***@@water pumps
02-01-2010, 01:54
***@@water pumps
We had Foretravel of Nacogdoches replace both of our waterpumps last April.
They worked fine up until sometime last week. The wife commented that she
thought that she had been hearing the water pumps running continuously for
several minutes. Oh oh, I thought, empty water tank and a faucet running
somewhere; maybe a leak? Nope. Tank is full and faucets all secure. No leaks
anywhere. Cycled all of the pump switches on/off. The pump would turn on/off
but no suction, no increase in water pressure. Crawled into the pump area to do
a visual/feel. Only the top one runs but no suction. The bottom one won't even
run. Anyone been there? Thanks.
Ron & Ruth
2000 LXI in SPI
02-01-2010, 06:56
***@@water pumps
Hi Ron,
I've been there enough times to prompt me to rip out the two shurflo's
with accumulator tank and replace the whole contraption with one shurflo
extreme 5.7 gpm constant pressure pump. No looking back. :-)
David Brady
'02 LXi, NC
last April. They worked fine up until sometime last week. The wife
commented that she thought that she had been hearing the water pumps
running continuously for several minutes. Oh oh, I thought, empty water
tank and a faucet running somewhere; maybe a leak? Nope. Tank is full
and faucets all secure. No leaks anywhere. Cycled all of the pump
switches on/off. The pump would turn on/off but no suction, no increase
in water pressure. Crawled into the pump area to do a visual/feel. Only
the top one runs but no suction. The bottom one won't even run. Anyone
been there? Thanks.
Ron & Ruth
2000 LXI in SPI
02-01-2010, 07:55
***@@water pumps
Hello David, How long has the Shurflo Extreme been out, and how long has it been since you installed yours? Are they pricey? May need one this spring. Thanks, George Burke 1977 FC31 Charlotte
On Mon, Feb 1, 2010 at 1:56 PM, david brady <"dmb993@earthlink.net"> wrote:
Hi Ron,
David Brady
'02 LXi, NC
We had Foretravel of Nacogdoches replace both of our waterpumps last April. They worked fine up until sometime last week. The wife commented that she thought that she had been hearing the water pumps running continuously for several minutes. Oh oh, I thought, empty water tank and a faucet running somewhere; maybe a leak? Nope. Tank is full and faucets all secure. No leaks anywhere. Cycled all of the pump switches on/off. The pump would turn on/off but no suction, no increase in water pressure. Crawled into the pump area to do a visual/feel. Only the top one runs but no suction. The bottom one won't even run. Anyone been there? Thanks.
Ron & Ruth
2000 LXI in SPI
02-01-2010, 08:02
***@@water pumps
I did the same thing -- used the 5.7 gpm on demand pump for 2+ years until I sold the coach. Had no problems with the pump. Better pressure than before. Some Microphor toilets aren't "happy" with the extra pressure, so you may need to install a pressure limiter on the water line serving the toilet. (Or open a cold water tap just before flushing to momentarily drop the pressure.)
See photos of the installation at:
Pete Masterson
(former) '95 Blue Bird Wanderlodge WBDA 42
El Sobrante CA
"aeonix1@mac.com"
On Mon, Feb 1, 2010 at 1:56 PM, david brady<"dmb993@earthlink.net">wrote:
Hi Ron,
David Brady
'02 LXi, NC
Ron & Ruth
2000 LXI in SPI
02-01-2010, 08:22
***@@water pumps
Hi George,
They've been out a good 3+ years. Amazon has them for $167.00.
http://www.amazon.com/SHURflo-5900-0211-...B000BGM326
David Brady
'02 LXi, nC
Hi Ron,
David Brady
'02 LXi, NC
been there? Thanks.
Ron & Ruth
2000 LXI in SPI
02-01-2010, 08:28
***@@water pumps
George,
I bought one of their early pumps which failed shortly thereafter. They
made
some improvements and my second pump is well into it's second year.
