electrical issue
11-10-2009, 13:45
electrical issue
While driving my coach from Santa Barbra, I noticed that my engine volt meter
was at 12. Stopped the coach and just as I suspected, no belts on the alternators. No problem, I started the generator and all is well. The question I have is, my generator volt meter is still at 12. I am currently "camped" on the side of the interstate as I don't drive at nite and I didn't think the charger could handle all the lites. Does the main engine alternator charge the generator battery? If the house charger does not do that I might have to add a charger for the generator battery. I have cell phone, internet, and tv. Life is good. and I'm in the coach, which is even better. Ernie- 83PT40 Newberry Springs, Ca- beside the tracks |
11-10-2009, 14:26
electrical issue
Ernie, I was a supervisor our there on the Sorry about your electrical problems. - Chuck 1982 FC 31SB From: While driving my coach from Santa Barbra, I noticed that my engine volt meter was at 12. Stopped the coach and just as I suspected, no belts on the alternators. No problem, I started the generator and all is well. The question I have is, my generator volt meter is still at 12. I am currently "camped" on the side of the interstate as I don't drive at nite and I didn't think the charger could handle all the lites. Does the main engine alternator charge the generator battery? If the house charger does not do that I might have to add a charger for the generator battery. I have cell phone, internet, and tv. Life is good. and I'm in the coach, which is even better. Ernie- 83PT40 Newberry Springs, Ca- beside the tracks |
11-10-2009, 15:06
electrical issue
Hi Ernie,
Sorry for the belt loss. If your rig is like mine, on the passenger side at the rear,there is a isolator bar. It is down low on the side that you open up. Mine had given up the ghost and wasn't charging the gen bat. I ran a seperate wire from the rear batts to the gen bat, with a fuse inline. This makes sure that the gen bat always gets juice. My gen set is probably like yours and doesn't have an alternator. I also carry a battery charger in my pod in the event the alt. gives out and I need to charge any batts. If seems from what you are saying the gen bat isn't getting a charge. Hope it starts for you tomorrow. Do you carry a set of jumper cables with you? If so, and the gen doesn't start, if you have the tools, remove a engine bat and jump the gen bat to get it started. Bob Lawrence 84 PT36 Elko, Ga --- In WanderlodgeForum@yahoogroups.com, "Ernie E" > > While driving my coach from Santa Barbra, I noticed that my engine volt meter was at 12. Stopped the coach and just as I suspected, no belts on the alternators. No problem, I started the generator and all is well. > The question I have is, my generator volt meter is still at 12. I am currently "camped" on the side of the interstate as I don't drive at nite and I didn't think the charger could handle all the lites. > Does the main engine alternator charge the generator battery? > If the house charger does not do that I might have to add a charger for the generator battery. > I have cell phone, internet, and tv. Life is good. and I'm in the coach, which is even better. > Ernie- 83PT40 Newberry Springs, Ca- beside the tracks > |
11-10-2009, 15:07
electrical issue
11-10-2009, 15:10
electrical issue
11-10-2009, 15:15
electrical issue
Ernie
Sounds like you have a handle on the situation for the evening anyhow.
The trains will let you sleep for a few minutes at a time,but you might get used to it.
I am sure you will be ok until you get to Rods and put new belts on the alt. and maybe pick up a little 25 amp.battery charger for back up.
Keep us up to date.
Fred Hulse
11-10-2009, 15:40
electrical issue
Ernie, Unless you have a very small charger you - Chuck 1982 FC 31SB From:
11-10-2009, 15:53
electrical issue
Ernie,
With generator running all batteries should get charged. PTs and most likely FC were all wired to do so. Even the SOBs that I have owned worked the same. I'm waiting to hear from Stephen Birtles regarding his Ontario arrival time...I might get over to the river Friday. Good luck. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Tue, Nov 10, 2009 at 7:40 PM, Chuck Wheeler <"cwheeler@kathleenwheeler.com"> wrote:
11-11-2009, 02:49
electrical issue
11-11-2009, 02:52
electrical issue
