Cross reference for Hydraulic fan filter o-ring
08-13-2009, 00:05
Has anyone ever been able to cross reference a match for the Hi Pressure O-ring
that is used on the hydraulic fan canister filter? The bluebird part number that I have is BB #2137024. Shane Fedeli 85PT40 Hershey, PA |
08-13-2009, 02:11
Shane
I think you are looking for the sealing ring for the canister that holds the hydraulic filter.
If so in the back of the WIX/Napa filter catalog are some gaskets/o-rings listed back ther by dimension,not having mine apart and measuring as best I could # 15114 may be what you need but there are others around the same size, but smaller or larger.
I can't see who made that tank to get more information.
Fred & Jeanne Hulse
08-13-2009, 05:29
Hello Shane. Coach Craft in Columbus, GA lost mine. BB told me they didn't
have a part number. I couldn't find a correct o-ring. I ended up making my own o-rings. After 2 years of trying different diameter 0-rings, I gave up on trying to get a o-ring to work. It almost works, but not quite. As you probably know, the cross section of the proper seal looks like a mountain. Glenn Rogers at BB eventually dug up the right part. Sorry I can't be of more help. If I had to use an o-ring again I would supplement the fit with a tube of silicone gasket sealer. Not an elegant solution but may work. Good luck. If you do find the manufacturer of the canister or a source for the gasket please broadcast it. Happy trails, Eric Perplies currently in New Haven, IN 96' 42' WBWL |
08-15-2009, 23:36
Fred, Hugh and others who replied-- thanks very much for the helpful hints. Tom
Sorrentino and I decided to do the job yesterday to see how it all went together and learn what we could. For those of you who have the mid-80's PT chassis and Hydraulic fan setup, the filter gasket that we're talking about sits in a valley, just above the threads, on the top of the long, spin-on bowl that is mounted to the frame near the fan. The bowl is/was made by Parker Filtration. Tom has an '87 with an 8V92 and I have an '85 with a 6V92. Aside from being in different locations, the bowl and filter assemblies were identical. Tom's is located in the tag axle wheel well- Mine was located behind the fan motor and a little higher up on the frame rail. The filter bowl is made of an aluminum alloy and has fine threads that could easily be damaged if you aren't careful when you re-attach the filter bowl. The O-Ring on mine appeared to be original. Tom's was changed by a PO in 1997. Both o-rings were in decent shape and we re-used them. I'm going to get new ones from Bluebird of Pittsburgh. They had 3 new o-rings on the shelf. When they arrive, I will take one to a hydraulic shop in Harrisburg and see if they can match it up in the Parker-Hannifin catalog. When I get some cross-reference numbers, I'll post them here and on the other Wanderlodge sites. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > Shane > I think you are looking for the sealing ring for the canister that holds the hydraulic filter. > If so in the back of the WIX/Napa filter catalog are some gaskets/o-rings listed back ther by dimension,not having mine apart and measuring as best I could # 15114 may be what you need but there are others around the same size, but smaller or larger. > I can't see who made that tank to get more information. > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > |
08-16-2009, 02:44
when I refit unions that require orings and gaskets I always coat the
gasket-ring with grease. that way when you torque them down they wont stretch , only compress. one problem I did notice was if you put too much grease in a track for the oring it can blow out the ring while it compresses. I wonder if oil or soap is a better solution. the hard part about placing orings is when they are to be prefitted around a shaft and it is hard to tell that you did not twist them while passing over threads of the shaft. twisting them distorts the rubber and will cause the ring to fail (I have learned) On aluminum pieces the threads seem to always be fine. I wonder if that is to reduce the damage to the threads from over tightening. I have a Mustang skidsteer that is under warranty contract and serviced by the dealer on site. The tech recently replaced the two hydrolic filters which were also mounted on alumnium. Without explanation the tech directed me to only tighten the filters to stop any chance for leaking and draw a reference line on the filter to the mounting base. one filter is the return and one under pressure. both are one piece throw away. On some hydrolic charge pumps you can find an inline steel filter fitted in the out port of the pump. http://www.tallonhydraulics.com/store/im...0140-4.jpg not that simple but they look like a mini catalitic converter on the inside and capture the big pump damage particles from getting to the motors and rams (fan and steering control). They are