They're
quite, they cycle only when you turn on a faucet, and the pressure and
flow rates
are smooth and consistent. If they fail in the field, limp over to
Camping World and
buy another, they're simple to install and replace. One caveat is that
you input and
outputs should be free of elbows for the first 18 inches. Shurflo
provides a good
set of fittings available for the pump.
David Brady
'02 LXi, NC
Hi Ron,
David Brady
'02 LXi, NC
been there? Thanks.
Ron & Ruth
2000 LXI in SPI
02-01-2010, 08:42
***@@water pumps
I just replaced ours with a Shurflo 2.8 GPM because I was concerned about water pressure in the older coaches. Wouldn't a higher flow rate pump potentially develop a higher pressure than the ratings of our old pipes and tubes?
Greg Young
86 PT-40
Escondido, CA
Each time you judge yourself you break your heart.
-Kirpal Venanji
Sent: Mon, February 1, 2010 10:56:39 AM
Subject: Re: [WanderlodgeForum] ***@@water pumps
Hi Ron,
David Brady
'02 LXi, NC
been there? Thanks.
Ron & Ruth
2000 LXI in SPI
02-01-2010, 09:02
***@@water pumps
The 5.7 gpm variable speed pump produces about 65 psi. The pipes in most RVs should be able to handle this without serious problems. I experienced zero problems (other than a glitch with the Microphor flushing -- but that wasn't the pipes...)
If you are very concerned, Shurflo also makes a 4.0 gpm variable speed pump that produces about 50 psi.
Shore water is limited to 40 psi by the most common limiting devices -- and is a very conservative setting. Adjustable pressure limiters are available that allow higher pressures. (Many BBs have 'built in' pressure limiters located at the water input port.)
Visit the Shurflo web site for information about both the 5.7 and the 4.0 gpm pumps:
Pete Masterson
El Sobrante CA
"aeonix1@mac.com"
Greg Young
86 PT-40
Escondido, CA
-Kirpal Venanji
To:"WanderlodgeForum@yahoogroups.com"
Sent:Mon, February 1, 2010 10:56:39 AM
Subject:Re: [WanderlodgeForum] ***@@water pumps
Hi Ron,
David Brady
'02 LXi, NC
Ron & Ruth
2000 LXI in SPI
02-01-2010, 09:11
***@@water pumps
The fresh water system is tested at 120 psi minimum to pass the RVIA/RVDA specs to be certified. Blue Bird's will take the pressure. I have the5.7 65psi pump in my 84FC. The copper tubing is rated at 600psi burst as is the PEX type tubing.
Safe travels, Ralph Charolette Fullenwider
'84 FC35 "Ruff Diamond"
Duncan, Oklahoma
Sent via BlackBerry by AT&T
Date: Mon, 01 Feb 2010 13:02:25 -0800
To:
Pete Masterson
El Sobrante CA
"aeonix1@mac.com"
Greg Young
86 PT-40
Escondido, CA
-Kirpal Venanji
Hi Ron,
David Brady
'02 LXi, NC
We had Foretravel of Nacogdoches replace both of our waterpumps last April. They worked !
Ron & Ruth
2000 LXI in SPI
02-01-2010, 09:30
***@@water pumps
More than twice that. I bought one in March of 2003, after they were reviewed in
MotorHome magazine, so I would guess they came out in late 2002.
That first one had problems with frequent cycling and "leak back" and was
replaced by Shurflo in June of 2003. It was working fine when the coach (SOB)
was sold in December of 2007.
On 2/1/2010 at 3:22 PM david brady wrote:
>Hi George,
>David Brady
>'02 LXi, nC
>> On Mon, Feb 1, 2010 at 1:56 PM, david brady >> > wrote:
>> Hi Ron,
>shurflo's
>> shurflo
>> David Brady
>> '02 LXi, NC
>>> there? Thanks.
>>> Ron & Ruth
>>> 2000 LXI in SPI
