					83 35FC fuel transfer pump location
					08-26-2009, 03:19
				 Post: #1 | |||
					does anyone know the location of the fuel transfer pump located between the tank and the racor. Is it on the cross menmber or the left rear chassis near the tank. I was told it was on the frame back at the tank drivers side but can't locate it. | |||
					08-26-2009, 07:16
				 Post: #2 | |||
| 83 35FC fuel transfer pump location I had an '81FC and it did not have one, just the fuel lift pump on the engine. Several folks have addeda Facet pump in-line along the framewith good results. Dick Hayden - '87 PT 38 - Lake Stevens, WA
					08-26-2009, 11:27
				 Post: #3 | |||
| 83 35FC fuel transfer pump location I’m in the process of doing that very thing with my ’84. From: WanderlodgeForum@yahoogroups.com   does anyone know the location of the fuel transfer pump located between the tank and the racor. Is it on the cross menmber or the left rear chassis near the tank. I was told it was on the frame back at the tank drivers side but can't locate it. | |||
					08-26-2009, 12:59
				 Post: #4 | |||
					My 84 has one mounted above and just behind the rear axle, about even with the streetside edge of the fuel tank. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "Peter Goddu" > > I'm in the process of doing that very thing with my '84. I can supply part > #'s if you need them and will post pix when I'm done. > > > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of larryalb > Sent: Wednesday, August 26, 2009 8:20 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] 83 35FC fuel transfer pump location > > > > > > does anyone know the location of the fuel transfer pump located between the > tank and the racor. Is it on the cross menmber or the left rear chassis near > the tank. I was told it was on the frame back at the tank drivers side but > can't locate it. > | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
