Heater part
12-09-2009, 07:56
Heater part
Hi Steve,
Did you replace the high temp safety switch on the hot water tank??
If so, which switch did you install???
The newer HWT's seem to trip at a lower temp than the original HWT.
Then the switch needs to be manually reset. I seem to also remember,
that the original HWT had an automatic resetable switch.
The HWT mfg. states that the high temp safety is set at 140 degrees.
WIth the engine running at 185/195 it sometimes trips the safety.
Cold water is not a fun surprise.
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "SteveQ" wrote:
> Ron
> I did not read your original post close enough. This control is on an
electric heater in your coach not the hot water system, right?
> I replaced mine on the hot water system, sorry not familiar with the electric
heater. The part that I used was one of the Snap Disc Fan Controls in the
middle of the page.
> Steve Quandt
> 1993 PT 40
> Iron Mountain, MI
> --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002"
> > Is this switch controlling the fan or the heat strip? I am not getting
heat. The fan runs all the time. Your source shows 3 different types of
controls, which is the correct type unit?
> > R.E. (Ron) Marabito, Dallas, TX 92WB40
> > > Ron
> > > They should be White Rodgers parts, look here at the snap disc fan
controls.
> > > http://www.whiterodgers.com/wrdhom/commo...ace_12.htm
> > > I think the one that I used was cut in at 110 and cut out at 90.
> > > Steve Quandt
> > > 1993 PT-40
> > > Iron Mountain, Mi
> > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger
> > > > Ron,
> > > > Another source...Fenwal
http://www.fenwalcontrols.com/utcfs/Temp...Id%3D\
1023%26siteId%3D375,00.html
> > > > Give them a call. Inform them what you have. My guess is they will know
what
> > > > you need.
> > > > Curt Sprenger
> > > > 1987 PT38 8V92 "MacAttack Racing"
> > > > Anaheim Hills, CA
> > > > On Wed, Dec 9, 2009 at 9:28 AM, Curt Sprenger wrote:
> > > > > Correct size? Do you have the heater manual? It might have that
> > > > > information., or direct you to a source to get the information.
> > > > > Curt Sprenger
> > > > > Anaheim Hills, CA
> > > > > On Wed, Dec 9, 2009 at 9:21 AM, ronmarabito2002 wrote:
> > > > >> Yes Curt. How do we determine the correct size?
> > > > >> --- In
> > > > >> > Ron,
> > > > >> > Look like this?
> > > > >> > http://www.thermodisc.com/productdetail.asp?ProductID=1
> > > > >> > the site has lots of them.
> > > > >> > Curt Sprenger
> > > > >> > Anaheim Hills, CA
> > > > >> > On Wed, Dec 9, 2009 at 9:07 AM, ronmarabito2002
> > > > >> > > Studying this closer, it is probably a heat sensor or
thermocouple.
> > > > >> > > --- In
> > > > >> > > "ronmarabito2002" wrote:
> > > > >> > > > Hi all: Does anyone have a source for the round disc resistor
or
> > > > >> > > capacitor that mounts in the top of the Bathroom Electric Heater
for a
> > > > >> > > 92WB40. Mine has disintegrated and can't get heat.
> > > > >> > > > It has TOD 1-B1-B stamped on it.
12-09-2009, 08:03
Heater part
Curt: This information is great if I just had some information of the limits
that the switch is set for. I called Pro Supply who is the authorized parts
distributor for the Cadet Heater and they say the Model TK-101 was a recall and
no parts are available. We both know that others have these switches, but they
won't give me any information of the switch, which appears to be a high limit
switch. According to them, you have to replace the entire heater. Do you think
one of these sites you referred me to would know how to determine that?
--- In WanderlodgeForum@yahoogroups.com, Curt Sprenger wrote:
> Ron,
> Give them a call. Inform them what you have. My guess is they will know what
> you need.
> Curt Sprenger
> Anaheim Hills, CA
> > Curt Sprenger
> > Anaheim Hills, CA
> >> --- In
> >> > Ron,
> >> > Look like this?
