87 FC 35 Generator??????
09-26-2009, 03:14
maybe the linkage on the fuel solenoid is not letting the electromagnetic stroke
of the solenoid go to full open????? there is more force, thus more amp draw
required to open the selonoid then hold it open. Recently some rich friends had
an overheating selonoid problem on their new 97EcknfloorPT. Lucas, The SouthWest
guru of Gensets diagnosed the issue and it made perfect sence.
Greg of Tim&Greg
94ptca
--- In WanderlodgeForum@yahoogroups.com, "sc310c" <sc310c@...> wrote:
> STILL WORKING ON GEN GOT SERVICE MANUAL CAN MANUALLY WORK FUEL SOLENOD WHEN
UNHOOKED AND ENGINE RUNS DOES ANYONE KNOW HOW MANY AMPS IT PULLS
> TKS BOB IN KY STILL HUNTING
09-27-2009, 04:08
I recently replaced the fuel shutoff solenoid on my Onan DKD. The instruction
sheet with the new solenoid assembly indicated that when the governor linkage on
the Onan (Kubota Diesel) is wide open against the stop, the electric solenoid
linkage should be adjusted so that the solenoid is "pulled in" all the way.
Linkage adjustment appears to be critical and could result in chattering or
maybe over heating the solenoid.
Dick Gideon
1989 FC35
8.0 DKD Onan
Rolla, MO
stroke of the solenoid go to full open????? there is more force, thus more amp
draw required to open the selonoid then hold it open. Recently some rich
friends had an overheating selonoid problem on their new 97EcknfloorPT. Lucas,
The SouthWest guru of Gensets diagnosed the issue and it made perfect sence.
> Greg of Tim&Greg
> 94ptca
09-27-2009, 07:36
Then maybe a test of the linkage causing the amp draw would be to disconnect the
linkage then check to see if operating the solenoid will draw the 40 amps it
does now.
then, operate the genset with the shut of linkage opened manualy, ;selonoid
removed from setting but connected to + and- ;; wait to see if the solenoid
will lose its signal disconnected running
then repeat
manualy open the shutoff linkage , remove the solenoid completly, put a test
light on the input to the solenoid, run the gen set and wait for the signal to
disapear.
these test should prove issue. Novice mechanics replace clutches that were
only out of adjustment and assumed that the replacement of the clutch was the
fix.
40 amp might be the result of a bad solenoid , a hard chore, weak connection etc
Greg
> Dick Gideon
> 1989 FC35
> 8.0 DKD Onan
> Rolla, MO
> > Greg of Tim&Greg
> > 94ptca
WHEN UNHOOKED AND ENGINE RUNS DOES ANYONE KNOW HOW MANY AMPS IT PULLS
06-23-2010, 06:55
does anyone know a parts source for the injector pump parts
tks bob maloney 87 fc 35 in ky
06-23-2010, 07:42
Try a Massy Ferguson tractor dealer. MF uses the Perkins engine
in their tractors. You will need the Perkins numbers (lots of numbers) to
locate the proper parts.
Project
success is in the details
Ken Doyle
ConServe
PO Box 35245
Richmond, VA 23235
direct: 301-908-5735
fax: 804-725-2982
ken.hvac-conserve@...
WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On
Behalf Of
sc310c
Sent: Wednesday, June 23, 2010 2:56 PM
Subject: [WanderlodgeForum] 87 FC 35 Generator??????
injector pump parts
06-23-2010, 10:27
In addition to Massey Ferguson, try a Bobcat dealer as they used Perkins also.
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "Ken Doyle"
> Try a Massy Ferguson tractor dealer. MF uses the Perkins engine in their
> tractors. You will need the Perkins numbers (lots of numbers) to locate the
> proper parts.
> Project success is in the details
> Ken Doyle
> ConServe
> PO Box 35245
> Richmond, VA 23235
> fax: 804-725-2982
> [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sc310c
06-23-2010, 11:21
why not try perkins
Stephen 97bmc 37
> Mike Bulriss
> San Antonio, TX
> > proper parts.
> > Ken Doyle
> > ConServe
> > PO Box 35245
> > Richmond, VA 23235
> > fax: 804-725-2982
> > ken.hvac-conserve@
06-23-2010, 11:36
Whenever i need parts i call up these folks- they usually hook me up. It's been
a while though...
Industrial Diesel
http://www.IndustrialDiesel.net
(800) 323-3659
8705 Harmon
Fort Worth, Texas 76117
--- In WanderlodgeForum@yahoogroups.com, "cape0001" <sbirtles@...> wrote:
> why not try perkins
> Stephen 97bmc 37
also.
> > Mike Bulriss
> > San Antonio, TX
> > > proper parts.
> > > Ken Doyle
> > > ConServe
> > > PO Box 35245
> > > Richmond, VA 23235
> > > fax: 804-725-2982
> > > ken.hvac-conserve@
06-24-2010, 02:23
It is an Onan/ Kubota
Bill 88 FC Michigan
> why not try perkins
> Stephen 97bmc 37
also.
> > Mike Bulriss
> > San Antonio, TX
> > > proper parts.
> > > Ken Doyle
> > > ConServe
> > > PO Box 35245
> > > Richmond, VA 23235
> > > fax: 804-725-2982
> > > ken.hvac-conserve@
06-24-2010, 02:25
Bill 88 FC Michigan
> why not try perkins
> Stephen 97bmc 37
also.
> > Mike Bulriss
> > San Antonio, TX
> > > proper parts.
> > > Ken Doyle
> > > ConServe
> > > PO Box 35245
> > > Richmond, VA 23235
> > > fax: 804-725-2982
> > > ken.hvac-conserve@