servicable. problem with them is there is no bypass and when they clog they will strain the engin rpm. On a tractor the pump is a major % of the HP consumed and strain is a clue. On a minor hp consumable charge pump it will take out the pump. On some of the old stuff I buy I have noticed this filter shade tree installed after market and I always just remove them. They are often installed after a system failure when an unserviced hydraulic filter plugged and fluid went bypass crapping out all the hydraulic appliances. Problem with this filter on a small charge pump like the fan or a dumptruck liftram pump is the HP to run is minimal compared to engine output and operator has no clue of an issue. the fluid sits in the running pump and heats up untill it cooks the pump. The point you make with the cross threading danger with the filter is good. many of the mounting bases for filters are unique to the application. It is best to look for the trajectory of the filter prior to removal to see the angle. when they are way off angle it is easy to notice and refit. When they are only slightly off assumed angle is when you end up fumbling and in danger of cross threading (I have learned). Greg ofTim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Fred, Hugh and others who replied-- thanks very much for the helpful hints. Tom Sorrentino and I decided to do the job yesterday to see how it all went together and learn what we could. For those of you who have the mid-80's PT chassis and Hydraulic fan setup, the filter gasket that we're talking about sits in a valley, just above the threads, on the top of the long, spin-on bowl that is mounted to the frame near the fan. The bowl is/was made by Parker Filtration. Tom has an '87 with an 8V92 and I have an '85 with a 6V92. Aside from being in different locations, the bowl and filter assemblies were identical. Tom's is located in the tag axle wheel well- Mine was located behind the fan motor and a little higher up on the frame rail. The filter bowl is made of an aluminum alloy and has fine threads that could easily be damaged if you aren't careful when you re-attach the filter bowl. The O-Ring on mine appeared to be original. Tom's was changed by a PO in 1997. Both o-rings were in decent shape and we re-used them. I'm going to get new ones from Bluebird of Pittsburgh. They had 3 new o-rings on the shelf. When they arrive, I will take one to a hydraulic shop in Harrisburg and see if they can match it up in the Parker-Hannifin catalog. When I get some cross-reference numbers, I'll post them here and on the other Wanderlodge sites. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > > > Shane > > I think you are looking for the sealing ring for the canister that holds the hydraulic filter. > > If so in the back of the WIX/Napa filter catalog are some gaskets/o-rings listed back ther by dimension,not having mine apart and measuring as best I could # 15114 may be what you need but there are others around the same size, but smaller or larger. > > I can't see who made that tank to get more information. > > Fred & Jeanne Hulse > > Morristown Arizona > > 1997 Wanderlodge WLWB41 > > > |
08-16-2009, 04:21
Greg,
Your comment about using grease on O rings (in moderation) is good, but I would suggest strongly that you use silicone grease as not all O rings are nitrile and there can be a chemical reaction between petroleum based products and some rubber compounds (also, speaking from experience ![]() Paul 97wb43 Silver Spring, MD --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > when I refit unions that require orings and gaskets I always coat the gasket-ring with grease. that way when you torque them down they wont stretch , only compress. one problem I did notice was if you put too much grease in a track for the oring it can blow out the ring while it compresses. I wonder if oil or soap is a better solution. the hard part about placing orings is when they are to be prefitted around a shaft and it is hard to tell that you did not twist them while passing over threads of the shaft. twisting them distorts the rubber and will cause the ring to fail (I have learned) > > On aluminum pieces the threads seem to always be fine. I wonder if that is to reduce the damage to the threads from over tightening. I have a Mustang skidsteer that is under warranty contract and serviced by the dealer on site. The tech recently replaced the two hydrolic filters which were also mounted on alumnium. Without explanation the tech directed me to only tighten the filters to stop any chance for leaking and draw a reference line on the filter to the mounting base. one filter is the return and one under pressure. both are one piece throw away. > > On some hydrolic charge pumps you can find an inline steel filter fitted in the out port of the pump. > http://www.tallonhydraulics.com/store/im...0140-4.jpg > not that simple but they look like a mini