> >> > Curt Sprenger
> >> > Anaheim Hills, CA
> >> > On Wed, Dec 9, 2009 at 9:07 AM, ronmarabito2002 wrote:
> >> > > Studying this closer, it is probably a heat sensor or thermocouple.
> >> > > --- In
> >> > > > Hi all: Does anyone have a source for the round disc resistor or
> >> > > capacitor that mounts in the top of the Bathroom Electric Heater for a
12-09-2009, 08:53
Heater part
Ron, if you look closely you should see a temperature
stamped in it. This is the cutoff temperature that protects from overheating.
They are available locally here from Granger, although I get most of my parts
from Appliance parts Co in Richland
hills.
- Chuck
Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of ronmarabito2002
Sent: Wednesday, December 09, 2009
11:21 AM
Subject: [WanderlodgeForum] Re:
Heater part
TX
92WB40
--- In "WanderlodgeForum%40yahoogroups.com",
Curt Sprenger ...> wrote:
> Ron,
> Look like this?
> Curt Sprenger
> Anaheim Hills, CA
> On Wed, Dec 9, 2009 at 9:07 AM, ronmarabito2002 ...>
TX
92WB40
> > --- In "WanderlodgeForum%40yahoogroups.com"40yahoogroups.com>,
a
TX
92WB40
12-09-2009, 11:04
Heater part
No temperature stamped on this one. Only markings are TOD-1-B1-B
--- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" wrote:
> Ron, if you look closely you should see a temperature stamped in it. This
> is the cutoff temperature that protects from overheating. They are
> available locally here from Granger, although I get most of my parts from
> Appliance parts Co in Richland hills.
> - Chuck Wheeler-
> _____
> Sent: Wednesday, December 09, 2009 11:21 AM
> Subject: [WanderlodgeForum] Re: Heater part
> > Ron,
> > Look like this?
> > http://www.thermodi
> <http://www.thermodisc.com/productdetail.asp?ProductID=1>
> > Curt Sprenger
> > Anaheim Hills, CA
> yahoogroups.com,
12-09-2009, 12:05
Heater part
Ron:
Cadet is located in Vancouver, WA. Their main part supplier is Reliable Parts.
They have a location in the Portland, OR area that I have bought from. Their
number is Sales: (503) 239-6050. Give them a call and they will either sell you
a part or can provide you with a current model electric heater. I bought one
for a project and it was suprisingly cheap.
Marv
2004 M380
Ocean Shores, WA
> > - Chuck Wheeler-
> > _____
> > > Ron,
> > > Look like this?
> > > http://www.thermodi
> > > Curt Sprenger
> > > Anaheim Hills, CA
> > yahoogroups.com,
12-09-2009, 12:40
Heater part
Does it look like one of these? Limit
Switches
I have replaced two of ours, but we have
different heaters I believe. I found the limit temperture stamped on the
mounting ring.
- Chuck
Wheeler-
5:04 PM
Heater part
TOD-1-B1-B
TX
92WB40
hills.
> - Chuck Wheeler-
TX
> _____
> From: "WanderlodgeForum%40yahoogroups.com"
> [mailto:"WanderlodgeForum%40yahoogroups.com"]
TX
92WB40
> --- In WanderlodgeForum@ Forum%40yahoogroups.com>
> yahoogroups.com, Curt Sprenger > wrote:
> > Ron,
> > Look like this?
> > http://www.thermodi
> > Curt Sprenger
> > Anaheim Hills, CA
> > On Wed, Dec 9, 2009 at 9:07 AM, ronmarabito2002 >
thermocouple.
TX
92WB40
> yahoogroups.comorum%40yahoogroups.com>,
resistor or
for a
TX
92WB40
12-09-2009, 14:26
Heater part
They are not interested in selling anything for the old models. They only want
to sell you a new heater unit complete. All I need is a less than $10 part and
I intend to find it somewhere.
Thanks for your response.
--- In WanderlodgeForum@yahoogroups.com, "marvjeanm380" wrote:
> Ron:
Parts. They have a location in the Portland, OR area that I have bought from.
Their number is Sales: (503) 239-6050. Give them a call and they will either
sell you a part or can provide you with a current model electric heater. I
bought one for a project and it was suprisingly cheap.
