Genny 12.5kw kohler
06-15-2005, 14:31
Genny 12.5kw kohler
Just when I thought I got the genny fixed and ready to run for another
3000 hrs I found a problem...When I used the Perkins/Kohler 12.5 at
Maxton recently I ran it for about 4 days nonstop..(cept when the
propane was leakin) and it ran great. Steady voltage, temps were good
about 140-150, all was good. The other day I started to cool down the
coach to work on the spot/flood lights. I just happened to glance at
the guages over the passenger side and both meters were pegged!! Then
to the galley both were very high with the top meter fluttering..I then
checked the outlet by the door with a meter and it was 140.2 volts!!
yikes I shut it down..crawled under it and replaced the regulator and
refired it back up...SAME RESULTS..Now I am stumped as where to go! I
just replaced the stator (had a hard ground in the excite circut) the
brushes are brand new, end bearing is brand new, regulator brand
new..Could the regulator need set??? Would the transfer switch have any
thing to do with it??? Maybe a ground issue in the transfer switch??
ANYONE HAVE ANY IDEAS???
thanks in advance for any help
Scott
86FC35
Murrells Inlet SC (over 100 deg here today is this heaven or #@%*)
06-15-2005, 15:18
Genny 12.5kw kohler
hmmm.does it sound like the rpm's are higher than normal? thats all i
have,where's jeff miller? randy
Sent: Wednesday, June 15, 2005 10:31 PM
Subject: [WanderlodgeForum] Genny 12.5kw kohler
Scott
86FC35
Yahoo! Groups Links
06-16-2005, 00:02
Genny 12.5kw kohler
Randy, I am not sure..its sounds normal..what should the motor be
turning??
Scott
86FC35
Sc
--- In WanderlodgeForum@yahoogroups.com, randydupree
i have,where's jeff miller? randy
> From: Scott
another
at
good
at
Then
fluttering..I then
volts!!
go! I
have any
switch??
> Scott
> 86FC35
> Yahoo! Groups Links
Service.
06-16-2005, 02:15
Genny 12.5kw kohler
My understanding is the gen. has to turn a constant 1,800 rpm to
maintain the 110/220 volt 60 hz.
> turning??
> Scott
> 86FC35
> Sc
06-16-2005, 08:09
Genny 12.5kw kohler
Curt,
RPM is for hertz..... 1800 rpm with a 4 pole generator gives 60 htz.
If the voltage is off, that's an adjustment on the generator....B
>Curt Sprenger '87PT38, Anaheim, Calif.
> > turning??
> > Scott
> > 86FC35
> > Sc
>Yahoo! Groups Links