catalitic converter on the inside and capture the big pump damage particles from getting to the motors and rams (fan and steering control). They are servicable. problem with them is there is no bypass and when they clog they will strain the engin rpm. On a tractor the pump is a major % of the HP consumed and strain is a clue. On a minor hp consumable charge pump it will take out the pump. On some of the old stuff I buy I have noticed this filter shade tree installed after market and I always just remove them. They are often installed after a system failure when an unserviced hydraulic filter plugged and fluid went bypass crapping out all the hydraulic appliances. Problem with this filter on a small charge pump like the fan or a dumptruck liftram pump is the HP to run is minimal compared to engine output and operator has no clue of an issue. the fluid sits in the running pump and heats up untill it cooks the pump. > > The point you make with the cross threading danger with the filter is good. many of the mounting bases for filters are unique to the application. It is best to look for the trajectory of the filter prior to removal to see the angle. when they are way off angle it is easy to notice and refit. When they are only slightly off assumed angle is when you end up fumbling and in danger of cross threading (I have learned). > > Greg ofTim&Greg > 94ptca > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> wrote: > > > > Fred, Hugh and others who replied-- thanks very much for the helpful hints. Tom Sorrentino and I decided to do the job yesterday to see how it all went together and learn what we could. For those of you who have the mid-80's PT chassis and Hydraulic fan setup, the filter gasket that we're talking about sits in a valley, just above the threads, on the top of the long, spin-on bowl that is mounted to the frame near the fan. The bowl is/was made by Parker Filtration. Tom has an '87 with an 8V92 and I have an '85 with a 6V92. Aside from being in different locations, the bowl and filter assemblies were identical. Tom's is located in the tag axle wheel well- Mine was located behind the fan motor and a little higher up on the frame rail. The filter bowl is made of an aluminum alloy and has fine threads that could easily be damaged if you aren't careful when you re-attach the filter bowl. The O-Ring on mine appeared to be original. Tom's was changed by a PO in 1997. Both o-rings were in decent shape and we re-used them. I'm going to get new ones from Bluebird of Pittsburgh. They had 3 new o-rings on the shelf. When they arrive, I will take one to a hydraulic shop in Harrisburg and see if they can match it up in the Parker-Hannifin catalog. When I get some cross-reference numbers, I'll post them here and on the other Wanderlodge sites. > > > > Shane Fedeli > > 85PT40 > > Hershey, PA > > > > --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > > > > > Shane > > > I think you are looking for the sealing ring for the canister that holds the hydraulic filter. > > > If so in the back of the WIX/Napa filter catalog are some gaskets/o-rings listed back ther by dimension,not having mine apart and measuring as best I could # 15114 may be what you need but there are others around the same size, but smaller or larger. > > > I can't see who made that tank to get more information. > > > Fred & Jeanne Hulse > > > Morristown Arizona > > > 1997 Wanderlodge WLWB41 > > > > > > |
08-16-2009, 06:18
Dow 111
--- In WanderlodgeForum@yahoogroups.com, "p_a_lazar" > > Greg, > > Your comment about using grease on O rings (in moderation) is good, but I would suggest strongly that you use silicone grease as not all O rings are nitrile and there can be a chemical reaction between petroleum based products and some rubber compounds (also, speaking from experience ![]() > > Paul > 97wb43 > Silver Spring, MD > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > when I refit unions that require orings and gaskets I always coat the gasket-ring with grease. that way when you torque them down they wont stretch , only compress. one problem I did notice was if you put too much grease in a track for the oring it can blow out the ring while it compresses. I wonder if oil or soap is a better solution. the hard part about placing orings is when they are to be prefitted around a shaft and it is hard to tell that you did not twist them while passing over threads of the shaft. twisting them distorts the rubber and will cause the ring to fail (I have learned) > > > > On aluminum pieces the threads seem to always be fine. I wonder if that is to reduce the damage to the threads from over tightening. I have a Mustang skidsteer that is under warranty contract and serviced by the dealer on site. The tech recently replaced the two hydrolic filters which were also mounted on alumnium. Without explanation the tech directed me to only tighten the filters to stop any chance for