> Marv
> 2004 M380
> Ocean Shores, WA
> > > - Chuck Wheeler-
> > > _____
> > > > Ron,
> > > > Look like this?
> > > > http://www.thermodi
> > > > Curt Sprenger
> > > > Anaheim Hills, CA
> > > yahoogroups.com,
12-09-2009, 14:32
Heater part
Ron,
I would think that given the wattage of the heater somebody like Grainger or Johnstone Supply should be able to come up with a high limit switch for it.
Dave Ward
80FC31SB
Mesa, AZ
Date: Thursday, December 10, 2009, 2:26 AM
They are not interested in selling anything for the old models. They only want to sell you a new heater unit complete. All I need is a less than $10 part and I intend to find it somewhere.
--- In WanderlodgeForum@ yahoogroups. com, "marvjeanm380" wrote:
> Ron:
> Cadet is located in Vancouver, WA. Their main part supplier is Reliable Parts. They have a location in the Portland, OR area that I have bought from. Their number is Sales: (503) 239-6050. Give them a call and they will either sell you a part or can provide you with a current model electric heater. I bought one for a project and it was suprisingly cheap.
> Marv
> 2004 M380
> Ocean Shores, WA
> > > - Chuck Wheeler-
> > > _____
> > > From: WanderlodgeForum@ yahoogroups. com
> > > [mailto:WanderlodgeForum@ yahoogroups. com] On Behalf Of ronmarabito2002
> > > To: WanderlodgeForum@ yahoogroups. com
> > > yahoogroups. com, Curt Sprenger wrote:
> > > > Ron,
> > > > Look like this?
> > > > http://www.thermodi
> > > <http://www.thermodi sc.com/productde tail.asp? ProductID= 1>
> > > sc.com/productdetai l.asp?ProductID= 1
> > > > Curt Sprenger
> > > > Anaheim Hills, CA
> > > yahoogroups. com,
12-09-2009, 14:38
Heater part
Besides the current draw of the heater you
need to know the cutoff temperature. I was lucky, the switch used in our
heaters was the same one used to protect most electric dryers so it was
available and cheap ($6.50) locally at Appliance parts.
- Chuck
Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of David Ward
8:33 PM
Subject: Re: [WanderlodgeForum]
Re: Heater part
Ron,
Dave Ward
80FC31SB
Mesa, AZ
--- On Thu, 12/10/09, ronmarabito2002 net>
TX
92WB40
yahoogroups. com
, "marvjeanm380"
> Ron:
WA
suprisingly cheap.
> Marv
> 2004 M380
> Ocean Shores, WA
yahoogroups. com
TX
92WB40
yahoogroups.. com
, "Chuck Wheeler"
in it. This
are
parts from
hills.
> > > - Chuck Wheeler-
> > > 1982 FC 31SB Fort
Worth
TX
> > > _____
yahoogroups. com
yahoogroups. com
yahoogroups. com
TX
92WB40
> > > --- In WanderlodgeForum@ Forum%40yahoogro ups.com>
> > > > Ron,
> > > > Look like this?
> > > > http://www.thermodi
> > > > Curt Sprenger
> > > > Anaheim Hills,
CA
or thermocouple.
92WB40
> > > yahoogroups. com,
> > > > > "ronmarabito2002"
disc resistor or
92WB40
12-10-2009, 02:19
Heater part
I'll try a couple outfits for a match. Got to take my coach to Ernie today for
new carpet.
--- In WanderlodgeForum@yahoogroups.com, David Ward wrote:
> Ron,
> Dave Ward
> 80FC31SB
> Mesa, AZ
> From: ronmarabito2002
> Â
> > Ron:
> > Marv
> > 2004 M380
> > Ocean Shores, WA
> > > --- In WanderlodgeForum@ yahoogroups. com, "Chuck Wheeler"
This
from
> > > > - Chuck Wheeler-
> > > > _____
> > > > > Ron,
> > > > > Look like this?
> > > > > http://www.thermodi
> > > > > Curt Sprenger
> > > > > Anaheim Hills, CA
> > > > > > --- In WanderlodgeForum@ ups.com>
> > > > yahoogroups. com,
a
