Thanks. Randy Akers > |
07-04-2009, 22:52
07-04-2009, 22:59
Pretty scary!!! Thinking like Ernie at the same time.
Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg > > This sounds like it may be a wire loose in the electrical line- take apart the plugs and check that out. > > > Ernie Ekberg > 83PT40 > Wanderlodge > Weatherford, Tx > http://autos.groups.yahoo.com/group/erni...gandrepair > > --- On Sat, 7/4/09, Randal Akers > > > From: Randal Akers > Subject: [WanderlodgeForum] Re: reverse polarity/general maintenance > To: WanderlodgeForum@yahoogroups.com > Date: Saturday, July 4, 2009, 9:04 PM > > > > > > > > > > > > > To follow up on the electrical problem, the electrician says it is a short in the alternating current. E verything works with the generator but the electrical line keeps throwing the breaker at the house. He tried following the line into the coach but was unsuccessful. I'd like to find a knowledgeable BB guy in the Kennesaw, GA area or as far south as Atlanta. Thanks. Randy Akers > --- On Wed, 7/1/09, Randal Akers > > > From: Randal Akers > Subject: reverse polarity/general maintenance > To: WanderlodgeForum@ yahoogroups. com > Date: Wednesday, July 1, 2009, 12:47 PM > > > > > > > I recently purchased an 86 38' BB from Scott Forman. He told me about this forum. Â The coach has developed a problem in the electrical system. Everytime I try to plug it in to an outlet it throws a breaker at my house. The problem is not at my house. Also, I'd like to find someone that knows Bluebirds to do maintenance on mine. Thanks. Randy Akers > |
07-04-2009, 23:05
07-05-2009, 02:27
07-05-2009, 06:10
The problem here is testing by plugging it in constantly puts continual damage
at risk. a circuit breaker wont trip untill it heats up while making something cook. since the genset runs the system with out issue, the problem must be at transfer or in the shorecord line to the transfer switch???? I also think the repair is simple if you start from basics and learn the dynamics. the transfer switch is a device that automatically gateways powercompany/shorecord electric and genset driven electric. two inputs to the transfer switch but one output out to the bus grey houselike circuit box. run the gen set on the bus. "carefully" test for voltage on your shore cord plug-in prongs. if voltage is there you have issue with the transfer switch. shut off the genset and insulate the shorecord prongs while stowed. Replace the transfer switch. second test: It would work best to have someone dis connect the shorecord input to the transfer switch / at the transfer switch (while unpluggged, no inverter or genset on/lm). At this point the shore cord is like an extension cord, un-attached. at either end you can test the un attached/shorecord 4 wires for continuity to each combination. if there is any continuity (continuous path ) there is a short in the shore cord. you may want to unroll the cord prior to a test to duplicate the state when the problem exists. if continuity in this shore cord unattached, next test; find any place along that path of wires from end to end where there is a terminal, connection or repair. (stow bay, plug end) separate the wires at that junction then retest both sides of the cord path for continuity untill you find the section that has the continuous path problem. it could be at the plug. note that even attached to the transfer switch the common prong and the ground prong should not be continuous; should not show continuity. I am sure your request for info to this most probable existing condition was responded to with a refax of at-sale disclosure statement. Greg ofTim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, Randal Akers > > Thanks for the suggestion but we have tried that. While the coach was parked and connected to park power water got into the adapter connection and melted it. I purchased a new adapter but from that point on it throws the breaker. That leads the electrician that it probably shorted something inside the coach. > --- On Sun, 7/5/09, Ernie Ekberg > > > From: Ernie Ekberg > Subject: Re: [WanderlodgeForum] Re: reverse polarity/general maintenance > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, July 5, 2009, 7:05 AM > > > > > > > > > > > > > and I haven't had my coffee, yet. > > > Ernie Ekberg > 83PT40 > Wanderlodge > Weatherford, Tx > http://autos. groups.yahoo. com/group/ erniesremodeling andrepair > > --- On Sun, 7/5/09, pattypape > > > From: pattypape > Subject: [WanderlodgeForum] Re: reverse polarity/general maintenance > To: WanderlodgeForum@ yahoogroups. com > Date: Sunday, July 5, 2009, 5:59 AM > > > > > > Pretty scary!!! Thinking like Ernie at the same time. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@ yahoogroups. com, Ernie Ekberg > > > > This sounds like it may be a wire loose in the electrical line- take apart the plugs and check that out. > > > > > > Ernie Ekberg > > 83PT40 > > Wanderlodge > > Weatherford, Tx > > http://autos. groups.yahoo. com/group/ erniesremodeling andrepair > > > > --- On Sat, 7/4/09, Randal Akers > > > > > > From: Randal Akers > > Subject: [WanderlodgeForum] Re: reverse polarity/general maintenance > > To: WanderlodgeForum@ yahoogroups. com > > Date: Saturday, July 4, 2009, 9:04 PM > > > > > > > > > > > > > > > > > > > > > > > > > > To follow up on the electrical problem, the electrician says it is a short in the alternating current. E verything works with the generator but the electrical line keeps throwing the breaker at the house. He tried following the line into the coach but was unsuccessful. I'd like to find a knowledgeable BB guy in the Kennesaw, GA area or as far south as Atlanta. Thanks. Randy Akers > > --- On Wed, 7/1/09, Randal Akers > > > > > > From: Randal Akers > > Subject: reverse polarity/general maintenance > > To: WanderlodgeForum@ yahoogroups. com > > Date: Wednesday, July 1, 2009, 12:47 PM > > > > > > > > > > > > > > I recently purchased an 86 38' BB from Scott Forman. He told me about this forum. Â The coach has developed a problem in the electrical system. Everytime I try to plug it in to an outlet it throws a breaker at my house. The problem is not at my house. Also, I'd like to find someone that knows Bluebirds to do maintenance on mine. Thanks. Randy Akers > > > |
07-05-2009, 06:22
If you already haven't, I agree with Ernie that you should disassemble your 50 amp plug and look for burns/shorts. It is an easy check and could be the source of your problem.
Roger Webb
91WL
Cedar Rapids, IA
In a message dated 7/5/2009 5:18:09 P.M. Central Daylight Time, randalakers@... writes:
07-05-2009, 08:25
07-05-2009, 10:17
User(s) browsing this thread: 19 Guest(s)