leaking and draw a reference line on the filter to the mounting base. one filter is the return and one under pressure. both are one piece throw away. > > > > On some hydrolic charge pumps you can find an inline steel filter fitted in the out port of the pump. > > http://www.tallonhydraulics.com/store/im...0140-4.jpg > > not that simple but they look like a mini catalitic converter on the inside and capture the big pump damage particles from getting to the motors and rams (fan and steering control). They are servicable. problem with them is there is no bypass and when they clog they will strain the engin rpm. On a tractor the pump is a major % of the HP consumed and strain is a clue. On a minor hp consumable charge pump it will take out the pump. On some of the old stuff I buy I have noticed this filter shade tree installed after market and I always just remove them. They are often installed after a system failure when an unserviced hydraulic filter plugged and fluid went bypass crapping out all the hydraulic appliances. Problem with this filter on a small charge pump like the fan or a dumptruck liftram pump is the HP to run is minimal compared to engine output and operator has no clue of an issue. the fluid sits in the running pump and heats up untill it cooks the pump. > > > > The point you make with the cross threading danger with the filter is good. many of the mounting bases for filters are unique to the application. It is best to look for the trajectory of the filter prior to removal to see the angle. when they are way off angle it is easy to notice and refit. When they are only slightly off assumed angle is when you end up fumbling and in danger of cross threading (I have learned). > > > > Greg ofTim&Greg > > 94ptca > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> wrote: > > > > > > Fred, Hugh and others who replied-- thanks very much for the helpful hints. Tom Sorrentino and I decided to do the job yesterday to see how it all went together and learn what we could. For those of you who have the mid-80's PT chassis and Hydraulic fan setup, the filter gasket that we're talking about sits in a valley, just above the threads, on the top of the long, spin-on bowl that is mounted to the frame near the fan. The bowl is/was made by Parker Filtration. Tom has an '87 with an 8V92 and I have an '85 with a 6V92. Aside from being in different locations, the bowl and filter assemblies were identical. Tom's is located in the tag axle wheel well- Mine was located behind the fan motor and a little higher up on the frame rail. The filter bowl is made of an aluminum alloy and has fine threads that could easily be damaged if you aren't careful when you re-attach the filter bowl. The O-Ring on mine appeared to be original. Tom's was changed by a PO in 1997. Both o-rings were in decent shape and we re-used them. I'm going to get new ones from Bluebird of Pittsburgh. They had 3 new o-rings on the shelf. When they arrive, I will take one to a hydraulic shop in Harrisburg and see if they can match it up in the Parker-Hannifin catalog. When I get some cross-reference numbers, I'll post them here and on the other Wanderlodge sites. > > > > > > Shane Fedeli > > > 85PT40 > > > Hershey, PA > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > > > > > > > Shane > > > > I think you are looking for the sealing ring for the canister that holds the hydraulic filter. > > > > If so in the back of the WIX/Napa filter catalog are some gaskets/o-rings listed back ther by dimension,not having mine apart and measuring as best I could # 15114 may be what you need but there are others around the same size, but smaller or larger. > > > > I can't see who made that tank to get more information. > > > > Fred & Jeanne Hulse > > > > Morristown Arizona > > > > 1997 Wanderlodge WLWB41 > > > > > > > > > > |
08-16-2009, 06:47
08-16-2009, 07:14
a very good silicone grease we use it on valves
Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg > > Stephen, what is Dow 111 ??? > > > Ernie Ekberg > 83PT40 > Wanderlodge > Weatherford, Tx 817-475-3991 > http://autos.groups.yahoo.com/group/erni...gandrepair > > --- On Sun, 8/16/09, Stephen Birtles > > > From: Stephen Birtles > Subject: [WanderlodgeForum] Re: Cross reference for Hydraulic fan filter o-ring > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, August 16, 2009, 1:18 PM > > > > > > > Dow 111 > > --- In WanderlodgeForum@ yahoogroups. com, "p_a_lazar" > > > > Greg, > > > > Your comment about using grease on O rings (in moderation) is good, but I would suggest strongly that you use silicone grease as not all O rings are nitrile and there can be a chemical reaction between petroleum based products and some rubber compounds (also, speaking from experience ![]() > > > > Paul > > 97wb43 > > Silver Spring, MD > > > > --- In WanderlodgeForum@ yahoogroups. com, "Gregory OConnor" > > > > > > when I refit unions that require orings and gaskets I always coat the gasket-ring with grease. that way when you torque them down they wont stretch , only compress. one problem I did notice was if you put too much grease in a track for the oring it can blow out the ring while it compresses. I wonder if oil or soap is a better solution. the hard part about placing orings is when they are to be prefitted around a shaft and it is hard to tell that you did not twist them while passing over threads of the shaft. twisting them distorts the rubber and will cause the ring to fail (I have learned) > > > > > > On aluminum pieces the threads seem to always be fine. I wonder if that is to reduce the damage to the threads from over tightening. I have a Mustang skidsteer that is under warranty contract and serviced by the dealer on site. The tech recently replaced the two hydrolic filters which were also mounted on alumnium. Without explanation the tech directed me to only tighten the filters to stop any chance for leaking and draw a reference line on the filter to the mounting base. one filter is the return and one under pressure. both are one piece throw away. > > > > > > On some hydrolic charge pumps you can find an inline steel filter fitted in the out port of the pump. > > > http://www.tallonhy draulics. com/store/ images/100_ 0140-4.jpg > > > not that simple but they look like a mini catalitic converter on the inside and capture the big pump damage particles from getting to the motors and rams (fan and steering control). They are servicable. problem with them is there is no bypass and when they clog they will strain the engin rpm. On a tractor the pump is a major % of the HP consumed and strain is a clue. On a minor hp consumable charge pump it will take out the pump. On some of the old stuff I buy I have noticed this filter shade tree installed after market and I always just remove them. They are often installed after a system failure when an unserviced hydraulic filter plugged and fluid went bypass crapping out all the hydraulic appliances. Problem with this filter on a small charge pump like the fan or a dumptruck liftram pump is the HP to run is minimal compared to engine output and operator has no clue of an issue. the fluid sits in the running pump and heats up untill it cooks the > pump. > > > > > > The point you make with the cross threading danger with the filter is good. many of the mounting bases for filters are unique to the application. It is best to look for the trajectory of the filter prior to removal to see the angle. when they are way off angle it is easy to notice and refit. When they are only slightly off assumed angle is when you end up fumbling and in danger of cross threading (I have learned). > > > > > > Greg ofTim&Greg > > > 94ptca > > > --- In WanderlodgeForum@ yahoogroups. com, "sfedeli3" <sfedeli3@> wrote: > > > > > > > > Fred, Hugh and others who replied-- thanks very much for the helpful hints. Tom Sorrentino and I decided to do the job yesterday to see how it all went together and learn what we could. For those of you who have the mid-80's PT chassis and Hydraulic fan setup, the filter gasket that we're talking about sits in a valley, just above the threads, on the top of the long, spin-on bowl that is mounted to the frame near the fan. The bowl is/was made by Parker Filtration. Tom has an '87 with an 8V92 and I have an '85 with a 6V92. Aside from being in different locations, the bowl and filter assemblies were identical. Tom's is located in the tag axle wheel well- Mine was located behind the fan motor and a little higher up on the frame rail. The filter bowl is made of an aluminum alloy and has fine threads that could easily be damaged if you aren't careful when you re-attach the filter bowl. The O-Ring on mine appeared to be original. Tom's was changed by a > PO in 1997. Both o-rings were in decent shape and we re-used them. I'm going to get new ones from Bluebird of Pittsburgh. They had 3 new o-rings on the shelf. When they arrive, I will take one to a hydraulic shop in Harrisburg and see if they can match it up in the Parker-Hannifin catalog. When I get some cross-reference numbers, I'll post them here and on the other Wanderlodge sites. > > > > > > > > Shane Fedeli > > > > 85PT40 > > > > Hershey, PA > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "Fred Hulse" > > > > > > > > > > Shane > > > > > I think you are looking for the sealing ring for the canister that holds the hydraulic filter. > > > > > If so in the back of the WIX/Napa filter catalog are some gaskets/o-rings listed back ther by dimension,not having mine apart and measuring as best I could # 15114 may be what you need but there are others around the same size, but smaller or larger. > > > > > I can't see who made that tank to get more information. > > > > > Fred & Jeanne Hulse > > > > > Morristown Arizona > > > > > 1997 Wanderlodge WLWB41 > > > > > > > > > > > > > > > |
08-16-2009, 07:28
